Dash lights don't light up with headlights on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2006taco6spd, Aug 3, 2017.
  1. Aug 3, 2017 at 6:51 PM
    2006taco6spd
    2006taco6spd [OP] Member
    Kevin
    2006 red tacoma ext cab
    2in lift, 32s, mikey thompson wheels, custom grille
    I recently installed an aftermarket radio on my 2006 tacoma, now when i turn on my headlights the dash wont light up but when my headlights are off the dash lights up. Its not the dimmer switch i checked that already. Could i have blown a fuse?
  2. Aug 4, 2017 at 3:35 PM
    highriserkaiser
    highriserkaiser Estoy Grifo
    Gunnison National Forest
    2007 DCSB TRD Offroad 4x4
  3. Aug 4, 2017 at 3:37 PM
    DeathLurkZ
    DeathLurkZ Active Member
    Dave
    2011 Tacoma Double Cab TRD Off Road
    Stock
    Ya you could have blown a fuse, the manual or the lid to the fuse box should have a diagram. I blown my fair share of fuses whem I was younger putting in radios.
  4. Aug 4, 2017 at 4:10 PM
    2006taco6spd
    Kevin
    Would it be the fuses under the dash or under the hood?
  5. Aug 4, 2017 at 5:35 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    In my 2014 the fuse for the instrument panel lights are in the fuse box within the cab. 3rd from the left top row.
  6. Aug 5, 2017 at 2:23 AM
    caribe makaira
    Caribbean, Puerto Rico
    It's your TAIL fuse blown. Remove the ground cable of battery before you do electrical work. Yes, even removing & replacing a fuse.
    It's in Cab behind the "stash tray". Open, squeeze sides to clear tabs then pull up.
    Reverse to install.
    tomwil likes this.
  7. Aug 5, 2017 at 7:22 AM
    2006taco6spd
    Kevin
    Thank you that helped a lot, but if i replace it do you think it will blow again? If it does blow again my wiring for the radio is probably messed up?
  8. Aug 5, 2017 at 7:27 AM
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    maybe you need to look at the illumination wire on the radio harness or the harness you bought to wire up the radio.
  9. Aug 5, 2017 at 10:47 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    x2
    If I understand this, The illumination wire tells the Clock and radio that the lights are on (Dark outside) and they dim the radio lighting. Check the illumination wire from the truck and the "dimmer" wire on the radio.
  10. Aug 6, 2017 at 5:04 AM
    2006taco6spd
    Kevin
    Probably what's wrong because the fuse is perfect
  11. Aug 6, 2017 at 6:09 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  12. Aug 6, 2017 at 11:16 AM
    2006taco6spd
    Kevin
    I disconnected the 2 orange wires and the dash doesnt light up at all
  13. Aug 7, 2017 at 5:51 AM
    caribe makaira
    This is more like what your looking for...
  14. Aug 7, 2017 at 6:31 AM
    2006taco6spd
    Kevin
    I solved the problem, the 2 orange wires i had connected, one of them (orange and black) needed to be grounded so i hooked it to a piece of metal on the side of the radio and everything works fine now
