Dash lights dim when brakes applied or flash with left signal on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DESTROYERRACER, Jan 24, 2015.
  1. Jan 24, 2015 at 6:47 AM
    DESTROYERRACER
    DESTROYERRACER [OP] Well-Known Member
    Sean
    Buffalo NY
    18 DCSB 4x4 SR5
    It's new......mods starting soon. Removed step bars so far. lol
    So Thursday night I noticed my dash lights started blinking with the left and left only turn signal. Also, when I apply the brake pedal my lights all dim. I am thinking a bad ground or short somewhere. Anyone ever have this happen?! 2010 Reg Cab 4x4. I do have a Curt plug n play trailer wire harness on it but it has worked fine until now, any possibilities this has something to do with it?! Maybe something went bad inside it?! Figured its tied into brakes and signal. I'm pulling her in my garage shortly to start going through everything just wondering if anyone else has heard of this?! Thanks
  2. Jan 24, 2015 at 6:51 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    With lights dimming it would indicate a short circuit. The Curt harness would be a good place to start ( remove it and see if it goes away ). That being said it seems to be a problem with the Left Side Brake and Turn Signal circuit.
  3. Jan 24, 2015 at 7:38 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Bad ground some where.
  4. Jan 24, 2015 at 9:39 AM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Did you just replace any brake light bulbs? If not check the bulb contacts for corrosion.
    Could also be the curt harness. Unplug it and check. I had one fail on me and kept shorting my tail light circuit.
    smartbomb likes this.
  5. Jan 25, 2015 at 6:10 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you have a short circuit it will blow fuses if you have a bad ground it will drive dash lights nuts. If it's just when the tail lights are on then that's is where you need to check first if it only happens with the signals that find out what side. Disconnecting the aftermarket harness may correct the problem that would be one thing to try but may not be the answer just because the problem goes away does not mean the harness t's self is bad it could be a bad ground at the other end. Factory wiring usually does not have problems but any time you see some thing spliced or taped up there is where you want to look. Toyota does not ground the tail lamp to the body in the back it gets to the lights through the harness so if a connection at that wire is bad it's going to cause problems.
  6. Jan 25, 2015 at 6:38 AM
    DESTROYERRACER
    Sean
    Buffalo NY
    18 DCSB 4x4 SR5
    So , here is what I found and corrected to fix my problem. Thanks everyone for the responses, however by the time I got on here and checked them I already solved the issue. I started by inspecting all wires, checked my grounds and since I was in my shop and not on the road I decided to check all the other lights. In fact, when I would turn my left signal on, not only did my dash lights flash, so did my front marker lights and all the LEDs in my light housings. When I applied the brakes, dash lights would dim out as previously stated as well as a slight glow from my front end lights. Everything else in the truck ( grounds, connections ) are good. I am anal with installation, always weatherproof, protect or mount to avoid rubbing etc. Anyways, it did indeed turn out to be the Curt wiring harness module. After checking everything else in the truck, I returned the tail lights to stock wiring configuration and problem was gone.My buddy is the manager of the local APS and delivered a new harness to swap out because I bought it from him originally. Interestingly enough, when I pulled the new wire harness / module out, it turns out that Curt totally redesigned the harness. Previously the module mounted in the center of the truck underneath and had two equally lengthed plug n play wires that ran up to each tail light with a short 4 way connection( maybe 2 feet long?!) to route to the trailer severely limiting mounting options to keep it protected from elements.
    The new module / harness I received ( same PN / listed applications ) now mounts the module up directly behind the driver side tail light with a short ground wire and one very long set of wires to run to the passenger side and a considerably longer 4 way to route to the trailer......now its all nice and protected from the elements. Must have been enough of a problem for them to re design it
    Jimmyh likes this.
  7. Jan 25, 2015 at 6:41 AM
    DESTROYERRACER
    Sean
    Buffalo NY
    18 DCSB 4x4 SR5
    oh , and when I inspected the first Curt module I took off the truck it was "puffed" out in a few spots indicating to me that salt/water had penetrated it and caused damage / corrosion internally. Sad part is I just installed the hitch and harness in mid 2014
    Jimmyh likes this.
  8. Jan 25, 2015 at 6:50 AM
    DESTROYERRACER
    Sean
    Buffalo NY
    18 DCSB 4x4 SR5
    and this is why I need trailer lights....
  9. Jan 26, 2015 at 5:07 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Ha, you got snow! It have been a terribly winter up here right now we have maybe 6" of snow on the ground and a poker rally coming up this weekend doing a snow dance this afternoon to make sure we get hit by the nor'easter. I have only been out once this winter. The aftermarket controllers for the lights are not much with no real protection for short circuits if they are shorted it cooks a diode instead of blowing a fuse. That is an excellent place to put the controller my old 97's controller was in there also and lasted 285K miles.
  10. Jan 23, 2025 at 4:00 PM
    smartbomb
    smartbomb rcvr/xmtr
    usually northwest of you
    2006 4-door prerunner long bed
    3" suspension lift, hard canopy, light bar in hood, ditch lights, aircraft cargo bars, powdercoated steel spares, desert tires, bed cargo bars (for rifle cases), misc interior doo-dads
    necropost, you saved my ass bro.
    I was pulled over for not having any tail lights and I traced the short to the Curt harness on the back of my truck. It was just a tiny cut with a lot of corrosion on it and I simply torn the whole thing out and re-connected the OEM tail light wiring. Took about three hours to find and ten minutes to fix.
    Vinz Clortho likes this.
  11. Apr 27, 2025 at 4:22 PM
    Vinz Clortho
    Vinz Clortho Member
    Roseville, CA
    2011 TRD Off Road Double Cab Short Bed
    I just got home from a weekend off-road trip and am having the exact same issue. Glad to have found the thread, now to find the short.
