Dash control panel lights bulbs won't light up
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hamer95USA, Jan 31, 2017.
  1. Jan 31, 2017 at 3:10 PM
    Hamer95USA
    Hamer95USA [OP] Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    Hello everyone,
    I have a 1999 Toyota Tacoma. My dashboard lights in the heater/AC control panel have burned out. I took off the panel cover, knobs, handles, and AC button and tried to replace the #74 bulbs, using the information on the DIY on the 1st generation Tacoma forums. The new #74 replacement bulbs that I installed on the heater/AC control panel doesn't work in either of the 2 positions. Does anyone know what's the best way to repair this issue?
  2. Jan 31, 2017 at 3:13 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    probably fuses.
    there are 2 boxes, one under the hood, and one under the driver side kick panel.
  3. Jan 31, 2017 at 3:34 PM
    Hamer95USA
    Thanks for responding to my thread. I did check both 10 amp fuses for the control panel in the engine bay and the driver side kick panel. Both fuses are in good condition. The other dashboard lights on the temperature/tachometer/spedometer/fuel/ashtray/AC/glovebox light up when I turn on the lights. Are there any other suggestions on how to fix this issue?
  4. Jan 31, 2017 at 3:54 PM
    jbrandt
    Justin
    get a volt meter and start tracing where you get voltage...
    You say you checked the two 10A panel fuses, but there's another a/c fuse under the hood (10A), check that too.
    I've had fuses blow that on initial inspection look good, but sometimes you have to look pretty closely.
  5. Jan 31, 2017 at 4:00 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Do the dash lights dim with a rheostat?
  6. Jan 31, 2017 at 4:09 PM
    Hamer95USA
    @jbrandt: I used the spare 10A fuse and tried it on the gauge & AC positions. It still doesn't illuminate the heater/AC dash panel. Where would I start to measure for voltage with a mulitmeter?
    @File IFR: What is a rheostat? I adjusted the dashboard lights with the dimmer control on the lower left. The dimmer control works properly.
  7. Jan 31, 2017 at 8:31 PM
    jbrandt
    Justin
    I would start where you know the problem is. The light sockets. Tho I don't know if you can get the voltmeter leads in the sockets...
  8. Feb 7, 2017 at 1:54 AM
    James Lee
    James Lee 1st gen for the win.
    Seattle,WA
    2001 Tacoma 4x4 Limited TRD
    -OME 882 coils -Jeep Jk 10mm trimpackers -Wheeler's extending rear brake line -OME Dakars+aal -4in Deckplate -nitro sport shocks all around -Star Hid projector headlights -Trail gear rock sliders -Trail Gear low profile front bumper -Pro Comp 51's 15x8 on BFG KO 32" -ARB snorkel -EBC pads and rotors -Rago Fabrication ditch lights+brackets -SpiderTraxx 1.25 wheel spacers -Snugtop Canopy
    Check the tail light fuse underneath the hood. I had the same problem with my 01 last week.
  9. Feb 7, 2017 at 8:45 AM
    Hamer95USA
    Thanks for the suggestion. I visually inspected the 10A fuse for the tail light at the fuse box in the engine bay. The fuse looks to be in good condition. I also tested it for continuity with a multimeter. The fuse shows continuity. The tail lights work properly, but it didn't solve my non working climate control dashboard light issue.
  10. Jul 29, 2019 at 1:07 PM
    Hamer95USA
    I'm still dealing with burned out lights on the AC/heater control panel. I watched a few YouTube videos and noticed that you can replace the bulb sockets on the climate control module to get the light working again. Does anyone know what the part number is for climate control module light bulb socket? If you can't replace the light bulb socket, is there an alternative part that can be used to replace the light socket? Can the light socket be repaired?
  11. Sep 19, 2019 at 8:25 PM
    Murray.elgancho
    Murray.elgancho Member
    Murray
    San Diego
    1999 2.7L Tacoma
    I'm having the same issue. Please help!
  12. Sep 19, 2019 at 10:00 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Sockets need a little help in their old age-
    Make sure lights are off
    Remove bulb from socket
    use pick or tiny screwdriver to slightly pull contacts closer to bulb position. Just a tiny amount here, don't break anything.
    Re-insert new bulb and check your work. Sometimes you need ot re-arrange the contacts on the bulbs as well to make things work best
  13. Sep 19, 2019 at 10:31 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Are the new bulbs LED? If so, you might just have to reverse the polarity.
  14. Sep 20, 2019 at 8:00 PM
    nautilus
    nautilus Member
    2002 Tacoma
    I bought the Toyota 90010-05120 Bulbs from eBay and replaced all three bulbs in my 02.
    I had to take out the whole climate control module and take it apart to replace the bulbs from the back. Definitely worth it.
    Hamer95USA[OP] likes this.
