Dash Cam?
Discussion in 'General Tacoma Talk' started by allelopath, Nov 13, 2023.
  1. Nov 13, 2023 at 7:48 AM
    allelopath
    allelopath [OP] Active Member
    2023 Toyota Tacoma Trail
  2. Nov 13, 2023 at 7:59 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    A lot. You want a sensor that is good in a wide variety of lighting conditions, first and foremost. Cheap cams might capture a license plate if it was in cloudless daylight, at noon, and if the other driver was kind enough to hold the plate perfectly still in front of the camera, and also read the numbers out loud. Anything between evening and morning hours, good luck. You also want a buffered parking mode so that you can see the footage 20 seconds before impact, not 5 seconds after.
    The cheap 100 buckers wont have either of those, and they are kind of important.
    TacomaCZman, 9pm, DSRamsey13 and 4 others like this.
  3. Nov 13, 2023 at 8:09 AM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    NextBase GW 522. Good 4K (do not expect reading license plates, but that is common among dashcams), using a quality 90 MB/sec microSD. I used it to record step-by-step of a truck rollover ... photo attached, zoomed in from original ... about 1/2 mile ahead of me. I just kept the video to show police that the driver has passed me at high speed and caused his own crash. Base uses glue-pad for windshield but camera can be removed from base without the power-cable attached. Best Buy carries them, $250.
    Just my $0.02.
    PS: This is your truck after yo stray into a dirt ditch ...
    PPS: had to finish the narrative, for those who wonder what the "puff" is in front of the sign ...
    Crom and allelopath[QUOTED][OP] like this.
  4. Nov 13, 2023 at 10:12 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I bought the splitter cable that goes from the Dash Cam to the back of the rearview mirror. My dash cam sits in the Go-Pro location (which I believe Toyota doesn't include anymore).
    Well worth it, instead of running a cable all around the windshield to the lower dash, using up one of the USB/cigarette lighter plugs.
    Sorry, don't remember the brand names...
    InfernoTacoCO and allelopath[OP] like this.
  5. Nov 13, 2023 at 10:30 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    My Garmin 45 is attached to the GoPro mount also. Works great and wires are out of sight.
    TacomaCZman and allelopath[OP] like this.
  6. Nov 13, 2023 at 10:33 AM
    TuffRuffDangerous
    TuffRuffDangerous Well-Known Member
    San Diego, CA
    2011 TRD Off Road 4x4 DCSB
    Salex glovebox/console organizers, Philips H4 MotoVision headlight bulbs, Optilux H10 Extreme Yellow XY foglight bulbs, csjumper2003 LED domelight & license plate bulbs
    Dongar Technologies is one brand I saw on the YouTubes.
    https://dongar.tech/
  7. Nov 13, 2023 at 10:44 AM
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    I currently have a N2-Pro dash cam. It was great for the first year or so, I absolutely LOVED the video quality (day and night) and all the features it had... especially the GPS speedometer. It records outside AND inside the cab at the same time. Now, the part that made me stop loving it and start hating it. The device has an internal battery, and the design makes it almost impossible for an average person to replace it since the whole unit had to be completely disassembled to get to the battery and then Sauder new battery wires to a circuit board. Since the battery has started dieing, the cam will not keep accurate date / time on it. It also loses (or fails to save) video files randomly.
    In short... they've got the software that makes dash cams great, they missed the mark big time on the hardware. I DO NOT recommend any Vantrue cams because they all have the same design flaw. I paid almost 300 bucks for (what I thought) was a quality dash cam and only got 2 years max of use from it. I'm currently looking at buying a Garmin dash cam soon, im hoping I have better luck with it since Garmin has been around a while in the auto accessories industry.
    allelopath[OP] likes this.
  8. Nov 13, 2023 at 11:22 AM
    TuffRuffDangerous
    San Diego, CA
    I was under the impression that GPS satellites contained atomic clocks and would send time/date info to GPS equipped devices. Maybe that feature wasn't utilized in your dashcam.
  9. Nov 14, 2023 at 1:10 AM
    RichochetRabbit
    First ... check that you are using a FAST microSD card ... class 10 that writes at 90 MB/sec. My NextBase GW522 will not even operate on slower than 45 MB/sec but I use a 90 MB/sec card anyway.
    Second ... check out the NextBase is my advice. Best Buy sells them off the shelf. The base it detaches from is glued to the windshield and the camera can be removed to get it out of sight or to make the windshield effectively flat. You can also add in-cab rear-look or out-the-rear-window rear-look extra camera.
    You have pictures taken through the windshield of a scene 1/2 mile in front of me and zoomed in. 4k recording is impressive.
    But you buy what you want.
    MudFlap[QUOTED] likes this.
  10. Nov 14, 2023 at 1:49 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Right now the best quality comes from a Starvis 2 chip. Look for products that have that. I’m going to be buying a Viofo A229 Plus (not the Pro, just the Plus) when Black Friday sales start next week for one of my other vehicles that doesn’t have a camera yet. Single channel best bang for buck is the Viofio A119 mini I think is the name.
    TacomaCZman likes this.
  11. Nov 14, 2023 at 3:49 AM
    InfernoTacoCO
    InfernoTacoCO Well-Known Member
    Hannah
    Denver, CO
    2017 Inferno Orange Toyota Tacoma TRD Offroad
    Westcott Design 0° Sliders, Falken Wildpeak AT3’s, OTT Tune, Interior/Exterior LED lighting, Raptor Lights, WeBoost 4G-M Signal Boost Amp, Trail Grid Pro Front/Rear Anytime Camera, OEM Tailgate Actuator & Wiring, 20% Ceramic Tint.
    Red Tiger F7N 4K camera, comes with a 1080p camera as well. Look them up on Amazon. If you pair two pf these kits up, you can put the 4k's front and rear, and both 1080p's on the sides for 360° of coverage. They have a parking kit to record while parked as well.
    You'll need an extra power port added in the rear. I run 256GB SDHC cards on both in my corolla.
  12. Nov 14, 2023 at 1:43 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I'll second Nextbase.
    I've had a GW322 for a couple years now and no trouble with it. Records excellent video during the day, and still very good at night. Has GPS speedometer and lots of other functions (one is a feature where it can automatically call for help through your cell phone if it detects a crash and you don't cancel the alert).
    Do you have the original (unzoomed) pictures of those? Looking at zoomed-in pics (w/o any reference to how far away it was) the blurring makes it not appear all that impressive.
  13. Nov 14, 2023 at 1:54 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I’ve been running a Garmin dash cam for a few years. It’s awesome. I have the adapter so it plugs into the back of my rear view mirror.
    I’d buy a Garmin dash cam again in a heartbeat.
  14. Nov 14, 2023 at 2:21 PM
    RichochetRabbit
    Original, first is a shot of the truck passing ... can ALMOST see the license plate but maybe not for a court of law. The second is with the truck just after drifting into the center ditch and moving across the freeway but quite far away. I think the fact the second image can be zoomed to "clear enough to tell the story" is pretty impressive.
    Screen Shot 2023-11-14 at 3.16.20 PM.png Screen Shot 2023-11-14 at 3.17.27 PM.png
    Crom likes this.
  15. Nov 14, 2023 at 2:28 PM
    RichochetRabbit
    When Garmin first marketed its dashcam I tried one. I returned for two reasons (below). They may have improved since, but I have not tried since I bought the GW522.
    > Startup screen spent too long on the license page. Fine on a GPS which is not needed for about 45 seconds, not good for a dashcam in my opinion.
    > The ONLY and AUTOMATIC collision sensing "sensitivity" was far too tight, and a 5 mile stretch of bad freeway registered 10 "accidents".
  16. Nov 14, 2023 at 2:39 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Oh interesting. Yeah I don’t have any of those problems. Mine doesn’t have a screen, it connects to your phone with the Garmin app which is really good and very easy to use.
  17. Nov 14, 2023 at 3:51 PM
    4x4junkie
    So Calif. (SFV)
    Appreciate the pics. :cool: That definitely looks zoomed in better than the same distance with my GW322 would.
    I've been contemplating getting a GW522 myself, and then moving my 322 over to another vehicle.
  18. Nov 14, 2023 at 3:56 PM
    wazepd
    wazepd Waze Map Editor
    NJ / NY
    2022 Tacoma TRD Off Road
    Commercial Pilot
    Explore options for always on recording with some constant 12v supply
    Been Using 2 Garmin Dash mini 2 with OBD port for now for ~2+ years and recorded every single thing that was important to save
  19. Nov 14, 2023 at 4:10 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Interesting thread.
    I bought the Blink 4th Gen System wire-free system on Prime Day Oct 11...love it!
    Now, I'm interested in a decent Dash Cam.
    Let's see more photos & testimonials!
  20. Dec 31, 2023 at 4:59 AM
    98 SNAKE EATER
    98 SNAKE EATER Active Member
    Rick
    97 FZJ80
    Lifted, Tired, Bumpered, Racked, Winched, etc.
    I currently have 3 different camera setups in my daily beater Sienna (companies send me dash cams for review)
    VANTRUE Nexus 5 (2 exterior views, 2 interior views)
    VANTRUE S1 Pro (2 exterior views)
    BlueSkySea B2W (2 exterior views)
    Just got rear ended by some lady yesterday, so here's footage from each camera so you can compare....
    https://www.youtube.com/watch?v=Z20eJ5gDxKQ
    https://www.youtube.com/watch?v=HPZdfwqhVak
    https://www.youtube.com/watch?v=G4ADJrjVxlI
    Crom and TacoTime55[QUOTED] like this.
