Dash cam options using the Go Pro Mount?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by justguth, Jul 17, 2016.
  1. Jul 17, 2016 at 8:14 PM
    justguth
    justguth [OP] We beefin??
    2016 White TRD OR DC 4x4
    I'm trying to find a dash cam that uses the existing go pro mount in the truck. I've searched the forum with no luck. I have a action "go pro" style camera, but I would like an actual dash cam for loop recording.
    Does anyone have anything good? There are tons on Amazon but none that look like they could use the mount in the truck. Help would be great....
    Thanks in advance.
    Nunya Bizness likes this.
  2. Jul 17, 2016 at 8:28 PM
    bcnu
    bcnu Active Member
    The Big Island, Hawaii
    2016 SR5 4x4 Access Cab / V-6 A/T Quicksand
    I'm not saying do't do it, but be aware that using the GoPro mount for anything on public roads may be illegal.
    As crazy at it may sound, Tacoma put the mount in an area of the windshield that many (probably most) states do not allow to be used for mounting anything. The idea behind the laws is that things mounted in that area could obstruct vision. Typically there are limited areas of the windshield on which items may be mounted, and then only certain types of items may be mounted. The top, center of the windshield (behind the rear view mirror) and lower left and lower right corners of the windshield are the most likely to be legal mounting areas. Here is a link to a site that has some info on GPS mounting, and those laws generally address other electronic devices: http://www.poi-factory.com/node/34521
    I guess Toyota put the GoPro mount where they did so the selfie-obsessed crowd could shoot videos of them and their passengers squealing while bashing around offroad, and not with any thought of actual utility.
    But, I have seen mounts that can be bought separately and which will work with the GoPro mount and many dash cams.
    Socal562, remgu2000 and justguth[OP] like this.
  3. Jul 17, 2016 at 9:37 PM
    SamChieftan
    SamChieftan Well-Known Member
    Dallas, Texas
    2016 TRD OR AUTO 4x4 Super White
    Interior LEDs, Truck Mat, Door sills
    I have a gopro Hero 3 on my mount, it does looping and the quality at 1080p is outstanding compared to some of the other cams on Amazon that other people I know have tried.
    As far as being legal, I use mine all the time ... because of the insane traffic in the dfw area in Texas.
    I think if you mount it in any place other than the mount there may be problems.
  4. Jul 17, 2016 at 10:42 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
  5. Jul 17, 2016 at 10:59 PM
    nilepoc
    nilepoc Active Member
    Craig
    16 TRD OR AC
    TRD rims, spacer leveling
    It would be pretty simple to adapt the mount for this camera to utilize the go pro mount. Mounting it way over there though would make it hard to lock any interesting clips you obtained.
    https://www.amazon.com/Rexing-Dashb...id=1468807163&sr=8-2&keywords=rexing+dash+cam
    I mounted mine behind the mirror and ran power to it from the under dash fuse block. You can see that thread in my profile history. I used double sided gorilla mounting tape.
  6. Jul 18, 2016 at 4:50 AM
    justguth
    I am afraid with this Texas heat that double sided tape would eventually fail. That's why I'm looking for a mount that will fit the GoPro clip on the windshield.
    FishnTx, sierra141 and shakerhood like this.
  7. Jul 18, 2016 at 5:00 AM
    qxrtz4321
    qxrtz4321 Well-Known Member
    Mitch
    Montana / Washington
    Texan here... I mounted my dashcam (that same Rexing pictured above) with 3M VHB tape after the OEM tape it came with failed. It hasn't budged an inch since then.
    fökai671 and nilepoc like this.
  8. Jul 18, 2016 at 5:22 AM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    Used a GoPro base & a transcend base combined into one. 15 mins of playing around with a Dremmel and good to go.
    Chris Miles, Socal562, gzilla and 5 others like this.
  9. Jul 18, 2016 at 5:45 AM
    nilepoc
    Craig
    16 TRD OR AC
    I am in NM. No failures yet.
    justguth[QUOTED][OP] likes this.
  10. Jul 18, 2016 at 7:12 AM
    Marc529
    Marc529 Well-Known Member
    I bought this Go pro knock off, made by Andoer http://www.ebay.com/itm/351780419002
    Great images for $43 + SD card
    Then I tapped the power leads for the rear view mirror for a sweet installation.
    SandTaco138, Hartman and justguth[OP] like this.
  11. Jul 19, 2016 at 4:49 PM
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    do a DIY
    TRD18 likes this.
  12. Jul 26, 2016 at 11:58 PM
    FlaccidMass
    FlaccidMass Well-Known Member
    Mitchell
    2016 White Taco Off Road
    None - yet... That's why I'm joining this fourm
    I may have misplaced the part that connects the GoPro to the windshield mount. Did that come with the truck or did it come with the GoPro? Or is it something i have to spend more money on to get?
  13. Jul 27, 2016 at 12:06 AM
    docsg
    docsg Well-Known Member
    South Alabama
    2020 White TRD OR SBDC
    Raptor 4" oval rails, OEM door sill protectors, totally debadged, OEM mud guards, OEM bed mat, OEM S/S tail pipe extension, BDT tailgate letters, Weather Tech sun screen.
    Comes with the GoPro...any model.
  14. Jul 27, 2016 at 12:09 AM
    FlaccidMass
    Mitchell
    I must have lost mine somewhere along the way. Do you happen to have a picture or link to the part that I am looking for? I have searched but they have more gadgets for GoPro's in my results than I know what to do with.
    Thanks for the help by the way.
  15. Jul 27, 2016 at 12:13 AM
    CaliforniaComa
    CaliforniaComa Well-Known Member
    Lee
    Bakersfield, Ca
    2016 Quicksand TRD Off-road 4x4
    Still to come
    I use my go pro sessions it's small and actually hides behind the rear view mirror...not actually behind it but the review mirror blocks it out enough where I forget it's there
  16. Aug 6, 2016 at 11:10 AM
    CodeTaco
    CodeTaco Well-Known Member
    HB, CA
    2008 Tacoma Access Cab 4x4 TRD
    Bilstein 5100s (f @ 1.75); 5100s rear; All Pro Expedition Springs; PowerStop slotted discs; Akebono ceramic pads; Wheeler's braided brake lines; Prodigy trailer-brake system; heavy duty towing set-up (for off-road trailer); WeatherTech mats (awesome); 5% Ceramic Tint; matching Snug Top (mid) with racks; Thule racks; dipped badges; 17" 2014 OEM 5-spoke 4-runner rims; 265/70/17 Bridgestone Desert Duelers (for now); Siriusxm radio; more on the want list...
    Can you by chance post a pic of your mount, brother?
  17. Aug 6, 2016 at 11:21 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    tacoguy88 likes this.
  18. Aug 6, 2016 at 11:34 AM
    Marc529
    Here is picture of the power connection to the rear view mirror. you can see the red and yellow wires that were tapped into the power leads from the mirror. The 12 to 5 volt adapter is tapped up. The adapter is a lighter plug to usb and I took it apart so it is smaller and soldered the 12v wires to it. Then just plug a short USB cable into it to the camera.
    WHIT4K3R and bcnu like this.
  19. Aug 6, 2016 at 12:20 PM
    CaliforniaComa
    Lee
    Bakersfield, Ca
    Still to come
    20160806_121534.jpg 20160806_121505.jpg 20160806_121349.jpg 20160806_121354.jpg
    There ya go hope it helps
  20. Aug 6, 2016 at 12:24 PM
    ExplorHer
    ExplorHer Question Authority
    Near Pittsburgh
    2016 4cyl, 5MT, 4x4, 2 seats, dents, & rust
    Does your tint show up in your shot?
    I have a small curved arm to get the Session past the tint.
