D Shackle & Recovery Questions
Discussion in 'Recovery' started by Wolftaco0503, Nov 6, 2016.
  1. Nov 6, 2016 at 12:00 PM
    Wolftaco0503
    Wolftaco0503 [OP] Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Are they all the same or what should I look for? I know most of them are 3/4". Recovery Straps should be rated to What? Thank you
  2. Nov 7, 2016 at 8:02 AM
    Wolftaco0503
    Adam
    Chicago
    So no one knows? Can anyone point me in the right direction or might know someone who knows?
  3. Nov 7, 2016 at 12:02 PM
    dlawrence529
    dlawrence529 Well-Known Member
    Maine
    2015 MGM Double Cab Long Bed
    In general you want the working load limit (WLL) to be greater than the weight of your truck. The breaking strength/ultimate capacity is usually 3 times the WLL. Read the fine print when you order things. Some are marketed by breaking strength and others are marketed by WLL. My double cab long bed has a curb weight of +/- 4300 lbs plus whatever I am carrying around.
    If you plan to bury your truck up to the axle in thick mud, you may want to buy things with a larger load capacity than someone who only believes they will slide down an embankment during a snowstorm. Below is what I carry in my truck. I don't know anything about snatch straps.
    https://www.amazon.com/gp/product/B013FLW8J6/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B012TYU5SQ/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
  4. Nov 7, 2016 at 12:09 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    This is an excellent source of info. and product. They also put out a really cool user guide. They are all about rigging. Crosby at www.thecrosbygroup.com
    Crom likes this.
  5. Nov 7, 2016 at 12:11 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
  6. Nov 7, 2016 at 1:30 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    When it comes to shackles, it's been my observation that it's generally accepted by the off-road community, that as long as the WLL is stamped into the forging it should be okay.
    For our sized trucks, it's quite common to use a 4-3/4 ton 3/4" screw pin bow shackle with a 7/8" pin.
    I take it a step further and make sure that the manufacturer is stamped on the shackle as well. It doubles the cost of the shackle over the no-name chinese stuff, but in my opinion, it's worth it to me.
    I'm currently using some Titan Marine branded shackles.
    Crosby is probably one of the best, Campbell is also good, both made in U.S.A.
    Regarding straps:
    Nylon straps will stretch, and are used for vehicle recovery.
    Polyester straps are for tow applications and will not stretch.
    When you go shopping, make sure you know what the strap is made of, because lots of times, the manufacturers are are bananas, and label shit wrong.
  7. Nov 7, 2016 at 1:39 PM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    When you do end up using your strap, place a blanket, jacket, or floormat draped over it roughly centered between you and whatever you're pulling. In the event that something breaks, it will pull the strap down...hopefully redirecting whatever rocket is now heading your (or their) way.
    I keep a smittybilt 3"x30' in my truck.
    SpeedoJosh likes this.
  8. Nov 7, 2016 at 1:46 PM
    Wolftaco0503
    Adam
    Chicago
    Yea I learned that Thank you
  9. Nov 7, 2016 at 1:55 PM
    Wolftaco0503
    Adam
    Chicago
    Could you just attach a D-Ring or D-Shackle to your Tow Hitch?
  10. Nov 7, 2016 at 1:58 PM
    Crom
    Nick
    San Diego, CA
    Millions
    You can with a shackle receiver adapter.
    I have one I need to list in the market place. (just got a new rear end for my truck and no longer need it)
    Hamer95USA and xxTacocaTxx like this.
  11. Nov 7, 2016 at 2:11 PM
    dlawrence529
    Maine
    A tree-saver strap and a Hi-Lift are nice to have too. You can lift yourself up to place wood under the tires or use it to winch yourself out in a pinch.
    I agree with everyone else... Crosby products are great. We use Crosby products for all our rigging at work. I've owned generic shackles from Amazon, Smittybilt shackles, and Crosby shackles. The generic shackles from Amazon look skinnier and just feel cheaper than the others, but I've never had any of them break.
  12. Nov 7, 2016 at 10:06 PM
    01 dhrracer
    Still Shopping
    I will add in most cases you get what you pay for. But in the case of recovery and saftey the dollar savings with no name stuff is not worth it. Buy the best you can because without the gear the cost of paying for the help to come out and save your ass will make the cost of high quality gear pocket change. Or you can just be that one.
    RedDemolisher likes this.
  13. Jan 13, 2017 at 9:18 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    RogueTRD likes this.
  14. Jan 20, 2017 at 5:57 PM
    tpotnoc
    tpotnoc Sit on my face
    Bellingham, WA
    15 2.7 DCSB PR
    I'd like to keep the d-ring on the hitch on the back. Would antiseize on the threads help prevent it from being a PITA later on when I need its?
  15. Jan 20, 2017 at 6:08 PM
    rkarabao
    rkarabao Well-Known Member
    2013 TRD Tacoma
    General rule is to hand tighten the shackle then back it out 1/2 turn keeps it from seizing on you.
  16. Jan 20, 2017 at 6:10 PM
    tpotnoc
    Bellingham, WA
    15 2.7 DCSB PR
    Then I'd worry about it backing out completely and losing it while driving. No?
  17. Jan 21, 2017 at 4:06 AM
    dlawrence529
    Maine
    At work we put rebar tie wire through the eye of the shackle pin and loosely tie it to the curved part of the shackle. This just keeps the shackle pin from rotating and backing out. The tie wire will rust and look like shit pretty quickly. A zip tie might do the trick. This a similar picture to what we do at work
    http://s66.photobucket.com/user/OffRoadPhoto/media/shakle2.jpg.html
    ShemRahBuck likes this.
  18. Jan 21, 2017 at 10:18 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Slip a screwdriver through the hole in pin, crank it down tight. Stops casual theft.
    If recovering, loosen half turn before pulling.
    tpotnoc and rkarabao like this.
  19. Jan 21, 2017 at 11:55 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Hand tighten to snug - back off 1/2 a turn and throw a ziptie through the pin hole and around the shackle. I've had mine like this for the whole summer - its too hard to for any person to snap the zip tie trying to steal it but light enough that my knife cuts it off when I need to remove it.
    Anti-seize will help but the friction between the shackle and the mount will wear it away and cause it to rust, I just disconnect mine and leave it in the truck now. After one winter with salt/sand and needing to tug my friend out of a ditch having an easy to use shackle without fighting it is key.
    Snatch Straps are mint for tugging someone out, it stretches and is better for pulling someone out of a ditch. Tow straps don't stretch and are used for as they are called - towing. Grab a snatch strap and pull someone out, then pull them out with a tow strap and you'll understand what I'm saying.
  20. Jan 21, 2017 at 12:06 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Just use a black zip tie (white and some other colors aren't UV stable) to keep the pin from backing out. Leave the tie loose so it's easy to get behind with a knife or pliers. There isn't a need to cinch it down tight. A few turns using stainless or monel tie wire will work too.
    tpotnoc[QUOTED] likes this.
