D-rings instead of washer...truck bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MemphisTaco08, Dec 20, 2021.
  1. Dec 20, 2021 at 1:34 PM
    MemphisTaco08
    MemphisTaco08 [OP] Well-Known Member
    Brian
    Memphis, TN
    07 TRD-SPORT 4x4
    3/1 lift 33in tires Overland Yakima system with Yakima Skyrise HD2
    Hey folks,
    Needing a few extras tie-down spots. Would prefer not to drill if possible. Looks like I could replace the washers in truck bed with needed d-rings, but a buddy cautioned me on messing with truck bed.
    Has anyone else replaced washers with drings? Any issues/concerns with doing so?
    Thanks!
  2. Dec 20, 2021 at 1:37 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    MemphisTaco08[OP] likes this.
  3. Dec 20, 2021 at 2:32 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Yep under every bed bolt, no issues
    Just sucks removing bolts
  4. Dec 20, 2021 at 4:13 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I really wish I could find some in stainless steel. My D rings are constantly rusting. If anyone has found one that would fit, I'd like to know where it was found. My past searches haven't turned up much.
    SR-71A and MemphisTaco08[OP] like this.
  5. Dec 20, 2021 at 4:14 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Dodge Sprinter D Rings - do a search. super cheap, BEEF, folding, and easily installed. def one of the most used add ons on my truck in the bed.
  6. Dec 20, 2021 at 4:15 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Did you try a boat shop? West Marine?
  7. Dec 20, 2021 at 4:18 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I know you said you'd prefer not to drill, but these were totally worth drilling through the bed for!
    Front: Custom front D-Rings.
    REAR: At The Helm Fab Bed Stiffeners
  8. Dec 20, 2021 at 4:18 PM
    adriancast
    adriancast Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
  9. Dec 20, 2021 at 6:14 PM
    MemphisTaco08
    Brian
    Memphis, TN
    07 TRD-SPORT 4x4
    Looks pretty good up there actually. Did you use a backing plate there? Any metal to drill through or just plastic?
  10. Dec 20, 2021 at 6:15 PM
    MemphisTaco08
    Brian
    Memphis, TN
    07 TRD-SPORT 4x4
  11. Dec 20, 2021 at 6:28 PM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    these are the ones I use too.
  12. Dec 20, 2021 at 6:31 PM
    williams63
    chili
    nh
    2011 dblcb
    Old pic
  13. Dec 20, 2021 at 6:45 PM
    adriancast
    Adrian
    Ontario, Ca
    yes goes directly into the frame. You don’t want to drill in the plastic bed. It’s very weak and easily crack.
  14. Dec 20, 2021 at 9:04 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
  15. Dec 21, 2021 at 2:42 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    You need 6 OEM bed bolts and the correct size Torx bit for a 1/2" breaker bar and good luck as if an 07 those are rusted into the frame mounts.
    Many posts on ways to remove so read those. Beer and a few choice words are required.
  16. Dec 21, 2021 at 5:19 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    I did the Dodge D-Rings back in 2014... Still look great (says guy with canopy)
    Island Cruiser likes this.
  17. Dec 21, 2021 at 5:34 AM
    No Shoes Nation
    Before you try and turn the bed bolts for removal, get under the bed and spray the tips of the bolts with PB Blaster or similar, do this for a day or so prior to bolt removal.
  18. Dec 21, 2021 at 7:21 AM
    YF_Ryan
    Kent, WA
    I purchased 4 of the below plates. Two for the D-rings to be welded on (random set of 8 purchased on Amazon) and two for backing plates. I placed them relatively close to the corners of the bed for added strength. And of course grade 8 hardware.
    https://www.ruffstuffspecialties.com/R2072.html
    My Camper hasn't fallen out yet! I figure if it can handle this, you wouldn't have any issue at all, lol.
  19. Dec 21, 2021 at 8:58 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    I used my 1/2" impact gun. made it much easier. Did struggle alittle... would hate to do by hand.
  20. Dec 21, 2021 at 10:57 AM
    Musubi3
    Big Island
    I've tried there and Google searching it out elsewhere. What I've been able to find is small SS D ring tie downs (similar to this mod and existing), where the bed bolt would be too large for the given hole or even if I drilled it out.
    On the plus side, replacing my reg. steel D rings allows me to reapply the the anti-seize to the bed bed bolts. I hear some guys have a tough time getting them out.
