Cylinders 2,4, and 6 misfiring after rebuild
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5000fingers, Jul 4, 2018.
  1. Jul 4, 2018 at 4:06 PM
    5000fingers
    5000fingers [OP] Well-Known Member
    Bruce
    Bay Area, CA
    '95 Tacoma, 6 cyl.
    I just put my engine back together after getting my cylinder heads rebuilt, and finally figured out my bonehead mistake that led to a no fuel condition. After fixing that and starting it up again, it's running rough, and I'm getting the general misfire code (P0300), plus the specific misfire codes (P0302/P0304/P0306) for all three cylinders on the driver's side valve head. And there are louder cam-like noises coming from that side as well.
    The only things that I can think of that would be causing this are the cam sprockets being off a tooth, or maybe the timing belt. But those are simple, easy things that I know I was very careful with when I put the engine back together. What else might be causing it?
  2. Jul 4, 2018 at 4:55 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Are you sure the injectors are plugged in and spark plugs haven't been closed somehow? Also plug wires from mother coils plugged in well?
    This sounds like an overlook somehow from assembly. Oh and firing order correct to wires?
  3. Jul 4, 2018 at 5:16 PM
    5000fingers
    Bruce
    Bay Area, CA
    '95 Tacoma, 6 cyl.
    I was pretty careful, but I'll double check.
    Yes, that is my assumption. I'm just hoping it wasn't anything with the camshafts or timing belt. It would be hard to mess those up, though.
    I'll triple check that one. But I can't imagine that would result in all three cylinders on the driver's side throwing codes.
  4. Jul 4, 2018 at 6:01 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    If they all 3 go to the wrong cylinder. I would think at least 1 wouldn't fit in the wrong position though.
    It's just stuff to look at and get you double checking EVERY connection.
  5. Jul 4, 2018 at 6:02 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Were the plugs in the head while it was installed?
    Maybe sat on something that closed the gaps?
    EDIT: From personnel experience, are there rags in the cylinders?
    TacoHank1998 likes this.
  6. Jul 4, 2018 at 7:45 PM
    TacoHank1998
    TacoHank1998 Well-Known Member
    Will
    Panama City, FL
    1998 Green Tacoma Base
    I see I'm not the only one to do something like this...
    Jakuku Pahwheenis likes this.
  7. May 22, 2023 at 2:15 PM
    FreeWilly623
    FreeWilly623 New Member
    2001 Tacoma TRD
    Just solved this issue on my 2001 Tacoma 3.4. My exhaust camshaft timing was off 180 degrees after I replaced head gasket. Both the intake and exhaust camshafts have a single dot alignment mark and a double dot alignment mark. I did not know this… So I aligned intake shaft single dot with exhaust double dot on driver side leading to misfires on 2, 4, 6. Why there are two alignment marks I do not know yet I still need to do some reading. Hopefully this saves someone a headache.
    kylehorvath likes this.
  8. May 22, 2023 at 3:59 PM
    TacoHank1998
    Will
    Panama City, FL
    Wow...
    treyus30 and Squirt like this.
  9. May 22, 2023 at 4:05 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can
    Holy back from the dead batman :eek:
  10. May 22, 2023 at 4:33 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    lmao that's been all day today
    Squirt and TacoHank1998[QUOTED] like this.
  11. May 22, 2023 at 4:36 PM
    TacoHank1998
    Will
    Panama City, FL
    Sad part is... I saw the date and I know I was legendary drunk that night. So how I even posted with proper English is beyond me.
    Squirt likes this.
  12. May 22, 2023 at 6:12 PM
    tkos
    tkos Well-Known Member
    Tommy
    Orange County, CA
    1996 Tacoma 4x4 3.4L
    Dang, cam shaft out of alignment was what i thought too
