Cylinder misfire, rusty spark plug (with picture). Diagnosis?
Discussion in '1st Gen. Tacomas (1995-2004)' started by easypz, Nov 14, 2015.
  1. Nov 14, 2015 at 2:06 PM
    easypz
    easypz [OP] Member
    Engine: 5VZ
    Guys, I pulled a code indicating cylinder #3 misfire. I figure I would replace all spark plugs since I just bought this truck with 165k miles. When I get to cylinder #3, it looks like the threads are rusted. All the other plugs have shiny threads. See the image to compare. The left spark plug is from cylinder #3. Also note the discolored ceramic below the electrode vs the white ceramic on the other. What do you guys think? Should I be more concerned about other issues or should I replace the plugs and move on?
    Thanks
  2. Nov 14, 2015 at 3:40 PM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    You may be getting water into the cylinder from possibly a bad gasket, a broken water jacket, etc. Or it could be as easy as a plug that was loose and not tightened down all the way allowing exterior moisture to seep down the threads
  3. Nov 14, 2015 at 3:45 PM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    do a compression test.those trucks are known for ceacked rxhaust manifolds.If left go will damage exhaust valve seat,(ask me how i know)
