CV Boot, What's Best?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Millerfish, Jan 12, 2020.
  1. Jan 12, 2020 at 5:22 PM
    Millerfish
    Millerfish [OP] Well-Known Member
    Southern Ca
    14 DC SB OR
    So i just noticed the passenger outer boot is blown. What's the best replacement part? With a 2.5 lift the factory boot lasted about 30K total miles 35K on a 2014. The inner and driver side boots look fine. So...
    Does that seem like proper boot life?
    Thanks
  2. Jan 12, 2020 at 5:26 PM
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    I tried SDHQ kits one time and didn't like that they lasted 1 year before splitting. They were soft and definitely didn't like the fins rubbing. With probably 50k miles on various lifts, I've redone the boots on my truck 3 times. It's a vicious circle and hopefully someone has some better ideas. I've gone back to OE boots for now.
  3. Jan 12, 2020 at 5:27 PM
    hualampeter
    hualampeter Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
  4. Jan 12, 2020 at 5:28 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    I had the same experience with SDHQ boots, my next set will be the cheaper of the two between OEM and SDHQ as they both seem to have similar life spans.
  5. Jan 12, 2020 at 5:28 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    Both of mine went out after a lift. I replace them with cvj axles and they both went out after 11 months. A lot of people on here will recommend them but I dont. I also paid extra for their “high angle” red boots.
    https://sdhqoffroad.com/products/sdhq-built-direct-replacement-cv-boot-kits
    I’m using the boots from sdhq at the moment. I don’t drive as much as I use to but these have been on my truck the last 3 years.
  6. Jan 13, 2020 at 6:37 AM
    Millerfish
    Southern Ca
    14 DC SB OR
    If you were to just replace the entire axle, what would you buy?
    Autozone/o'Reilly new $90
    Toyota new $320
    Napa with heavy duty boot $118
    Or ???
  7. Jan 13, 2020 at 6:51 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    With past experience on earlier Toyotas, I would only buy OEM Toyota axles, especially if you're lifted. The parts store stuff is much weaker, always gave me weird vibrations in my lifted applications at highway speeds and it was my experience that the boots have even shorter lifespans than OEM. Sure...it's a lifetime guarantee but you'll be replacing them every year (at least I did. To the point where the guy at Napa was curious if I was putting them on other trucks. "Nope" I told him. "If the boots were worth a $#!@ I wouldn't have to replace them so often")
    IMHO the best/cheapest thing to do, though, is just replace the boots with OEM Toyota boots when the boot tears before too much dirt makes it into the CV.
    jeff b likes this.
  8. Jan 13, 2020 at 9:05 AM
    westport toyota
    westport toyota Well-Known Member
    I rebuilt my whole lift and did wheel bearings and cv boots. I went with the red cvj boots. They look good so far. fins are not touching and that's the key I think. I hope they last that whole operation was a huge pain. also if you have to raise your lift because your tires are rubbing. That may be too much cv angle. If you get your alignment guy to increase the caster I think? It moves the wheels forward and the will clear. For years I had my lift way too high. now its not so stiff. Running swayaway2.5
  9. Jan 13, 2020 at 10:12 AM
    Millerfish
    Southern Ca
    14 DC SB OR
    So a local, very reputable 4WD shop quoted $325 to replace boots and rebuild axle with quality parts. Says he does a lot of them. Seems reasonable to me, what say y'all?
  10. Jan 13, 2020 at 10:21 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    ouch. The OEM boot kit from the dealership shouldnt be more than $40. To "rebuild" it, its not that difficult, although you do need a special boot plier and 2 breaker bars. The rebuild consists of cleaning the old grease out, and putting the new grease in. Then clamp, and youre good to go.
    here are some instructions from @mjp2
    This was also very helpful for me:
    https://adventuretaco.com/how-to-rebooting-a-tacoma-cv-axle/
  11. Jan 13, 2020 at 11:31 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    You can buy an entire axle assembly for $67 plus shipping without a core charge from RockAuto. CARDONE 665235HD
    There are even less expensive options available too, but this is the one that I would buy. Then you can rebuild the factory one as your leisure and keep it for a spare.
    Truc577 likes this.
  12. Jan 13, 2020 at 11:46 AM
    hoarder23
    Shay
    NJ
    Scratches
    A new OEM one is the same price. A CVJ Reman is cheaper. Price seems real high.
  13. Jan 13, 2020 at 12:04 PM
    Tacomataco12
    Tacomataco12 Well-Known Member
    I have this cardone the HD one 50,000 miles with lift no problems
    mjp2[QUOTED] likes this.
  14. Jan 13, 2020 at 1:19 PM
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Crikeymike likes this.
  15. Jan 13, 2020 at 2:02 PM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    JeffBoyardee[QUOTED] likes this.
  16. Jan 13, 2020 at 2:57 PM
    Millerfish
    Southern Ca
    14 DC SB OR
    I think having the shop rebuild the OEM axle with OEM parts for $325 is a deal. The dealer wants $750 per axle just for the boots.
  17. Jan 13, 2020 at 3:04 PM
    hoarder23
    Shay
    NJ
    Scratches
  18. Jan 13, 2020 at 3:35 PM
    Millerfish
    Southern Ca
    14 DC SB OR
  19. Jan 13, 2020 at 3:45 PM
    Millerfish
    Southern Ca
    14 DC SB OR
    FWIW The cardone axles are made in China. They may be just fine, but the chances of getting a defective one is a lot more likely..
  20. Jan 13, 2020 at 3:46 PM
    hoarder23
    Shay
    NJ
    Scratches
    You would be getting an axle that has 35k miles of wear and new boots/grease. That wear might be zero if no contaminates got in or it might be trashed and unserviceable. If you ran it for 5k slinging grease that thing might be bone dry and metal on metal.
    Changing a CV is not a difficult job if you have the space and tools to do it, the odd ones can be rented from your local auto parts store. If you wheel it's a good skill to have in your back pocket.
    But if you aren't able to change it yourself $325 isn't an outrageous price to remove/rebuild/reinstall a CV axle.
