cv boot clamp...hose clamp?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DIRT YOTA, Jun 22, 2010.
  1. Jun 22, 2010 at 8:24 PM
    DIRT YOTA
    DIRT YOTA [OP] Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Hello all. So wasn't sure where this should go, so I put it here. I'm missing a cv boot clamp on one of the boots. I bought a hose clamp to replace it. Any thoughts or better solutions...the screw part that tightens the clamp is a lil heavy. So at speed since it will be off weight or kinda out of balance, will that cause anything. Hum or vibrations etc. I don't think so but just checking. Thanks in advance.
  2. Jun 22, 2010 at 8:47 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Use a heavy duty zip tie!
  3. Jun 22, 2010 at 11:33 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How bad is it? Are you loosing grease?
    You can put a temporary fix on it now - but just make sure you keep an eye on it. Once those boots come loose, you lose grease, and water/dirt get inside which can cause problems later on. Hopefully you caught it soon enough and you didn't lose too much grease.
  4. Jun 23, 2010 at 12:50 AM
    DIRT YOTA
    Cory
    Camarillo, CA
    Well it has been off for a bit now. But I have been watching it and very little to no grease. But I havnt been off-road since I noticed, not much water to worry about here in Cali. So hoping I caught it early enough. Fixed one on a Chevy I had like this and thing lasted till I sold her.
  5. Jun 23, 2010 at 5:07 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    a band clamp is what you want to use. ...it shouldn't cause any vibrations.
  6. Jun 23, 2010 at 8:43 AM
    DIRT YOTA
    Cory
    Camarillo, CA
    Band clamp huh.....is that like the original? Where can get those, auto parts, hardware stores, or the stealer ship.....
  7. Jun 23, 2010 at 8:48 AM
    DIRT YOTA
    Cory
    Camarillo, CA
    Just googled band clamp, its same thing I got. Aka hose clamp or worm drive clamp.
  8. Jun 23, 2010 at 9:07 AM
    Camdan
    Camdan Well-Known Member
    Cameron
    Mississippi
    '10 dbl cab SR5 4x4
    stock
    Same thing happened to me, but i ended up losing a good amount of grease. Luckily it was still under warranty and the dealership ended up replacing the hole axle assy. so I would watch out. I do believe that your clamp will work fine though.
  9. Jun 23, 2010 at 9:15 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
  10. Jun 23, 2010 at 5:50 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    ^yeah thats a good find.
    so I had time to kill, went by the stealership. The oe clamp is $7 and change. I ask the dude if it is able to be put on without any disassembly with just the tool...he said oh yeah no problem just the tool is all you need. Hmmm is this true I thought the oe clamps required you to disassemble because the clamp doesnt open up to get around the shaft.
  11. Jun 23, 2010 at 11:14 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    my f-ing hose clamp is to wide, pissed. bought two cv replacement clamps from autozone that claims just use pliers then flip a little clam with a screwdriver. Piece of shat! broke the first one and second just would not get tight enough. Well we will see tomorrow what the dealer wants to charge to put the $7 clamp on.....or I'm head to the marine supply thats near by for a clamp like shown up in that tj fourm. Hope this info helps someone else down the road.
    anyone one know off hand what a whole new axle assembly cost.
  12. Jun 24, 2010 at 6:03 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    i think you can get one from autozone for around $50. ...it makes it very tempting to replace the whole shaft with them being so cheap.
  13. Jun 24, 2010 at 6:22 AM
    Paul's TRD
    Paul's TRD I'm Not Your F***ing Brother
    TX
    2011 Z71 4x4 5.3L V8
    suprisingly they are pretty cheap. We just replaced one on my buddy's Nissan Murano. was pretty easy and it was the first time we ever attempted to replace an axle.
  14. Jun 24, 2010 at 12:19 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Nice man, just checked the autozone site....Cardon Reman complete half shafts for $79 with a core charge of $100...$179 aint bad for brand new with limited lifetime warranty! They also had Duralast ones only $70. Anyone try either of these. Off to find a clamp for temporary fix(dealership said today no say tomorrow) untill I get a lil spare cash then I might by two new half shafts. Which will allow me to have two spares, afterbI fix the clamp on the other. Toyota wants $1000 for one haha or $300 to replace one clamp/boot/grease or $400 for both. What a rip.....
  15. Jun 24, 2010 at 10:39 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    So I went by west marine a boat supply store, they hose clamps that are the perfect width and the edge is kinda rolled not sharp like normal clamps. Worked great.
  16. Jun 25, 2010 at 6:00 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    how do the actual boots look? ...are the fins rubbing on the differential side boot? mine split so i just installed a new shaft. ..but the new shaft's boots are touching waaaay more than they were on the original shaft. ..i may take the band off and see if i can stretch the boot a bit to separate the fins.
  17. Jun 25, 2010 at 6:19 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    After replacing several boots on an NSX axle, I will never go back to buying whole new axles when the boot goes out! Its that easy...
    Honestly, I would go by honda and ask for their CV boot straps, the old style and DIY.
  18. Mar 10, 2011 at 7:31 PM
    HERHEATER
    HERHEATER New Member
    Chip
    ct
    01 sr5
    2 1/2 lift 31" tires
    Message is for SENIOR TACOROJO,
    Cory,which clamp from west marine did you use?
    thanks for the help,
    herheater
  19. Mar 10, 2011 at 7:59 PM
    marchand8
    marchand8 Member
    phil
    St Amant, Louisiana
    10 trd sport
    3'' suspension connection lift, brute force intake
    If you get the right kind of clamp (oem) then yea youll have to take the axle back off to put it on. make sure you have the right pliers to clamp it or you be fighting it for a little while and theres a chance that grease may seep out.
  20. Mar 10, 2011 at 10:22 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Funny you should ask, I will be picking another up in the next few days. The same exact one but on the other axle is leaking a bit. I'll post a pic and size. The one I already did is holding up great.
