CV axles keep breaking and I don’t know how to mitigate it. I have a 3.5 inch suspension lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jordanlacelle, Oct 31, 2023.
  1. Oct 31, 2023 at 4:09 PM
    Jordanlacelle
    Jordanlacelle [OP] Member
    Jordan
    2013 magnetic grey trd off road
    3.5 inch rough country suspension lift. 33 inch BF Goodrich all terrain tires. 17 inch rims
    Cv axles keep breaking on my 2013 Tacoma. I had a 3.5 inch suspension lift installed about 2 years ago with 33 inch tires. Trying to see if there is a way to mitigate this issue. Thanks
  2. Oct 31, 2023 at 4:13 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Lower the lift. 3" is pushing it, over 3" and this is what will happen.
    If you really want more than 3" lift on these, you need to either get a 2wd or do a dropbracket lift
    Or sas
    drizzoh, SH10151, Mully and 1 other person like this.
  3. Oct 31, 2023 at 4:15 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Breaking how? Snapping? Torn boots? Oem shafts?
    SR-71A and Mully like this.
  4. Oct 31, 2023 at 4:18 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    2 inch lift max to be on the safe side.Get the rest of the lift with bigger diameter tires.
    Mully likes this.
  5. Oct 31, 2023 at 4:19 PM
    Jordanlacelle
    Jordan
    Torn boots.
  6. Oct 31, 2023 at 4:21 PM
    Jordanlacelle
    Jordan
  7. Oct 31, 2023 at 4:28 PM
    Jordanlacelle
    Jordan
    Could I still run 33” tires with a 2” lift?
  8. Oct 31, 2023 at 4:32 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Either get to below 3" of lift or look into the boot slide mod. Either of which still run the risk of eventually tearing boots. Nature of the beast once you leave stock form.
    In simple terms...yes, wheel offset and how much you're willing to cut play a factor.
  9. Oct 31, 2023 at 4:48 PM
    Jordanlacelle
    Jordan
    So this is the suspension lift kit that was installed. To lower it down to a 2inch lift do i only need to change the size of the struts or what else would need to be changed?
  10. Oct 31, 2023 at 4:50 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Just replace the boots and do the boot-slide mod while you're at it.
    I am at 2.7" lift and ran the boot slide mod for for 3 years with no issues.
  11. Oct 31, 2023 at 5:26 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    CVJ axles with boot slide mod.
  12. Oct 31, 2023 at 5:28 PM
    Clearwater Bill
    Billy
    Largo Florida
    You can run 33's with no lift if you pick the right wheel and tire.
    Nate88cool and EubeenHadd like this.
  13. Oct 31, 2023 at 8:38 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Lower the preload on your coilovers until you fail to clear the fenders, then raise it slightly.
    No reason for excessive lift with just 33's.
    winkel likes this.
  14. Oct 31, 2023 at 8:50 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Yep. I run 315s with 1.75" of lift.
    stickyTaco likes this.
  15. Oct 31, 2023 at 8:55 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    that’s probably going to cost like 5x that cheap rough country lift kit.
    drizzoh and Jordanlacelle[OP] like this.
  16. Oct 31, 2023 at 9:16 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    I run 33s and a no inch lift...albeit 255s
  17. Oct 31, 2023 at 9:19 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Lower the front, trim, regear, bigger tires.
    Works great for my pile of shit.
    4xThad, winkel, OffroadToy and 3 others like this.
  18. Oct 31, 2023 at 10:02 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Haven't measured after adding weight but I'm probably about 1" of lift at this point with tires that measure to 33.2". Wheels are 16x8 0 offset. After a cab mount chop and some reshaping/trimming of fender liner I still rub a bit when stuffed on the fender flare at the top of the wheel well.
    Unless you're running skinny 33's like 255's you will probably need to do some trimming but you can run 33s on a stock height truck once you've opened up the wheel well enough.
    4xThad and Mully like this.
  19. Nov 1, 2023 at 4:45 AM
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    Have you tried taking the lift out?
  20. Nov 1, 2023 at 4:50 AM
    TegoTaco
    Ontario, Canada
    I’m at 3.5” of lift right now, both my CV’s have ripped open but it’s been a long time coming anyways lol!
