CV axle won't come out
Discussion in '1st Gen. Tacomas (1995-2004)' started by KlitKlapper, Jul 4, 2019.
  1. Jul 4, 2019 at 4:10 PM
    KlitKlapper
    KlitKlapper [OP] Member
    Black 2001 Toyota Tacoma, 2.7L, 4x4, Stepside Bed
    2.5 lift
    My cv axel will not come out by any means. There’s no pin holding it in. It’s just that little clip at the end of the shaft. I’ve Pryed on it for 20 minuets and I’ve even grabbed a hold of my shock and used my feet to push on the key bar. I just isntalled it 2 weeks ago and forgot to put the axel seal in it. Any idea on why it won’t come out???
  2. Jul 4, 2019 at 4:17 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Make a puller. Loop a chain around it, on the opposite end put the handle of a sledge hammer, give the sledge a swing and you should be able to pop out the CV from the Duffy.
    Keep out of the line if fire, when it pops, it might keep coming at you. Ask me how I kniw.:)
  3. Jul 5, 2019 at 12:40 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I tried this idea I pulled the CV axle apart!!
    I found a pry bar tapping the CV axle out of the housing pops them out it worked for me
    CS_AR and KlitKlapper[OP] like this.
  4. Jul 10, 2019 at 3:21 PM
    KlitKlapper
    2.5 lift
    That’s what I ended up doing. I was so mad at myself for not thinking of it sooner
  5. Jul 11, 2019 at 7:39 AM
    Glamisman
    Glamisman Well-Known Member
    the spring clip that retains the axle in the diff has an open end and this has to point down to allow it to compress "easier"... how do you know it is in the down position when the axle is installed, you dont, you have to pry on it a little and if it doesnt pop, rotate the axle a little and try again and again untill it pops out.
    underaroof likes this.
  6. Jul 11, 2019 at 8:39 AM
    UtahTacoma02
    UtahTacoma02 Well-Known Member
    Dave
    SLC
    02 Tacoma Double cab TRD Limited
    ARB front bumper, Old Man Emu suspension, on board air compressor, on board hot water converter, cb radio, safari snorkel, warn 8K lb. winch, AP rock slidders/rear bumper, gray wire mod
    In the future if you have oem cv's these notches can be used to tap on with a large screw driver or crow bar to break loose the clip. download.jpg
  7. Jul 11, 2019 at 8:59 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Pry on it with 2 pry bars at the same time on opposite sides. If you only use 1 you’re just side loading it in the diff and it’ll never pop out.
  8. Jul 11, 2019 at 9:25 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Damn, that sucks. time to sell it. :devil:
  9. Jul 11, 2019 at 9:29 PM
    Wulf
    Wulf no brain just damage
    rock raisin
  10. Jul 12, 2019 at 12:59 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
