Cv axle seal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Idahotacoma, Apr 13, 2016.
  1. Apr 13, 2016 at 8:28 PM
    Idahotacoma
    Idahotacoma [OP] Member
    Justin
    2007 toyota tacoma
    Light bar, aftermarket wheels, leveling kit, brake light bar
    Hey guys I am new to this sight and I figured this would be the best place to ask seeing as most of the things I look up I end up finding on this site. Now I was wondering if you guys could help me i have a 2007 4x4 tacoma and see i recently was under my truck to change the oil pan and before I screwed with the oil pan or anything at all (it was not leaking) I looked over and I noticed some fluid that had pooled up on the bottom of part of my front axle. More specifically the part that is inboard of the cv shaft. So I kept an eye on it and I noticed I was getting a couple drops a day in my driveway from it so I was wondering if you guys could tell me what might be the problem in there or even what makes up that part? I was researching online and couldn't find anything so before I go in and tear into it and take the cv shaft and everything out to try to find out I was wondering if maybe you guys could tell me anything before hand. My best guess would be that it is some type of rubber of ring or seal. So if anyone has had this problem or anything I would sure love to know. Thank you guys in advance hope the pictures somewhat help I'm no professional photographer. Sorry if I didn't explain it very well if you have questions I can definetly try to explain! Thanks again 20160412_185811.jpg 20160412_185824.jpg 20160412_185830.jpg 20160412_185847.jpg 20160412_185852.jpg 20160412_185859.jpg 20160412_185914.jpg 20160412_185928.jpg
  2. Apr 13, 2016 at 9:05 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Just need to replace the seal, OEM Part number 9031147013:)
    Nv90, mpm, PSU Taco85 and 1 other person like this.
  3. Apr 14, 2016 at 2:21 AM
    Idahotacoma
    Justin
    2007 toyota tacoma
    Thank you very much! Appreciate it when you took everything off did you have a lot of differential fluid leak out and did you drain and refill it?
  4. Apr 14, 2016 at 2:47 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    You want to drain the diff. A little more oil may come out when you pull the seal so have a catch pan ready. That is a pic of my seal and I may have driven it too deep :)facepalm:). You can use a small drift or punch to carefully drive it in, working around slowly, just be careful to set it even.
    AaronArf likes this.
  5. Apr 18, 2016 at 6:27 PM
    Idahotacoma
    Justin
    2007 toyota tacoma
    So I have it all ripped apart and the old seal out. How in the Holy hell did you guys drive the new one in evenly with out damaging the inner rubber portion?? I'm really stuck on it is there a special tool or anything
  6. Apr 18, 2016 at 7:01 PM
    ajohnson
    Andy
    Charlotte, NC
    Carefully. I used a small punch working my way around it slowly. But the best way would be find a piece of PVC or ABS tube that fits over that dust lip.
  7. Apr 18, 2016 at 7:12 PM
    Idahotacoma
    Justin
    2007 toyota tacoma
    This is the seal I got from that part number is looks a little different from the one that,come off but is the exact same size and everything. The outside on this one is metal as where the old on is part rubber on the outside. I just wanna make sure this looks right to you guys. I tried going around it with a small punch but it didn't work very well so I will have to go get some pvc pipe
  8. Apr 18, 2016 at 8:17 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    It should be rubber. That doesn't look like the right part
    F9CA1E4B-25F5-4D65-A14F-9D49F41C761E_zps_5f6fb0e51965f90d9f7798edbd78119f3624c87c.jpg
    I used a 2" ABS coupling to drive mine in and it worked easy peasy, just make sure to grease the spring on the inside so it doesn't fly out and grease the outer part of the seal so it slides into the differential easier.
    219C397C-0061-4D6E-A4A5-86152614A164_zps_44dcfa238b1cc2fd83b6f14f68250810862b13dc.jpg
    As mentioned, make sure to drive it to the correct depth (not too far though) otherwise it will leak
    9EA9F3AC-FB34-4E49-8A10-8358B11B9B9E_zps_a5d57944f6ed08ce855617c8d57c82aaca132bef.jpg
  9. Apr 18, 2016 at 8:32 PM
    Idahotacoma
    Justin
    2007 toyota tacoma
    Ok ya I thought the seal definitely looked different but the seal that your talking about that are in those pictures, is that the seal that connects to the cv shaft or is that the end that goes into the differential
  10. Apr 18, 2016 at 9:22 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I have used the old seal as a driver, then a small block on top of that.
    darkyota33 and PSU Taco85 like this.
  11. Apr 21, 2016 at 10:45 AM
    Darklight
    Darklight Well-Known Member
    Bobby
    Charlotte,NC
    2008 Black SR5 V6 4Runner
    http://www.toyota120.com/forum/showthread.php?t=26920
    This method worked best for me. Even after trying to use a seal setter that ECGS recommended. Using the old oil seal method that James recommends worked best!
    Try to get it as deep as the old seal was and make sure you do not put it in to deep.
    Bobby
    darkyota33 likes this.
  12. Apr 21, 2016 at 6:03 PM
    PSU Taco85
    optional
    That's the seal that goes into the differential
  13. Apr 23, 2016 at 4:10 PM
    Idahotacoma
    Justin
    2007 toyota tacoma
    Where did you guys finstill the seal to order it because I have gone to a bunch of different parts stores and can't find the right one or what name would it be under at the parts store??
  14. Apr 23, 2016 at 4:31 PM
    PSU Taco85
    optional
    Either order online or have the dealership order it
  15. Apr 28, 2016 at 7:08 AM
    Darklight
    Bobby
    Charlotte,NC
    mpm likes this.
  16. Apr 29, 2016 at 5:51 PM
    Themud
    Themud Member
    Jud
    2010 taco 2.5 toytec ecgs bushing leather
    Toytec level Ecgs bushing Leather seats
    Help. I think. I put in the ecgs bushing and prying th axle out i bent up the flimsy rim type thing. Is that a huge issue?
    Also put in new seal and a very small portion of the lip is protruding and there is a tiny tear in the lip.
    My advice to anyone is get a chisel and go from those small corner edges that are on the inner side. After hours, east coast said try it. BANG! It came free.
  17. Apr 29, 2016 at 5:53 PM
    Themud
    Themud Member
    Jud
    I mean those small halloed outs half way to the spindle.
  18. Apr 29, 2016 at 7:14 PM
    PSU Taco85
    optional
    The flimsy thing is just a dust shield, no biggie.
  19. Apr 29, 2016 at 8:24 PM
    klikboom
    klikboom Well-Known Member
    SNOHOCO
    Taco
    How did you pull the old seal out? Screwdriver?
  20. Apr 29, 2016 at 8:26 PM
    PSU Taco85
    optional
    Screwdriver or a set of pliers. Just make sure you don't score the diff housing where the outer part of the seal seats against the machined surface.
