CV Axle Replacement ... express method!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roboots21, Mar 3, 2013.
  1. Mar 11, 2014 at 4:53 AM
    #61
    roboots21
    roboots21 [OP] Taco Supreme!
    Brian
    Pittsfield, MA
    2007 TRD Sport DC LB
    Bilstein 5100's, Grillecraft, Flowmaster, Nitto's, NFab's, BHLM, BFLM, 20% tint, more to come.
    Express method worked for me again (Drivers side this time). Found that I originally missed the step of removing sway bar end link/brake line clamp from spindle. Added those to the OP. But again, 25 minutes tire off to tire on. Another 10 minutes to refill diff, but either way. Express method FTW!
  2. Mar 19, 2014 at 6:51 AM
    #62
    j83soldier
    j83soldier Well-Known Member
    joshua
    Colorado
    05 tacoma
    anti lock brake disable mod, fogtime anytime mod, Leer Topper, all pro plate bumper, toytec 3 inch lift, bfg AT, rims, piaa 5100's, some double din head unit (cant remember), warn 8000 winch, DO sliders, hacked frame to fit full size spare, thule and yakima roof racks
    What is the quality of these shafts that everybody is getting for around 100 bucks. The oem one is 300 plus
    Also what is the harm in just replacing to boots
  3. Mar 19, 2014 at 8:07 AM
    #63
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    The quality is not there. I have pix in my user profile of an Auto-zone brand and an OEM cv. Side by side with the boots off. The OEM is much heavier build and has a larger range of motion.
    As long as the cv joints are in good shape, no dirt and good grease still inside, there really isnt a downside to just replacing the boots. Its just messy.
  4. Mar 20, 2014 at 7:26 PM
    #64
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Subbed for sure. Going to attempt this tomorrow... Both sides. One is blown out, other is starting to weep. At 130k I figured screw it I will just replace the axles. As for quality I went with a company called CVJreman. They take OEM axles and rebuild them so you only get OEM parts from them. $99 per axle and I have to send them in my cores. As an added option if someone wanted they have extended length silicone boots to help prevent tearing. I have never done this so it is all new to me, but so far I am very happy with the service of CVJ. From my call to axles at my doorstep was 2 days.
  5. Mar 21, 2014 at 3:38 AM
    #65
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Wouldnt an extended length boot cause even more fin rubbing?
  6. Jun 22, 2014 at 10:11 PM
    #66
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    Steel cable and sledge trick? What is that?
  7. Jun 23, 2014 at 3:42 AM
    #67
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Scroll back. There are pics in here somewhere.
  8. Jun 23, 2014 at 2:30 PM
    #68
    suvh8er
    suvh8er Member
    Dave
    Delaware
    '01 Tacoma SR5
    So my driver's side upper boot is torn and I'm about to take it on the beach for a week of surf fishing. Since I plan on replacing the whole axle when I get home does it really matter if some sand gets in there?
  9. Jun 23, 2014 at 4:54 PM
    #69
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Short term, knowing you are replacing it, it won't flat out fail on you but it might get noisey. Also might throw globs of grease on the beach, no one wants that. It really dosnt take muxh longer to put a new boot on it than just a replacement. Considerably cheaper too.
  10. Jun 23, 2014 at 6:53 PM
    #70
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    Subd
  11. Sep 3, 2015 at 12:35 PM
    #71
    Ellman605
    Ellman605 Well-Known Member
    Elliott
    Glen Dirty, MD
    Sub for my ecgs install
  12. Sep 3, 2015 at 12:38 PM
    #72
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    There's a different way to do it other than this?
  13. Sep 3, 2015 at 12:46 PM
    #73
    Ellman605
    Elliott
    Glen Dirty, MD
    From what I was reading the general way was to remove the caliper, rotor, and spindle and a bunch of other things.
  14. Sep 7, 2015 at 4:38 PM
    #74
    123erinnc
    123erinnc Well-Known Member
    Erinn
    Lake Arrowhead, CA
    2014 Double Cab Long Bed 4x4 TRD
    Weathertech, Wet Okoles, OME 887, Nitrochargers, LR UCA...
    Do the CV boots spin while the truck is in motion at all times, or only when 4x4 is engaged?
  15. Sep 7, 2015 at 4:58 PM
    #75
    123erinnc
    Erinn
    Lake Arrowhead, CA
    Ok that explains how I sliced my driver side CV boot wide open, what a mess:facepalm:
  16. Sep 7, 2015 at 5:02 PM
    #76
    123erinnc
    Erinn
    Lake Arrowhead, CA
    So the dealerships are closed today and I can't get a price. Does anybody know about how much an OEM CV axle cost for a 2014? And has anybody heard of the CVJ OEM rebuilds, are they any good?
  17. Sep 7, 2015 at 6:01 PM
    #77
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    CVJs are good, very good.
  18. Mar 12, 2016 at 9:57 PM
    #78
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
  19. Jun 8, 2018 at 7:49 AM
    #79
    tango zulu
    tango zulu Well-Known Member
    Yukon
    2007 crew cab 4x4
    3 inch lift, 1.5 inch front wheel spacers
    It seems if you had to remove the tie rod end, it no longer is the easy method? My read is the tie rod does not need removal. (I have always had to do this)
  20. Feb 18, 2019 at 6:39 AM
    #80
    darkyota33
    darkyota33 Well-Known Member
    AJ
    Upstate NY
    '05 TRD Sport, 4x4 Manual 6 spd trans, Black.
    Replaced engine with an '07 FJ Cruiser motor. Clutch accumulator deleted. WIP. plan to add new exhaust, cold air intake, URD short throw shifter,
    GHammer, R0dzilla75 and MolonLabeTaco like this.
