CV Axle Replacement ... express method!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roboots21, Mar 3, 2013.
  1. Mar 3, 2013 at 8:32 AM
    roboots21
    roboots21 [OP] Taco Supreme!
    Brian
    Pittsfield, MA
    2007 TRD Sport DC LB
    Bilstein 5100's, Grillecraft, Flowmaster, Nitto's, NFab's, BHLM, BFLM, 20% tint, more to come.
    Recently, I had one of the boots rip on my 2007 Tacoma (105k mi) and I called up my brother (ASE tech) and asked him about replacing just the boot. He suggested I just replace the axle seeing as I'll have it apart and all and also because the boots were not a very fun thing to replace. So I got on RockAuto and ordered a new axle.
    I got the truck up on the lift yesterday and was going to follow this how-to here: http://www.tacomaworld.com/forum/2n...axle-replace-front-wheel-bearing-2nd-gen.html. I get use of the lift at his shop and he helps me out between inspections. So I was about to remove the upper ball joint as he was coming over to get some tools out of the tool box, and he says "What are you doing?" .. I gave him a puzzled look and was like "Uhhhh axle?" He promptly goes "Let me show you the easy way to do that, big shot."
    So here is the easy way. If you are only replacing the axle and not the wheel bearings, you can do it on about <30 minutes. Here is how you do it, express:
    1) Remove wheel/tire.
    2) Remove axle nut cover/cotter pin/axle nut.
    2A) ADDED .. Remove sway bar end link from spindle, also brake line holder from spindle.
    3) Undo lower ball joint (two 19mm bolts).
    4) Once you have the ball joint undone, you can basically swing the whole caliper/rotor/spindle assembly out of the way, and push the axle out of the wheel hub.
    5) Remove axle from diff.
    6) Reassemble in reverse order.
    I was expecting this to be much more involved process, but was pleasantly surprised. I held the spindle out of the way while my brother popped the axle out of the diff with no special tools. It took us ~25 minutes no joke from start to finish.
    He had told me he had just done a replacement in a 4-runner and that these toyota's are some of the easiest to do the front axle in. I wanted to share this with you folks that have to replace just an axle. Saved me an hour of work easily. :)
    EDIT: Missed a step. Added 2A. Just did this on the drivers side axle again. 25 minutes from tire off to tire back on.
  2. Mar 3, 2013 at 9:11 AM
    biglinc
    biglinc Well-Known Member
    linc
    maine
    07 tacoma
    subbed
  3. Mar 4, 2013 at 10:10 PM
    RIDDICK3
    RIDDICK3 nuckin futs member
    Stefan
    Orem, Utah
    Icon, omd, lr uca, bed speakers, t-rex grill, 170 striker lights.
    got any pics? about to do both cv's and also do you have to get a alignment after replacing them?
    darkyota33 likes this.
  4. Nov 2, 2013 at 4:45 PM
    lemons
    lemons LOCO 4X4
    Virginia
    07 TRD DC Offroad 4X4
    Icon coil overs W/King 14 inch 700lb springs and super bump bump stops, Allpro Expo leaf springs, Allpro Ubolt kit W/timbren Bump stops, Dif Drop Kit, Magnaflow Cat-Back Exhaust, Badges painted Rust-Oleum bed liner, Color Matched TRD Sport Grill W/Grille Craft Insert, TRD seat covers, Weather Tech Floor Mats, Flyzeye's , fog light anytime mod, ABS Off mod, ATO skid plates, ATO rear H/C bumper, BAMF sliders w/kick out, CBI front bumper, Engo 10000lb winch, Rigid D2 foglights, Piaa 510 fog lights, cobra CB w/firestix antenna, AFE snorkel
    sub'd, Just torn a boot.
  5. Nov 2, 2013 at 6:14 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Is it really that simple??. I have a torn inner boot on my driverside. I already have the new axle, i just havnt attempted doing it yet. I thought it was a little more involved than this
  6. Nov 2, 2013 at 6:16 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Wow, it's 2013 and you guys just barely figured out the "express" way of replacing an axle shaft?
    Slacking guys.
  7. Nov 2, 2013 at 6:22 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Taking the balljoint off takes longer than takin off the two large bolts on the bottom of the spindle.
    Way longer
    Leave that upper bj alone. One less thing to duck up during the R&R.
    Dominic4Lo likes this.
  8. Nov 2, 2013 at 6:23 PM
    reece13
    North Carolina
    I haven't done a cv axle replacement on a Tacoma yet, thats why I am glad to know this info.
  9. Nov 2, 2013 at 6:27 PM
    reece13
    North Carolina
    So an alignment wont be needed after R&R?
  10. Nov 2, 2013 at 6:29 PM
    Spoonman
    Jamie
    Alberta
    No.
    1 wheel
    2 dust cap
    3 axle nut
    4 two lower bolt
    5 Pop it out of the diff.
    Repeat in reverse to install. Can R&R in about 20 minutes.
    Have new one ready so you don't lose any gear oil.
  11. Nov 2, 2013 at 8:24 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Unless the axle won't come out. That's fun. Matt's was a BITCH.
  12. Nov 2, 2013 at 8:28 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    The only issue I had was removing the damn axle from the diff. other then that it was as stated above. same steps etc..
  13. Nov 2, 2013 at 8:37 PM
    Spoonman
    Jamie
    Alberta
    I use a 5' pry bar. Easy
  14. Nov 2, 2013 at 8:52 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Subbed! I have a torn inner boot.
  15. Nov 2, 2013 at 11:08 PM
    RIDDICK3
    Stefan
    Orem, Utah
    I took some pics of everything you need to take off in another thread
  16. Nov 2, 2013 at 11:53 PM
    gearcruncher
    Canadain bumper technician
    You dont need an alignment because you are not changing the geometry of the front end . If you remove Tie rod ends by unthreading them , you will need to have alignment checked but in this case you do not need to remove tie rods .
    I would pay attention to how the ball joint is removed . It should be popped out of the control arm .
    The idea to replacing an axle is to try and keep everything the same as it was before you took it apart
    When removing the axle , you want the axle to be as straight as possible . Same goes for re-assembly . The straighter the axle is , the easier it will go into the diff
  17. Nov 3, 2013 at 10:41 AM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    Torn drivers side need to do mine too. Def goin to do it this way instead of the other longer way
  18. Nov 3, 2013 at 11:02 AM
    anotherreject
    anotherreject Well-Known Member
    My boots are not torn but i have a axle seal leaking on the front, i might as well change the whole dame axle while its apart, thanks for the info.
  19. Nov 3, 2013 at 11:06 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    interesting.
  20. Nov 3, 2013 at 11:16 AM
    Spoonman
    Jamie
    Alberta
    Why change the axle if there no problem?
    That's kinda like changing the engine if there's nothing wrong with it
