CV AXLE OR BOOT
Discussion in 'General Automotive' started by gregzz, Nov 2, 2021.
  1. Nov 2, 2021 at 11:14 AM
    gregzz
    gregzz [OP] Well-Known Member
    greg
    las vegas nv
    2011 tacoma crew cab 4x4 v6 4.0
    Wheels/ tires, tint, level kit. Rock crawler rails. 3- 6" procomp lights with light bar on front bumper. Magnaflow # 12256 stainless muffler. Billet shorty antenna.
    Ughh!! I’ve got a CV BOOT leaking on my 2011 Tacoma. Anyone have any experience in changing out the CV AXLE that wants to give me some pointers would be great. Thx!
  2. Nov 2, 2021 at 11:15 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Nov 2, 2021 at 11:19 AM
    gregzz
    greg
    las vegas nv
  4. Nov 2, 2021 at 11:21 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    This guy knows his shit
    fatfurious2 likes this.
  5. Nov 2, 2021 at 11:23 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    CV axles are pretty straightforward/easy to swap out if you have a little experience doing DIY maintenance. There are a ton of tutorials on Youtube to follow that make it as simple as going step by step, just search YouTube for Tacoma Cv axle install.
    SR-71A and gregzz[OP] like this.
  6. Nov 2, 2021 at 11:26 AM
    gregzz
    greg
    las vegas nv
    :facepalm:
    thx. I’ll do that.
  7. Nov 2, 2021 at 11:57 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    They are pretty straightforward like @eon_blue said. You can get an OEM boot kit from Toyota, but you will need these pliers and 2 breaker bars for leverage
    Lisle 30800 CV Boot Clamp Pliers https://www.amazon.com/dp/B0002SREPY
    If you don't want to rebuild yourself, you could send them out to CVJ for a rebuild
    gregzz[QUOTED][OP] and SR-71A like this.
  8. Nov 2, 2021 at 12:06 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yes.
    Only thing Ill add is depending on how tight your circlip is you might have a hell of time popping it out of the diff. Some are easy and some fight you all the way. In that case an extra set of hands and a CV Lasso can be a huge help.
    For example: https://www.gzila.com/products/cv-removal-tool
  9. Nov 2, 2021 at 12:12 PM
    fatfurious2
    David
    Ashburn, VA
    I found when you are trying to get the cv out, to tap with a small sledge, and rotate the diff side of the CV, and then pry with a pry bar. sometimes tap the handle side of the pry bar. Keep on doing that until it pops out. It might take a while or you might need a lasso like @SR-71A said.
    These will help too:
    https://youtu.be/-oSifI6U-Iw
    https://youtu.be/F_WNmMWYaeA
    SR-71A likes this.
  10. Nov 2, 2021 at 12:21 PM
    jgr81
    jgr81 Well-Known Member
    Jen
    Summit County CO
    16 Tacoma TRD OR Access Cab, 03 4runner v8
    I just replaced both cv axles on my old 4runner and it was cake, I have helped before but never tackled one on my own. I watched a few youtube vids just to make sure I did everything in the right order and it was no big deal. Get yourself a long pry bar and don't be afraid to whack it pretty good to get out/put back in. Tapping on the end of the axle with a rubber mallet did not work for me. Make sure it is lined up really well, I didn't have any help so I used a bungee cord looped off of my upper control arm to hold it level. Only took one or two good whacks using a big hammer with the pry bar in the little indentations on the inner cv body to get the c-clip going in. You will do fine!
    gregzz[QUOTED][OP] likes this.
  11. Nov 2, 2021 at 1:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It’s not too bad to replace the CV.
    Remove the caliper. You can leave the pads in.
    Remove the 35mm axle nut.
    Disconnect the 2 Lower ball joint mount bolts.
    Remove the tie rod end from the spindle.
    The sway bar mount/link can stay on.
    Pull out on the lower spindle where the ball joint mounts.
    Swing spindle out of the way.
    Pull CV out.
    If you are good. And everything goes right. It could probably be done in an hour or so.
    I’m slow. Really slow. It took me longer. I’m not a mechanic. And I tend to check and recheck things.
