CV axle opinions
Discussion in '1st Gen. Tacomas (1995-2004)' started by tntacomaguy, Dec 12, 2022.
  1. Dec 12, 2022 at 9:59 AM
    tntacomaguy
    tntacomaguy [OP] Well-Known Member
    Hello all, I haven't been active on here posting for ages thanks to work and life. However, my poor truck is falling apart on me and I'm trying to get a few things fixed up on it.
    First up are the CV axles. I replaced them several years ago with parts store brand ones before I read about rebooting the OEM :annoyed:, anyway, both sides have both boots busted or just totally gone. I do have lifetime warranty thru the parts store but I'd rather replace with better quality if possible, since the parts store ones bind up. Can't afford the CVJ (I think that's the company), besides I don't have OEM cores to return anyway. And definitely can't afford OEM
    While looking this morning I found a set on rock auto that claims to be for lifted suspensions. A quick search on TW didn't come up with much on the brand, maybe one to two people used them and the verdict was still out on them. They are the Trakmotive or FVP TO8043XTT. Not sure what the difference is between the 2 brands except about $10.
    Trakmotive
    FVP
    Anyone have experience bad or good with these? And also that part number is for ADD correct?
    For the record, my truck is an 02 v6 ADD, with OME lift. Don't do offroad much anymore and when I do it's light dirt roads getting to hunting spots. Also don't put many miles on the truck, think its around 5k a year for the last 2-3 years.
    Thanks for any input! :wave:
  2. Dec 12, 2022 at 10:15 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    tntacomaguy[OP] and Bivouac like this.
  3. Dec 12, 2022 at 10:37 AM
    tntacomaguy
  4. Dec 12, 2022 at 10:41 AM
    eon_blue
    Azusa, CA
    For a parts store axle it is probably the best bang for your buck, otherwise you could try and hit up some dealerships locally or online to see if they have any remanufactured OEMs in stock. They're discontinued for 1st gens but a lot are still floating around. Without a core to exchange I think they cost around $170 each.
  5. Dec 12, 2022 at 10:43 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Then just use the lifetime warranty. Getting back to the OEM quality is going to be expensive if you didn't keep the original CVs.
  6. Dec 12, 2022 at 11:34 AM
    DemApples
    DemApples Kainoa HI
    Kainoa
    Kailua-Kona, HI
    1995.5 Tacoma
    Supercharged w/ 7th injector 97 ECU swap 2001 front end swap TRD e-locker rear end swap 6 inch crossmember lift stretched to 11.5” 3 inch body lift 14.5” total lift
    I’m currently running the extended travel cv’s from oreillys. I have to say they are so beyond worth it, I HIGHLY recommend.
    My truck is lifted in way that makes some people grumpy on TW. (11.5 inch suspension lift). For my application OEM axles do not even bend far enough down to reach the wheels from the diff... let alone have enough travel to rotate without binding. The extended travel CV’s have considerably more travel than OEM, and they have lifetime warranty!
    I believe I went through 3 cv axles (the fancy oreilly ones) on my passenger side within a span of a week until I finally got a cv from them that wasn’t put together like shit though. But hey, lifetime warranty. Still highly, highly recommend. Make friends with the workers over there so you can get a discount on them. Get a commercial discount put on there and they come out to around $450 a pair.
  7. Dec 12, 2022 at 11:36 AM
    DemApples
    DemApples Kainoa HI
    Kainoa
    Kailua-Kona, HI
    1995.5 Tacoma
    C0E83F0A-2D69-4AC4-9826-A7587FEF412A.jpg There’s the first one to break..
    4E0DF178-34E7-4C89-AA11-B6FF3787DC71.jpgAnd the second one..
  8. Dec 12, 2022 at 11:38 AM
    DemApples
    DemApples Kainoa HI
    Kainoa
    Kailua-Kona, HI
    1995.5 Tacoma
    AF0DACF2-425B-483F-BAAE-A2F589746B4F.jpgFinally a keeper lol
  9. Dec 12, 2022 at 3:06 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    I'll be that guy, OEM. A couple of weeks ago I just replaced my 2nd OEM (one on each side) after 40k+ strict offroad miles on my 2015. I wouldn't consider anything but OEM based on my history of wheeling this truck. Both failures were also my fault - Full turn locked and both in bad situations in which I couldn't avoid.
    I do wheel with those who love the 2ndary warranty market and they will keep replacing them with a smile.
    Do a search here and you'll see the topic has been discussed repeatedly and I also bet you see that OEM is the clear choice if you offroad.
    Good luck!
  10. Apr 16, 2024 at 8:45 PM
    Pacificclam
    Pacificclam Well-Known Member
    Carl
    Hawaii
    2010 Tacoma 4x4 Access cab
    6” pro comp lift Kings Coils and Shocks 700lbs Element UCA Atlas Leaf spring kit 17x9 stealth custom series ray 10s -38 33x12.5 toyo open country mt Tom woods driveshaft CSF high performance radiator 4.88 GEARS
    yo bradda, you think these extended CV axles would fit my Tacoma set up?
    im on a fabtech with kings and leaf springs set up. Lifted 8” total I think.
    I’m in need of some new CV axles… lemme know. Mahalos
  11. Apr 21, 2024 at 12:52 PM
    DemApples
    DemApples Kainoa HI
    Kainoa
    Kailua-Kona, HI
    1995.5 Tacoma
    They absolutely would fit and I promise you will not regret it. Hmu on ig if you get any other questions. I build this kine all day. @im.kainoa
    Pacificclam[QUOTED] likes this.
