Cv axle needle bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by acgreen01, Oct 20, 2020.
  1. Oct 20, 2020 at 2:29 PM
    acgreen01
    acgreen01 [OP] Well-Known Member
    Andrew
    2012 silver 4wd regular cab
    I have a 2012 tacoma 4wd base model. Regular cab 2.7l. Went to Toyota to get the needle bearings and they say their is a type A and a Type B. Does anyone know how to tell which one mine has? Like what do I need to look at to know. Toyota couldn't tell me
  2. Oct 20, 2020 at 2:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Any reason why you want to go back with a needle bearing?
    I’d go with the aftermarket bushing myself.
    Pretty sure the same bushing works in all the 2nd & 3rd Gen trucks.
    @whatstcp is the 2.7 diff any different than the 4.0 , other than being 4.10 ratio?
    whatstcp likes this.
  3. Oct 20, 2020 at 2:59 PM
    acgreen01
    Andrew
    I just prefer the bearing over the bushing. I don't plan on a installing a lift or anything.
  4. Oct 20, 2020 at 3:00 PM
    TnShooter
    Deogee
    STOCK
    Sorry, I can help on the type A or B.
    Maybe whatstcp will know?
  5. Oct 20, 2020 at 3:01 PM
    acgreen01
    Andrew
    My axle code is A02A. My local toyota dealership looks at me like I'm stupid when I ask how do I know which I have
  6. Oct 20, 2020 at 3:03 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The dealer could not tell you what you need? :facepalm:
    Thatbassguy likes this.
  7. Oct 20, 2020 at 3:04 PM
    acgreen01
    Andrew
    Nope. My local dealer sucks. He ordered the bearong for both and said Goodluck. Bring the one back yoj don't need. Plus had to order them. After he was supposed to have ordered them yesterday but didn't
  8. Oct 20, 2020 at 3:04 PM
    acgreen01
    Andrew
    their service department was like sorry don't know what to tell you
  9. Oct 20, 2020 at 3:07 PM
    TnShooter
    Deogee
    STOCK
    Maybe it’s like the Luk or Aisin clutch?
    They used both in the 2nd Gens.
    Maybe you don’t know, until you get the old one out?
    Which obviously makes for preordering parts “hard”.
  10. Oct 20, 2020 at 3:07 PM
    TnShooter
    Deogee
    STOCK
    Thanks man:thumbsup:
    whatstcp[QUOTED] likes this.
  11. Oct 20, 2020 at 3:18 PM
    acgreen01
    Andrew
    Thanks for the help. I don't understand why it so complicated for them to do it.
  12. Oct 20, 2020 at 3:19 PM
    acgreen01
    Andrew
    Dealership parts departments make things complicated.
    I work for a local 18 wheeler Dealership and our parts department makes things more complicated then they need to be. Lol
  13. Oct 20, 2020 at 3:42 PM
    acgreen01
    Andrew
    How long have yall had the bushings in? How are they holding up?
  14. Oct 20, 2020 at 3:45 PM
    rnish
    Tacoma 2nd gen
    About 3 weeks. 500 miles and still going strong.
  15. Oct 20, 2020 at 4:17 PM
    acgreen01
    Andrew
    Also is the passenger side cv axle seal bigger than the driverside
  16. Oct 20, 2020 at 4:56 PM
    rnish
    Tacoma 2nd gen
    The driver side is the problem side. The passenger side has “real” bearings. If memory serves me you can get both seals from ECGS.
  17. Oct 20, 2020 at 4:59 PM
    acgreen01
    Andrew
    I got my seals from my toyota dealership but did not know that it was a regular bearing on that side
  18. Oct 20, 2020 at 6:08 PM
    TnShooter
    Deogee
    STOCK
    There have been a lot of guys running the bushing for years and many thousands of miles.
    You can get both seals for ECGS I think they are around $20 each.
    They also make a bearing removal tool.
    If you look over in the BST section, a lot of the time there is one floating around for you to borrow.
    Once you are done with it, send it to the next guy.
  19. Oct 20, 2020 at 6:10 PM
    acgreen01
    Andrew
    I am trying to do it this Saturday. Has anyone had any luck with a slide hammer with a 2 jaw puller
  20. Oct 20, 2020 at 6:16 PM
    TnShooter
    Deogee
    STOCK
    I think there was a guy that did it that way.
    You need to be really really careful not to damage the side where the bearing sits.
    I believe the tool is a blind hole bearing puller.
    @Larzzzz
