CV Axle going bad?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TeeYoda, Dec 20, 2017.
  1. Dec 20, 2017 at 9:05 PM
    TeeYoda
    TeeYoda [OP] Well-Known Member
    PNW
    2003/2025 Tacoma sr5 4x4
    What are some of the signs of a cv axle going bad? I've been noticing a shake/vibration coming from my front drivers side wheel at highway speeds. It feels similar to a tire being out of balance. I had my tires balanced a few weeks ago. Did the wheel bearing a month ago. The ball joints and tie rods are fairly new. The one thing that isn't new is my cv axle. The drivers side cv boot does have a very slight tear. I don't have the classic symptom of clicking when it turns. Could a worn cv axle being causing the highway shake? Is there anything else I can do to check to cv axle?
  2. Dec 20, 2017 at 9:15 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    louder/ higher pitched the faster you go?
    You may be like me (and an older fellow I know with same noise) and looking next at needle bearing in the front diff, driver's side.
    Black97v6MT likes this.
  3. Dec 20, 2017 at 9:20 PM
    TeeYoda
    PNW
    Zero noise associated with it. It's a shake that I can feel just like an out-of-balance tire...
  4. Dec 20, 2017 at 9:36 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    CVs are a little hard to diagnose as loose. There's a bit of flop to new ones when you grab and shake them.
    Mine is a vibration also but has progressed to a hum. I've traded tires/CVs/ even went back in checking new wheel bearings. That needle is next.
    FWIW: Most people associate bad CVs w/ a 'click' especially turning.
  5. Dec 20, 2017 at 10:19 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Was it doing it before you had your tires rebalanced? It's possible that they didn't balance very well, and this could be causing the issue. You could check by rotating the front/rear tires and seeing if the vibration goes away or moves to the rear of the truck.
    TeeYoda[OP] likes this.
  6. Dec 21, 2017 at 9:49 AM
    TeeYoda
    PNW
    I got the tires rebalanced after I noticed the vibration thinking that was the problem. It didn't help. So I guess what I'm left with is it's either the cv axle or the needle bearing. I don't think it's the needle bearing because the truck isn't lifted & I don't have the vibration between 35-50 mph like others complain about. The vibration is only noticeable at highway speeds from 60 mph & up...
    Has anybody out there had my symptoms and it turned out to be a cv axle? These are the same cv axles that came with the truck new, so they have 270,000 miles on them...
    03 NIGHT TACO[QUOTED] likes this.
  7. Dec 21, 2017 at 9:53 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    hmmm, mine is only at hwy. also. I'll take cues from you. I've changed (swapped with someone) CVs already though. No change.
    has progressively gotten worse over a few years.
  8. Dec 21, 2017 at 9:53 AM
    geoyota760
    geoyota760 Allergic to pavement
    PHOENIX, AZ
    2019 TRD OR
    5.29 Nitros Bilstein ICON Kansei BFG
    I had similar issues...replaced the carrier bearing, tires rebalanced, removed my wheel spacers...vibration from 60-65 mph now gone, but now have a rotational (reminds me of a wheel bearing going, but replaced those as well) vibe that seems to be located in the diff area.
    Needle bearings are a new source to check...I was also going to look at my front drive shaft u-joints...
    EDIT: added all new steering components, along with CV's about 15K ago...so hoping that's not the source now.
    :cool:
  9. Dec 21, 2017 at 9:56 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Yea, i did my U joints and carrier bearing. CB was on it's way out anyway but made no change, had 1 U joint i thought for sure was going to be it. Nope.
    Goes to show you can get vibes w/o a lift that are hard to find.
    Black97v6MT and geoyota760 like this.
  10. Dec 21, 2017 at 10:07 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Maybe I'm missing something but the CVs shouldn't be rotating unless your in 4wd, so how could it be the CVs at highway speeds in 2wd?
    Black97v6MT and Marc70 like this.
  11. Dec 21, 2017 at 10:12 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I don't have lock hubs, guessing he doesn't either.
    BTW extra hard taco, yours do too if you didn't realize.
  12. Dec 21, 2017 at 10:14 AM
    TeeYoda
    PNW
    Unlike the old manual locking hubs, ADD hubs don't disconnect the cv axle from the wheel, so the cv's are constantly spinning...
  13. Dec 21, 2017 at 11:10 AM
    Extra Hard Taco
    R.J.
    Devil's Island
    Roger that
  14. May 6, 2020 at 11:02 AM
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Did you ever figure that vibration out? Having a similar issue with my 06
  15. May 6, 2020 at 11:18 AM
    TacoTaco02
    TacoTaco02 Well-Known Member
    Illinois
    02 Ext Cab SR5 TRD 4x4 V6
    I'm curious as well.
    My Tacoma got hit in the front left wheel and I've had a vibration issue since it was repaired.
    New spindle, control arms, bearing, etc. Wondering if the cv joint somehow got bent....
  16. May 6, 2020 at 1:03 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    man that's a big can of worms there.
  17. May 6, 2020 at 1:39 PM
    TeeYoda
    PNW
    It ended up being a tire (or tires). I replaced the tires due to mileage & the vibration completely disappeared. Happy it was something so simple...
  18. May 6, 2020 at 2:40 PM
    TacoTaco02
    Illinois
    Yeah, I am unhappy to say the least especially because the other driver was deemed 100% at fault. Had a new tire and reconditioned wheel put on as well during the repair. Rebalanced everything and that helped but still have the problem.
    I'm going to do another rotation and see what happens. The only other thing that rotated relative to speed possibly affected by getting tboned is the cv joint.
  19. May 6, 2020 at 4:33 PM
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Stupid question but have you had a wheel alignment done?
  20. May 6, 2020 at 5:15 PM
    TacoTaco02
    Illinois
    Yeah, they checked to make sure the frame was still straight and aligned it after the repair. Everything was good.
    [KD][QUOTED] likes this.
