CV-axle confusion - can you set me straight?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toddwarren2, Dec 13, 2016.
  1. Dec 13, 2016 at 9:17 AM
    toddwarren2
    toddwarren2 [OP] Gig 'em Ags!
    Todd
    Stuart, FL
    2006 2.7L 4-cyl Tacoma 4x4
    3" MotoFab strut spacer 3" SkyJacker Add A Leaf LiquidMetal 20" chrome wheels 275/55/20 Pirelli Scorpion tires TPMS hack (to turn off the blinking light) 1" filter for the 2ndary air pump (emissions control BS)
    Hey TW peops! So I'm getting ready to install the ECGS bushing to replace my wonky factory needle bearing set-up on my 2006 4x4 2.7L 5sp. I think I may also have a bent or otherwise damaged cv-axle on my driver's side from nailing a curb a while back, but don't see anything obvious (broken boots, oil leaks, obvious bends, etc.). Since aftermarket cv's appear to pretty affordable, I'm going to swap both driver's and passenger's side cv's while I'm doing the bearing.
    So here are my questions:
    1) Which manufacturer of aftermarket cv's is okay? Which are hunks of doo-doo? Online reviews are virtually no help in my experience...
    2) What is the proper length of the cv axles? I'm seeing a ton of different lengths - some as long as 33" and some short as heck. I've read some horror stories about people installing aftermarket cv's that end up being shorter than the stock ones. I would like to avoid tearing apart my truck to find out I have replacement cv's that are too short.
    3) I think I know the answer to this, but are the driver's side and passenger's side interchangeable. That is, are they the exact same part number?
    4) I ordered axle seals for both sides from ECGS (OE ones I think), but don't currently have leaks. Is there anything obscure about replacing these? I see some discussion about how to seat them properly. One side is "flush" and one side is "pushed all the way in 'til it stops" so I'm a little dubious about this. I'll definitely make note (take pics) of the factory seal location before I pull them out, but want to know if there's anything strange about this procedure that I should be on guard for.
    Thanks y'all. Seems like I have more questions but can remember them right now.
    timbobzimbob likes this.
  2. Dec 13, 2016 at 1:39 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I'm not of any help, but I do wish to know the answer to this as well. From the research I did the only conclusion I could come to was that ALL aftermarket CVs are crap and I should try to grab some used genuine Toyota take-offs.
  3. Dec 14, 2016 at 6:14 AM
    toddwarren2
    Todd
    Stuart, FL
    Well, I bit the bullet and ordered some A1Cardone CVs, new. Part nos: 66-5235HD. I'll let you know how they fit after install. Probably will be some time b/w Christmas and New Year's before I get it done.
  4. Dec 14, 2016 at 6:18 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    Cvjaxles.com built great ones for me!
    Coot83 likes this.
  5. Dec 14, 2016 at 7:20 AM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    Don't get rid of the oem cv axles. Send the OEM pieces to CVJ and have them rebuild them for you.
    Coot83 likes this.
  6. Dec 14, 2016 at 7:23 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I was just going to say the same thing. A good secondary option besides a rebuild is have CVJ build one like @fireturk41 said.
    Coot
    toddwarren2[OP] likes this.
  7. Dec 14, 2016 at 7:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    I have Cardones on my Tundra. Replaced pass side last year and the boot is already dry rotted. I just replaced driver side this year. The other thing to note is the retaining clip is square on the Cardone. Throw it out and use the round one off of the OEM axle.
    toddwarren2[OP] and Coot83 like this.
  8. Dec 14, 2016 at 7:35 AM
    toddwarren2
    Todd
    Stuart, FL
    Well I ordered the "HD" ones that seem to have an upgraded boot versus the regular version. Hopefully mine don't dry rot. Thanks for the heads-up on the retainer clip. I bet that square clip take a 15lb sledge hammer to persuade it to seat.
  9. Dec 14, 2016 at 7:38 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Some aftermarket CV joints are known to have less articulation range than OEM. Important thing to consider for lifted trucks.
  10. Dec 14, 2016 at 7:39 AM
    toddwarren2
    Todd
    Stuart, FL
    My only concern about having them rebuilt is that I have a suspicion that the driver's side CV is bent in some very minor way. The passenger side is fine...which makes me wonder why I decided to replace it too! LOL How much does CVJ charge for a rebuild? I don't do a ton of off-roading, so I imagine the new CVs are going to last for a long time. I have 190k on the clock, so the OEMs lasted just fine based on the limited abuse I give them. Having a spare set seems more like a plan for an avid off-roader... so maybe I could sell these to someone who wants to rebuild them? Just an idea.
  11. Dec 14, 2016 at 7:42 AM
    toddwarren2
    Todd
    Stuart, FL
    I am concerned, albeit only a tiny bit. I have a very modest lift - more like a leveling kit on front and a wee lift (AAL) on the back. As far as I can tell, I don't have any of those bugga-boos people talk about related to lifts (shutters/shimmies/vibes). I DO have a vibration, BUT it was there prior to the lift and new wheels. I'm hoping the vibe I have is settled by the new CVs and the ECGS bushing. I have to say, tho, if I pull of the OEM CVs and the new ones are shorter, I'm gunna be uber pissed.
  12. Dec 14, 2016 at 7:52 AM
    KenLyns
    Belly of the Beast
    I've seen two different lengths on Rock Auto. They differ by a good 1/4" but are measured from tip to tip, which is not a good interface dimension. (The longer one could simply have more threads for the axle nut.)
    http://www.rockauto.com/en/moreinfo.php?pk=3857619&cc=1445516&jsn=402
    http://www.rockauto.com/en/moreinfo.php?pk=2976975&cc=1445516&jsn=405
    Unfortunately the Cardone axle listings don't show the length.
    You have the necessary tools handy? Need a large socket for the axle nut (which may differ in socket size between OEM and aftermarket...) and either a 1/2" drive impact wrench or long breaker bar.
  13. Dec 14, 2016 at 8:10 AM
    toddwarren2
    Todd
    Stuart, FL
    Ya, I have all the tools needed to get everything removed and installed. I've replaced both wheel bearings and hubs (trying to track down my freaking vibe), so have the right socket to get that OE axle nut off. I might break down and get a serious torque wrench, tho. Mine only goes up to about 140ft.lbs. and if I remember right the axle nut is tightened in the 170ft.lb. range. The only tool I might do without is the needle bearing puller from ECGS. I've heard mixed reviews on how easy the OE needle bearing comes out of the diff. Some say they got it out easily with a standard slide hammer and a bearing puller jaw attachment. The ECGS tool looks pretty simple to make. I could measure the OD of the new bushing and make a similar tool before I start the job, but knowing myself better than that, I'll spend 3 hours cussing at the slide hammer before I break down and fashion a removal tool. Ha! I am trying to track down an ECGS removal tool to use on loan.
  14. Dec 14, 2016 at 8:28 AM
    andrew61987
    Source on this? First hand experience? I see it mentioned a lot but the information is always pretty vague as far as which brands suck and how the articulation range was verified.
  15. Dec 14, 2016 at 9:04 AM
    cj13058
    Oregon
    My napa cvs are already clicking in some conditions and the boots squeak at very low speeds (when everyone can here it ha).
    CVJ can rebuild them, I was quoted around $300 to rebuild and ship my exact ones back to me. Call them and talk to them, they were helpful on the phone. They can even install a different boot to help cope with steeper angles.
    I have not found another place to do this local.
  16. Dec 14, 2016 at 9:06 AM
    cj13058
    Oregon
    Use a hose clamp to secure the slide hammer to the cv when pulling it out. And when reinstalling, use a crowbar on the flat housing of the cv to bang in back in. Do not hit the shafts with a hammer
