Cv axle broken again
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HumanityForPresident01, Jun 20, 2021.
  1. Jun 20, 2021 at 6:45 PM
    HumanityForPresident01 [OP] Let 'er eat
    Trevor
    2006 Dark Blue Tacoma V6 SR5 EXT Cab TRD Off Road
    2.5" rancho 9000xl lift with UCA's, custom rock sliders, custom rear tube bumper, road armor front bumper, k&n air intake, winch, lights etc.
    Hey everyone,
    I recently started breaking passenger side cv axles and I don't know what's up.
    Both times they've broke on the inner joint, both times going under 6mph and both times turning left.
    Both axles were brand new with less than 200miles on each.
    I've never had this issues in the past 3.5 years of ownership, only the last two months has this occured after I ditched my lift blocks for lifted springs and got bigger tires.
    -Cv axle angle is almost completely flat on level ground
    Could the flex from the leaf springs and frame twist cause the CV to separate?
    Does anyone have any suggestions or questions?
    Would a better uca help this problem?
    Thank you!!?
  2. Jun 20, 2021 at 6:51 PM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    Wheel turned all the way when they break?
  3. Jun 20, 2021 at 6:53 PM
    Trevor
    Not full lock but definitely turning.
  4. Jun 20, 2021 at 7:12 PM
    littlefish
    Hudson Valley NY
    Ok. I definitely don’t have any answer for you. I was thinking maybe your steering was over extending if you were at full lock adding strain. Otherwise I’ve got no clue. Sorry and good luck.
  5. Jun 20, 2021 at 7:17 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    year
    model
    mileage at breakage
    L i f t ????how high
    tcjacado likes this.
  6. Jun 20, 2021 at 7:30 PM
    Trevor
    Rancho 2.5" uca/diff spacer, axle was brand new less than 30 miles.
    Previous axle last month brand new less that'll 200 miles.
    DSS brand or DDS from carid. Com and a car quest brand cv
  7. Jun 20, 2021 at 7:37 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Probably just due to low quality CVs.
  8. Jun 20, 2021 at 8:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d do this, plus turn the wheel to the left and rotate the tire.
    See if anything is suspect.
  9. Jun 20, 2021 at 10:33 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Use OEM CVs only, aftermarket are junk.
  10. Jun 21, 2021 at 2:27 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^
  11. Jun 21, 2021 at 2:50 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I had a similar problem where my halfshaft popped out of the stub shaft pretty much the same as it looks like yours did. See here: https://www.tacomaworld.com/threads/passenger-side-half-shaft-broke.722269/
    My truck has about 2-2.25" lift in the front.
    When I pulled off the failed shaft and compared it to the new shaft I was going to replace it with, the old shaft looked about 1.5" shorter. The tulip cup on the halfshaft appeared to be shallower as well.
    When I was limping it off the trail with the old, broken shaft, the half shaft barely had any engagement with the stub shaft, even when the truck was on the ground (which was as easy see given that the CV boot was torn to shreds when it failed).
    My new shaft is a NAPA shaft with the "high performance" boots. Not OEM, but I've read good things about them and decided to try them out, as they are ~1/4 the cost of OEM. And as stated above, they are about 1.5" longer than the CV shafts that were installed on the truck when the shaft failed (it appears the NAPA shafts are the correct dimensions).
    I'm out of town at the moment, but when I get home I plan on taking more detailed measurements to confirm--but at first glance, it looks like some of the non-OEM replacement brands have shorter halfshaft and shallower tulip cups on the inboard stub shafts--making it far easier for them to pop out, especially when lifted.
    My initial guess is that the manufacturer of my old CV shafts that failed skimped manufacturing/material costs by making a shorter half shaft and shallower tulip cups on the stub shafts, which are compatible (for the most part) with stock height trucks, but that don't have sufficient engagement on lifted trucks, leading to these kinds of failures. As mentioned above, I plan to do more detailed measurements when I get home, but the initial inspection was pretty damning for the old shafts.
    wi_taco, ItalynStylion and Goldwrench like this.
  12. Jun 21, 2021 at 9:38 AM
    Trevor
    No it doesn't contact it I'll look this week/end for more less droop
  13. Jun 21, 2021 at 9:39 AM
    Trevor
    Oem cv's are like 395$ a piece
  14. Jun 21, 2021 at 9:41 AM
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    Buy OEM. Online I purchased a brand new OEM axle for like $300. Worth the price for a robust trouble free item. Reman axles I stay away from, I would not even use them if someone gave me one for free unfortunately.
  15. Jun 21, 2021 at 9:42 AM
    Trevor
    Do you have a measurement on the CV that worked for you?
  16. Jun 21, 2021 at 9:42 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Shitty part store CVS don't have the same range of motion as oem and will bind when drooped and turning. I'm sure with some research you can find a part store cv that doesn't suck. For first gens napa axles do alright.
  17. Jun 21, 2021 at 9:45 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    CVJ Axles are awesome. I use mine pretty hard and double lock sometimes and haven't broken one yet for what its worth.
  18. Jun 21, 2021 at 9:52 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Competition CVs are $2000 a set but who's counting? :)
  19. Jun 21, 2021 at 9:55 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Go with CVJ axles. They sell remanufactured OEM CVs, at least with first gens they are about half price or less of a brand new one. And far better than any aftermarket brand (unless you're looking at the aftermarket RCV axles or the like for $2k/pair).
    6 gearT444E likes this.
  20. Jun 21, 2021 at 9:56 AM
    eon_blue
    Azusa, CA
    I've used cheap parts store CVs off and on for awhile and never had one break like that though, even after wheeling them. Usually its the boots on those cheap ones that rip and result in me changing them out. The cheap ones bind up a lot easier though so I can see this happening.
    You're not turning in 4wd on dry pavement or anything like that right?
    SR-71A likes this.
