Cv axle blows out in 4wd
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hilk_55, Nov 30, 2021.
  1. Nov 30, 2021 at 6:26 AM
    hilk_55
    hilk_55 [OP] Member
    Brendon
    2017 Tacoma TRD Offroad
    I had both cv axle boots tear and ended up swapping both cv axels with a brand from advanced auto parts. I drove 4 hours the next day and had to engage 4x4 because of road conditions. I arrived at the hunting camp in 6” of snow, where I backed up to the front door to unload. Went hunting the next day again in 4x4 where I backed into another parking spot. I left hunting and backed up at the camp once again and the inner boot completely twisted up, made an awful noise and then completely ripped apart. I had it towed to a Toyota trained mechanic who put a new one in for me. I picked it up and once again backing up at camp in 4x4 it blew out again! Any body know the cause? I have 3” icon coil overs with the icon UCAs and a 1” diff drop kit. Much appreciated
  2. Nov 30, 2021 at 6:34 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    take the lift off and see if it does the same thing..
    ian rogers likes this.
  3. Nov 30, 2021 at 6:36 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Too high lift
    HiBillyMaysHere and Wulf like this.
  4. Nov 30, 2021 at 6:43 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    How long has it been doing this? Like is this new with your lift or did it just start happening out of the blue? Id also check the bushings for the front diff. Maybe they have wore and the diff is flexing causing cv to go negative in reverse.
    andrewtheadventurer likes this.
  5. Nov 30, 2021 at 6:45 AM
    hilk_55
    hilk_55 [OP] Member
    Brendon
    It just started doing this. The lift has been installed for over a year. I will get pictures but the truck is currently on a tow truck for 180 miles
  6. Nov 30, 2021 at 6:53 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Sounds like an angle issue from the lift.
    Lt. Dangle likes this.
  7. Nov 30, 2021 at 7:06 AM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    doesnt sound like a lift issue to me.. a lift issue will cause it to pop out of the diff a little. My buddy had a 3 gen with like 4" lift and his would pop out .10-15" and we would have to pop it back in. We would only know because it would leak oil but it wouldnt immediately blow up. you will know if the cv is pulling out from the diff. Plus you have a diff drop which fixes most of the angle issues.
    the lift is just the easiest thing to point the finger at
    Id look into bushings or something that is worn and causing a the cv to break.
    LoveableWerewolf likes this.
  8. Nov 30, 2021 at 8:32 AM
    hilk_55
    hilk_55 [OP] Member
    Brendon
  9. Nov 30, 2021 at 8:33 AM
    hilk_55
    hilk_55 [OP] Member
    Brendon
  10. Nov 30, 2021 at 8:33 AM
    hilk_55
    hilk_55 [OP] Member
    Brendon
    First pic you can see the angle is not bad at all… second pic you can see where the cv axle failed
    AmateurTaco1313 and TWTaco like this.
  11. Nov 30, 2021 at 8:44 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Take some pics of the shock towers as one side is very different from the other side it seems.
  12. Nov 30, 2021 at 8:53 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    whats the bearings look like on the inside?
  13. Nov 30, 2021 at 8:55 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    i would also check to see if somehow your 4wd is engaged and you don't realize it or light isn't on.. Go under truck and try to spin front shaft by hand. If it doesn't spin its engaged. If it does spin then it isn't engaged .
  14. Nov 30, 2021 at 9:15 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    The pic where the angle looks steeper is because the axle popped out and is pointed upwards, can see below where the cup is...looks to be the same side to side.
    Angles don't look bad to me, weird this is happening
  15. Nov 30, 2021 at 9:34 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Diff drop bolts coming loose?
    Engaging 4wd and reverse, differential flexes, CVs bind and kapow. Worth checking at least.
  16. Nov 30, 2021 at 10:55 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I think this is the winner here. From what I'm gathering the original OEM ones just tore a boot, that can happen. The weird binding and popping out only happened once you put the auto store brand in. I recall reading that happening to someone else on here.
    https://www.tacomaworld.com/threads/cv-axle-broken-again.725946/page-2#post-25865721
    Typically the auto store ones have a warranty. I would get a new one under warranty just because you're owed one (or see if you can get refunded all together) and either get OEM new, reman OEM from CVJ, or I've had really good luck with Napa ones being put through some good abuse.
    Front locker on and eating away with Napa axles. They weren’t exactly under a lot of stress, but still.
    https://www.instagram.com/p/CRZbiK7FThg/
    BigWhiteTRD likes this.
  17. Nov 30, 2021 at 12:03 PM
    hilk_55
    hilk_55 [OP] Member
    Brendon
    02Duck and SR-71A like this.
  18. Nov 30, 2021 at 12:04 PM
    hilk_55
    hilk_55 [OP] Member
    Brendon
    OEM on the left is 2” longer than what advanced sold me. I think that’s the problem
    Mr-Paul, Lt. Dangle, Captqc and 2 others like this.
  19. Nov 30, 2021 at 12:10 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The joint that's closest to the diff has a lot of plunge, meaning the axle will lengthen or shorten as needed in the suspension stroke. Hold them the same way as that pic but push downward so the tupil is seated for a more accurate representation of length.
  20. Nov 30, 2021 at 1:31 PM
    HVLA
    HVLA Well-Known Member
    Idaho
    2020 Voodoo Blue OR DCSB 6MT
    Those are definitely NOT the same.
    02Duck and Mr-Paul like this.
