Custom subwoofer enclosure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TVCOK3N, May 22, 2020.
  1. May 22, 2020 at 12:21 AM
    TVCOK3N
    TVCOK3N [OP] New Member
    Kennedy
    Cement 2020 Tacoma TRD Sport 4x4
    Hey wussup TW any bass heads out there that have made a custom enclosures for there 3rd gen Tacoma double cab.Did some custom work in the past in some of my cars and this is my first truck I ever bought and there’s limited amount of space to work with then a truck of a car.
    Need a little inspiration was Thinking for taking out all the plastic storage behind the seats build a box in there or even taking the whole left side out and making a box there. I don’t really have passengers sit behind me sins I'm pretty tall and my seat is pretty much all the way back.
    I’ve bin doing some research on some boxes and there dimensions. But biggest bottom mount for sub they put in other boxes is around a 5.2” to 5.6” in 10” or 12” sub and it’s a problem I want to fit my 10” with a bottom mount of around 6.5”.
    Has anyone made a box and have put that size sub behind there without any major rubbing of the sub on to the seats.
    Plz Post your custom subwoofer enclosure Thanks in advance!!
  2. May 22, 2020 at 12:39 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    TVCOK3N[OP] and DAS Taco like this.
  3. May 23, 2020 at 6:41 PM
    Color_Me_Taco
    Color_Me_Taco Well-Known Member
    Doug
    Utah
    2022 TRD OffRoad, 2019 TRD OffRoad, 2021 Subaru STI, 2021 Kawasaki ZX6R
    ADD, Rigid, ToyTech, DBcustomz, Methods, Nittos, Powertank, Morimoto
    That price point tho. That's a little steep. Definitely paying to "save space"
    TVCOK3N[OP] likes this.
  4. May 23, 2020 at 6:44 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    TVCOK3N[OP], thebaker and su.b.rat like this.
  5. May 23, 2020 at 6:54 PM
    su.b.rat
    su.b.rat broken truck
    also have a Marv box with a 13TW5, sealed and on a 500/1 with a 5F Alumapro cap. had to remove all the plastic and be careful with dynamat so the box wasn't pushed into the seat. it's very close. with the seat up it touches the seat bottom, but doesn't touch with the seat down so you can do it depending on dimensions and excursion.
    if i could change one thing it would be to do full floor & ceiling deadening. i have way more bass than i can use. thanks for the JL bass knob.
  6. May 24, 2020 at 5:39 AM
    Ysrracer151
    Ysrracer151 Okopipi
    Nate
    Huntington beach
    Voodoo tacoma pro
    Mr marv is the highest quality! 2.2 cubic feet sealed behind seat. Two 12xt1s Rockford Fosgates. Probably the loudest subs to fit behind the rear seats so the truck still resembles stock
  7. May 24, 2020 at 5:43 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Is that coated with bedliner?
  8. May 24, 2020 at 5:46 AM
    Ysrracer151
    Ysrracer151 Okopipi
    Nate
    Huntington beach
    Voodoo tacoma pro
    Mr marv recommended duratex, its the stuff they use for concert equipment cases, roadie cases. Legit professional coating
  9. May 24, 2020 at 5:54 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Thanks for the info. I’ll look into it.
  10. May 27, 2020 at 8:54 PM
    TVCOK3N
    Kennedy
    Nice box I like it and man that sub looks huge back there lol I took some measurements back there with out the plastic to fit the same set up as you. If you don’t mind me asking if you could post up the dimensions of the box. Definitely need to dynamat the rear wall I have a Rockford Fosgate P3S 12 back there for now and it rattles like crazy.
    su.b.rat[QUOTED] likes this.
  11. May 28, 2020 at 8:20 AM
    rj_taco
    rj_taco Well-Known Member
    To maximize the space you would need to remove the brace, plastic covers from behind the seats, increase the seat lock out angle and remove the OEM sound deadner (too thick and uneven). Definitely not reversible to stock. You would have to get creative with the angles to fit a pair of 10s as low as possible.
    2 Sound Integrity BM 12" fit, they are really shallow though (3.4"). Had to use 1/2" plywood for the back, everything else is 3/4". Looking at some of the dimensions I have it looks like it will be a close fit for 10s @ 5-1/2" deep.
    Pray4Mojo, JR_BayArea and TVCOK3N[OP] like this.
  12. May 28, 2020 at 9:45 AM
    su.b.rat
    i'll try to get you dimensions later today. it's kind of a PITA to do it but if i get the time i'll post em up.
    TVCOK3N[QUOTED][OP] likes this.
  13. May 28, 2020 at 10:11 AM
    TVCOK3N
    Kennedy
    Wow that is hella clean man thanks for the feed back I was wondering about taking the rear brace out but had some second though on it. Change up my mind this couple of days looking at other boxes and setups and how clean it looks back there. Probably going to do the shallow mount route to maximize space with a single skar VD-12’s around 5” deep.
  14. May 28, 2020 at 10:13 AM
    TVCOK3N
    Kennedy
    Thanks man much appreciated!!
