Custom Phone Mount for Vent (3D Print)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KaBaL, Jul 15, 2017.
  1. Jul 15, 2017 at 8:28 PM
    KaBaL
    KaBaL [OP] Well-Known Member
    Northern VA (NOVA)
    2017 ORDC 4x4 White
    Brand spanking new...
    Hey all, just wanted to share my progress on a custom phone/device mount for the HVAC vent. I will admit I was inspired by the Hondo Garage one, I actually ordered it last week, but then realized it didn't let you fully close or adjust the vent once installed. I didn't like that approach so decided to go look at what I could do about it.
    I have a 3D printer, and mill, so figured I could come up with something.
    The first step was simply looking where I could mount my current phone mount. I'm a huge fan of the TecheMatte magnetic holders, they're made to slip onto the vent shrouds, but the Tacoma simply doesn't lend itself to these very well, they fall off and move around. I wanted to continue using this, but knew it needed to be mounted more securely.
    After looking around and not seeing any viable options for mounting locations that were clean and not protruding massively, I opted to pull the dash cover off. (I've already had it off to swap out the colored plastic parts). I presumed I could 3D print something similar to the Hondo version, but perhaps make changes, a simple clip on (snap in) version was my initial idea, since I'm not looking for ultimate "off road stability".
    Long story short, I discovered a neat little bonus from Toyota. The HVAC vent has some extra tabs on it a little lower from the default ones used for installation. These tabs, line up perfectly for installation, but leave a 0.225" gap between the vent and the front bezel. This is a perfect gap for some kind of spacer mount.
    The following are images expressing what I found.
    6RFqXTtgggkgcOwu6CPOMclvqsR-Lew4a-chc_hr_2abe485497f67459dfec7d46e40aa7dd148369b8.jpg
    Here are those tabs (red) default mounting, (blue) extra tabs that already exist and I utilize.
    YKwrdp4yFmKbCbhbr5WnKpa3tUENmEso9Idch9zu_e04adf114f1e5f9e659b7aa971b90be497ea61df.jpg
    Here you can see the gap that is created if you install the vent using those alternative snap points.
    gVkOiZad4MXjVkY0z-ijDJARzisDkgcmfM7KZnOl_3551912a18ef92145007189d383dd2fcebff004b.jpg
    3D Design prototype, this was version 3 or 4, the tabs on the outside are to keep the mount/spacer from rotating.
    k189s4On5zm3r0jUPSzJsh5TK6BfxL7cUy5usgnx_38d0f06be33ed8ee8b0b34e3016165253e476761.jpg
    This is the magnetic mount I prefer to use.
    wjcBY8AeOfQ7VZ78mb7ZGVERu8XpeA1i_UCcsut9_6e587740356daf52e52cd7145d2b17da37432a3a.jpg
    First printed prototype (note the missing outer tabs). This one ended up being a little too thick.
    L60DfCgYe1Hd9FWvOTWmDYcSrEh3Sru9dkS_wkfK_881eb82644d69005ca1d060ff5c39497835c0a0d.jpg
    QT7rEx-vmFI9J2xX2lRnh9NmRYkTHaHr1JjYmfdi_574ab96f5a2a8cb60a69b79e36194fec77b1f2d5.jpg
    Disassemble the magnetic mount.
    qpy5-VFtR109VdqVrZh6--INqQjo6Zg_M7wxZeJA_441e7d3df2a932402477b49d8c4318e736668dc0.jpg
    Mount the magnetic mount to the spacer-mount.
    9SXcFowwvROc6wypYtcqDrKGU0yrFiCbwUrsA2bo_02fa53e23478560abb424ff59f880e960293d572.jpg
    Re-assemble everything - note the vent closes fully.
    EW8FTYeHPongjiBWrLq8_x_u8F1xzS0mxq9kOzz7_68c1d1df2bb84205c61eaf746d71c84f88648ba6.jpg
    Re-assembled - note the vent opens fully.
    Cn-PNWsXy-hNd8Al0BDtKeJHif6YoKcqYz3fVpv8_440b2dccde53c73c06ace33c98c6343be4640270.jpg
    Installed
    So I'm still fiddling with things, but I currently have it installed (dark out so no fully-installed photos). I tested it, and it's as stable as can be. The vent still swivels and opens/closes. This design could easily facilitate other mounts or RAM balls quite easily, especially the "bar mount bolt-on version of the RAM Ball.
    I'll consider printing out some for those interested as well at a small fee (material and shipping).
    Those curious, I'm currently printing with ABS filament, a) because it's what I had loaded in the printer already b) it holds up better to heat, since this will be a mounted inside a potentially hot vehicle and used in the heat vent.
    Thanks, and enjoy!
    **UPDATE**
    Decided to attempt a RAM mount (1" ball) but the bolt on version looked like it would be a bit much to mount, so for a concept, I simply printed a version with a 1" ball on it to test. I know up-front this isn't a design I'm interested for my own needs, but know others might like it.
    eFetL_Z_fIxFgp6WkVtbIiQhP3zQTPWpaz8MzePE_e9b6f19e730a2c567f9130aa98015bbd91752f55.jpg
    LTIgfDqI3q8kE0Tk2Ej_W5lKUrkujVrtwMCp_Zoq_8a4f7fb4f4b857f860de218b89e7ec3b182c2845.jpg
    I already know it sticks out a little far, but wanted to test for clearence, etc. I can probably push the "stick-out" back in ~0.500"
    C6SqAnPPrhqC5_hYbBSToXUco5gImaCBp-56d2PG_a1a1917b835a0a4eaa2ac962bf6390414d054e54.jpg
    Here it is with a RAM X-Mount (small) - this is the only RAM product I own (for the street bike).
    dSTI2so8ZjSzEPXChY4PS6wL6JMDcw4TB0brAAwv_693c5adf2896e7b136c314ce3232baa66dd662d7.jpg
    cbNfGpY6CEGbxMp0W0a2mFUmh7N76gozmpNu8FaM_a524a8f87f7ab9e84c515d757cefc03084be9a74.jpg
    In the photos I have it positioned in the top, as that seems the most reasonable, but it can go anywhere really. Looking for feedback.
    Thanks
    Vinny C, wee, Manfred and 18 others like this.
  2. Jul 15, 2017 at 8:28 PM
    KaBaL
    Northern VA (NOVA)
    2017 ORDC 4x4 White
    Reserved
  3. Jul 15, 2017 at 8:33 PM
    Sedyn
    Sedyn Well-Known Member
    Justin
    Vancouver, BC / Sumas, WA
    17' TRD Pro, Cement.
    Definitely interested.
  4. Jul 15, 2017 at 8:36 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Definitely interested, esp since I use the magnetic mounts similar to that and have the vent ones but it doesn't play well with our types of vents.
  5. Jul 15, 2017 at 8:39 PM
    KaBaL
    Northern VA (NOVA)
    2017 ORDC 4x4 White
    This is exactly why I decided to make this. I have multiple versions of the magnetic mounts. Some use a screw, some have the clamp part mounted directly to a threaded rod, so variants exist. So trying to finalize a more "universal" mounting method, especially for other options (RAM mount, etc). Thinking simply provide a recess, and let whatever wants to be mounted to be nut/bolt fixed to it.
    Literally just got it going, but thought I'd share to get feedback / thoughts / ideas
  6. Jul 15, 2017 at 8:42 PM
    Tacowin1013
    I think there's a great niche for this type of low profile mount. I have a magnetic windshield mount that I currently use. I like the usefulness of the Hondo mount but it's much too bulky for my tastes. If you need a tester to give you feedback, I'd be more than happy to pay you shipping and give feedback.
    KaBaL[QUOTED][OP] likes this.
  7. Jul 15, 2017 at 8:49 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Nice. +1 for fusion360!
    KaBaL[OP] likes this.
  8. Jul 16, 2017 at 5:30 AM
    smuckers
    smuckers :: cough cough ::
    Los Angeles
    Wish list: 17 TRD OR DCSB 4X4 6MT
    Add me to the list please!
  9. Jul 16, 2017 at 7:45 AM
    scottsglock29
    scottsglock29 Well-Known Member
    Scott
    Wisconsin
    2019 Cement TRD Sport DCSB
    Looks like something that I could definitely use.
  10. Jul 16, 2017 at 7:46 AM
    ponts
    ponts Well-Known Member
    I'm in for one. Please add me to the list. Thanks
  11. Jul 16, 2017 at 7:57 AM
    matt636
    matt636 Well-Known Member
    Central, IL
    2017 TRD Sport 4x4 DCSB Inferno
    this is a great idea! I currently use a vent clip style, and when my phone isn't in it, it rattles like crazy and drives me INSANE! this looks to be very solid and sturdy! But, I use I Magpul bump case on my iPhone, and I've never tried the magnetic mount but assume it wouldn't be strong enough to make it through my case?
  12. Jul 16, 2017 at 8:21 AM
    su.b.rat
    su.b.rat broken truck
    watching this. looks nice, also watching the bar mount development.
  13. Jul 16, 2017 at 8:45 AM
    T$$
    T$$ Well-Known Member
    2017 TRD OR MT
    I'm interested too. Good work.
  14. Jul 16, 2017 at 8:51 AM
    KaBaL
    Northern VA (NOVA)
    2017 ORDC 4x4 White
    Send me an image or product page of the mount that you use, I'd be curious if it would lend itself to this type of fixture. As for the magnetic mount, they come with adhesive metal plates you can either put on your phone or simply between the case and the phone, they work quite well actually, but I've only ever tested on thinner cases.
  15. Jul 16, 2017 at 8:54 AM
    KaBaL
    Northern VA (NOVA)
    2017 ORDC 4x4 White
    Thanks, I'll be pulling the RAM ball off my motorcylce today to give it a try and see how sturdy it is when fully mounted on a plate. I personally won't run with it, as the extra mounting hardware required for the RAM stuff is way to much to have sticking off my dash (personal preference), but know some people love it.
    I'm also looking to see if it would be worth it to mill out an aluminum version as well, not sure if it's worth my effort, but I'm sure I'll do at least one prototype and judge from there.
    su.b.rat[QUOTED] likes this.
  16. Jul 16, 2017 at 9:00 AM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    I'll take one as long as the installation isn't crazy. I really don't want to have to rip my dash apart.
    Do you have to remove the dash to install this?
  17. Jul 16, 2017 at 9:06 AM
    KaBaL
    Northern VA (NOVA)
    2017 ORDC 4x4 White
    I thought it was obvious from some of the photos, but I presume not. The bezel surrounding the radio, has to be removed, it's one piece spanning both center vents. It's easy to remove, grab above/below the radio where there's a lip easy to grab, and pull out. If you can't do this, or don't want to, then move on as this is a required step in order to install.
  18. Jul 16, 2017 at 9:08 AM
    RIDERED67
    Yea I wasn't sure if you removed extra stuff to work up your design
  19. Jul 16, 2017 at 9:13 AM
    KaBaL
    Northern VA (NOVA)
    2017 ORDC 4x4 White
    Ah, nope, everything can be done from that one bezel/trim panel. The vents are secured onto that piece (three tabs), it all comes apart quite easy. But I have experience working with fiddly plastic crap and have the right tools, so I'm sure for some, it might take some effort. Depending on how far this goes, I might make a full installation video.
  20. Jul 16, 2017 at 9:14 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Good work OP!
    I'm sure that'll look good too, but to much work for me. I'm lazy and don't want to permanently change the appearance yet, in case I decide to trade for more (TSS) safety features in '18-19? But maybe 10yrs down the line If I keep it lol!
    This is what I use, (magnet mount) it just tapes on top and I let the phone rest on dash for extra support. I've had it for over a year, hasn't fallen yet.
    Keep those innovation ideas coming!
    Cheers!
    arnette64 likes this.
