Custom HD relay/ fuse terminal
Discussion in 'Group Buys' started by Spencer, Feb 4, 2013.
Thread Status:
Not open for further replies.
  1. Feb 4, 2013 at 6:18 PM
    Spencer
    Spencer [OP] Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    This one comes from Dave over at
    http://www.autotrendefi.com/
    After looking around and finding nothing that suits my standards for a solid one piece relay/ fuse terminal combo, I found Dave who makes them with OEM parts, epoxy and quality. I plan to run two lightbars on a few separate circuits for spots, floods etc- body lights, under hood lights, reverse lights, power outlet under the hood... and the list will add on and on over time.
    Agreed, you can piece together radioshack parts, or go with any number of other bussman type DIY setups, but you won't find this part anywhere but this group buy. this will be made with OEM type epoxy and molded plastic, not plug together parts.
    Here's an example of what it'll look like-
    The relay we're buying will have prewired:
    • EIGHT 40 Amp relays, rated for constant 40A use, all 12V+ switched
    • One of these 8 powers Four separate fuses
    • 7 relays control 7 seperate fuses (one each)
    • SIXTEEN total fuses:
      Four 20A fuses switched from 1 relay
      Four 20A fuses wired for constant 12v power
      Eight 30A fuses protect all 8 relayed circuits.
    INPUTS:
    • Main battery input will be 3/8" stud type terminal block to handle 100% capacity of the whole terminal
    • One switched 12V+ input from engine on controlling one relay to 4 fuses (or your own switch)
    • Seven 12V+ inputs controlling the other seven relays
    • One common relay ground
    OUTPUTS:
    • Seven relay outputs 12 gauge wire leads 12" long
    • Eight fused outputs 16 gauge wire leads 12" long
      (4 constant hot, 4 hot only with key on)
    Here's what yours will look like: (Prototype model-Minus the 12" wire pigtails of course)
    Group buy ends March 1st
    payments taken over the phone to him or PayPal at the end of the group buy after price break is determined.
    Cost breaks:
    20+- $334 each
    11-20 panels- $358 Each
    1-10 panels- $378 Each
    The price breaks may go lower if we get enough interest.
    Yes. it's pricey. hopefully we can get it lower.
    My justification here:
    • I just dropped $35,000.00 on my Tacoma. Trying to save $100.00 on a vital setup component is a bit like using a ziplock as a rubber. It'll probably work... hopefully...
      What's spending less than one percent of the value to do it right?
    • I know the importance of laying solid groundwork before expanding- nothing more *facepalm* than having your $500.00 light bar setup melt the $5.00 ebay chinamade relay and (in my case) start a wirefire along with it.
    • This unit will very likely cover every new circuit you plan to run SAFELY and SIMPLY to avoid your octopus orgy wire job and save you from running hot power through your in cab switch.
    • nothing's more satisfying than a clean, neat wiring setup you never have to touch again.
    Hopefully these images embedded correctly, and hopefully we can get over 25 & help everyone out. anyone? :)
    1. SPENCER
    2.
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    10.
    11.
    12.
    13.
    14.
    15.
    16.
    17.
    18.
    19.
    20.
  2. Feb 5, 2013 at 6:47 AM
    Spencer
    TIGGLEBITTIES
    Bump....
  3. Feb 5, 2013 at 6:55 AM
    BytorTruck
    BytorTruck Well-Known Member
    Brandon
    Scottsdale AZ
    Not to HiJack the thread, but have you seen the Spod? I put one in our jeep, super slick one wire into the cab for the switch panel. It even has low voltage protection.
    http://www.4x4spod.com/category_s/52.htm
  4. Feb 5, 2013 at 8:46 AM
    Spencer
    TIGGLEBITTIES
    well damn. looked all over & never found that...:facepalm:
    well now what.
  5. Feb 5, 2013 at 9:07 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Hmmmm....
  6. Feb 5, 2013 at 9:13 AM
    DHwreckage
    DHwreckage Well-Known Member
    Boulder, CO
    Moby Dick (FZJ-80)
  7. Feb 5, 2013 at 3:40 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    nicely thought through in a compact prototype package. It looks like you have the bases covered.
  8. Feb 6, 2013 at 1:15 AM
    Spencer
    TIGGLEBITTIES
    Haha it was great until I saw that SPOD...
    Well as a courtesy to Dave who took the time to design this thing for me/ us, I'll leave this thread going in case anyone is interested in this thing.
    Otherwise...
    Howbout that Super Bowl eh? Haha
  9. Feb 6, 2013 at 9:22 AM
    BytorTruck
    Brandon
    Scottsdale AZ
    lol.....sorry :)
  10. Feb 7, 2013 at 10:27 PM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    all these ideas and suggestions are great, but id just like to carry one type of fuse type...like the mini used in factory fuse boxes
  11. Feb 8, 2013 at 6:48 AM
    Spencer
    TIGGLEBITTIES
    Do they make a 40a mini fuse? & I never had a problem with minis till I had to figure out how to tap a hot lead into my compressor relay circuit-
    I had plenty of those little s shaped doodads that let you tap into regular fuses and plenty of male flat tab wire connectors that fit perfectly into a fuse spot, but nothing at all that worked with minis.
    Two fuse types would be great for me.
  12. Feb 11, 2014 at 6:24 AM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    OP, you might want to look at AutoRod controls. I have their 8000 series relay panel and switches.
    $294 from Amazon
    Manufacturers page
    My relay panel installed in a pelican case under the hood.
    The EMP proof switch panel that comes with it. The switches can be set to momentary or full on/off. There is also a master switch that kills the entire panel. I currently have my switch panel in the center console, but I'll be moving it up to the headliner soon.
    Just some food for thought. Good luck with your selection.
  13. Feb 11, 2014 at 6:56 AM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
  14. Feb 11, 2014 at 8:56 PM
    Spencer
    TIGGLEBITTIES
    I actually went with the sPOD after this thread- check out my build thread for pics etc. it's one of the first ones I did to my truck. They built me a custom switch panel and did one hell of a job at it too. Got take a look and call em up! they've made two or three more after people keep seeing my build thread.
    isnt cheap. but worth every single penny.
    Works perfectly, and has my entire Aux. electrical circuit isolated and safe with the low voltage cutoff.
  15. Dec 8, 2014 at 7:47 PM
    skygear
    skygear                    
    Holly shiet./// Damn Spencer, sell that SPOD and get a real box ;)
  16. Dec 8, 2014 at 8:46 PM
    Spencer
    TIGGLEBITTIES
    haha hey man have you seen my switch panel? I'm keeping that spod forever it's so clean!
    Though I have started to outgrow it already.... I needs more power. Trying to prepare for a winch / dual OBA compressors and they'll draw too much for any one relay. using one relay to power another seperate set of relays kinda defeats the whole purpose aside from keeping a super duper clean switch panel on my center console....
  17. Dec 9, 2014 at 7:41 AM
    skygear
    skygear                    
    Look at the ones I have been selling. Linked in my signature. 100% compatability with all other switch panels on the market
Thread Status:
