Custom Bed Rack Build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DrWeld, Apr 15, 2018.
  1. Apr 15, 2018 at 6:47 PM
    DrWeld
    DrWeld [OP] Well-Known Member
    Southern CA
    '18 Cement Off Road
    2” Bilstein shock lift in front
    Before buying my truck I knew that a overland build was the way I was going to go with it. I know there is a lot to a overland build but as a welder I knew there would be some things I could build on my own. My first build I decided to do was a bed rack. For one I had the material already and I knew that I be able to continue to mod and adapt it to my growing needs. I looked for weeks online at different styles and eventually came up with a mash up of different designs. Here is my progress so far and will continue to update as I modify it. I'm already planning brackets for lights, fuel cans, jack, shovel, etc.
    Material used:
    main rack: 1-1/2" tubing
    mounting brackets: 3"x 3" x 1/4" angle
    tire stand off: 1" tubing
    tire hoist is off the truck from under the bed
    I decided to paint it instead of powder coating because I knew I would be grinding and welding on it and didn't want to put money into that and just grind it off later. I used a tractor primer paint and good old flat black rust-oleum all roll on. When I rolled on the primer it gave it a cool texture simmer to hammered look. I liked it so I left it that way. I'm planning two coats for the top color. IMG_4112.jpg IMG_4114.jpg IMG_4122.jpg IMG_4124.jpg IMG_4126.jpg IMG_4127.jpg IMG_4129.jpg IMG_4134.jpg IMG_4139.jpg IMG_4141.jpg IMG_4150.jpg IMG_4152.jpg IMG_4162.jpg IMG_4172.jpg
  2. Apr 15, 2018 at 7:33 PM
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    Looks great!
    New option for purchase in TW? lol
    Zulupapa and DrWeld[OP] like this.
  3. Apr 15, 2018 at 7:37 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Dude nice!! I'm making one similar myself, and was going to put the tire in the same spot. Looks great in that location.
    GillyLink and DrWeld[OP] like this.
  4. Apr 15, 2018 at 7:40 PM
    DrWeld
    Southern CA
    '18 Cement Off Road
    Thanks! I look forward to see what you come up with as well.
    GillyLink likes this.
  5. Apr 15, 2018 at 7:51 PM
    MESO
    State of Jefferson
    my idea was to bring the tire up as high as possible(almost flush with the top bars). I noticed yours arent quite as high as the cab. Any particular reason? RTT?
    DrWeld[QUOTED][OP] likes this.
  6. Apr 15, 2018 at 7:59 PM
    DrWeld
    Southern CA
    '18 Cement Off Road
    I used the tire hoist from under the truck so I needed the space for that. I'm kind of glad I did because it give a little more visibility out the back window.
  7. Apr 16, 2018 at 12:30 AM
    FrayAdjacent
    FrayAdjacent Well-Known Member
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    Nice work! Looks excellent.
    DrWeld[OP] likes this.
  8. Apr 16, 2018 at 6:08 AM
    GruntledCitizen
    GruntledCitizen Well-Known Member
    Fresno, Ca
    2018 Quicksand TRD OR DCSB
    TRD pro grill Volk racing te37x 16x8 -20 offset Toyo Open Country MT 265/75r16 Meso ultimate led turn signal EGR rain guards
    Very nice looking rack. I like the tire placement as well.
  9. Apr 16, 2018 at 6:36 AM
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    Looks great!
  10. Apr 18, 2018 at 6:23 AM
    Zulupapa
    Zulupapa Bah-Weep-Gragnah Weep Ni Ni Bong
    Waterloo Region Canada
    2017 Tacoma TRD Sport Inferno
    very nice and great lines to it!
  11. Apr 18, 2018 at 5:02 PM
    DrWeld
    Southern CA
    '18 Cement Off Road
    Update:
    Finished the top coats of the the flat black rust-oleum. The rack is extremely easy to install and remove if ever need to remove it down the road. My thoughts are to incorporate my own style of bed stiffeners. I’m happy with how the tire hoist came out. Can’t wait to get some fuel cans on it with some other trail recovery equipment. D4766E6C-14CA-45E1-B82B-B0211DE08F3E.jpgE1F16CF7-EC00-4104-B8F8-46D188BA91BD.jpg
  12. Apr 18, 2018 at 5:05 PM
    catastrofe
    Bob
    Montrose, CO
    2022 F350 Tremor
    Build it, and they will come. :D
  13. Apr 18, 2018 at 5:08 PM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    I like that bed rack. Nice job!
  14. Apr 18, 2018 at 7:30 PM
    GruntledCitizen
    Fresno, Ca
    Wtb half rack in similar configuration... Lol
  15. Apr 18, 2018 at 7:52 PM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    the tire hoist is awesome! ive never seen that on a bed rack. great job!!
    OneFastGeek and DrWeld[OP] like this.
  16. Apr 18, 2018 at 7:58 PM
    Superman
    Superman Well-Known Member
    Joe
    Michigan
    2017 Quicksand TRD OR DCSB
    Current: Behind rear seat MOLLE panel Softopper Empyre grille insert MesoJDM ultimate red maps MesoJDM ultimate white dome Future: BajaRack roofrack/basket Mobtown bolt-on sliders Mobtown rear plate bumper Mobtown front plate bumper On-board air compressor Ditch lights LED headlights (blacked out) LED taillights (blacked out) LED yellow fog lights Bedrack over softopper Maxtrax
    What equip was required for this rack build?
    I'm looking to build my own but need the tools first :)
  17. Apr 18, 2018 at 9:03 PM
    DrWeld
    Southern CA
    '18 Cement Off Road
    Thanks. I’ve see racks with the tire in that position before but didn’t know how they did it. I also knew I didn’t want to be lifting and holding it in place trying to thread some kind of nut on all thread. I just thought why not use what’s already on the truck.
    hirod and GoGoGadget like this.
  18. Apr 18, 2018 at 9:04 PM
    GruntledCitizen
    Fresno, Ca
    It's a great idea.
  19. Apr 18, 2018 at 9:07 PM
    DrWeld
    Southern CA
    '18 Cement Off Road
    Man where to begin!
    You’ll need a good tube/pipe bender, welder, a couple different angle/degree finders, a good saw, various hand tools and a notcher but you could do that with a grinder but it’s easier with one.
  20. Apr 18, 2018 at 9:10 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Incredibly well done!!
