Custom Battery Hold Down
Discussion in '2nd Gen. Tacomas (2005-2015)' started by No-Limits, Mar 13, 2020.
  1. Mar 13, 2020 at 5:06 AM
    No-Limits
    No-Limits [OP] New Member
    Steven
    06 TRD 4x4 4.0
    Hello,
    New to the Tacoma forum. This might be a dead issue, However I saw a really nice custom TRD battery hold down and was curious if still available. Have a 2nd gen 4.0 and would really like to get one.
    cheers!
  2. Mar 13, 2020 at 5:35 AM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
  3. Mar 13, 2020 at 7:22 AM
    jadesparrow
    jadesparrow Well-Known Member
    Tim
    San Angelo, TX
    2011 White Tacoma 4.0 V6 4wd
    3" lift, ARB bumper
    Used an aluminum flat bar from home depot cut down and drilled 2 holes big enough for the stock plastic bushings.
  4. Jul 3, 2022 at 3:51 PM
    TacoTuesday1
    FL
    Is there a functional point to an upgraded hold down?
    Dealer sold me an OEM battery, that's larger size for more winter cranking amps. I think the heavy duty version. Parts dept guy told me that's all they sell and recommend. It fit just fine.
    Have had zero issues with the hold down. It's thin flimsy cheap stamped metal, which may be a good thing if any slight bending means it holds tension/downward pressure on the battery.
    Versus something solid/billet without deflection, that places all the stress on tiny threaded rods at each end.
    Is there an actual point to blowing $50-100 on a metal bracket, functionality-wise?
    Let alone restricting yourself to being stuck with one particular type of bracket, that may not fit if you change to a different type of battery later on?
    Or is it just for looks?
    I've gotta say. If anything/out of all the brands, I'd probably want to go with SDHQ.
    It looks like they're the only one that also offers upgrade J-hooks; and their clamp price is cheaper than competitors as well
    I'm very happy with the terminal kit upgrade I have from them (still running strong); and this would match
  5. Jul 3, 2022 at 6:24 PM
    Waasheem
    Waasheem
    2007 xrunner
  6. Jul 4, 2022 at 12:47 AM
    Titanx85
    Titanx85 Well-Known Member
    AJ
    Between Lexington, VA and Richmond, VA
    2006 Red Tacoma crew cab long bed
    wi_taco likes this.
  7. Jul 16, 2022 at 7:51 PM
    whiskeybiscuit
    whiskeybiscuit Well-Known Member
    Pretty sweet hold down great links!
