Cup holders to fit bed tie-down rails?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FirstTracks, Sep 10, 2013.
  1. Sep 10, 2013 at 5:44 PM
    FirstTracks
    FirstTracks [OP] Well-Known Member
    Marc
    Salt Lake City, Utah
    07 Tacoma Access Cab 4.0L V6 SRS 6sp manual
    Leer cap, BedRug
    I've been camping a bunch this summer in my 2007 4WD Access Cab with a Leer camper shell, and we're permitted for a three-day trip on the White Rim in Canyonlands near Moab in early November. When settling in for the night I've imagined that there must be a company that makes cup holders that clamp into the tie-down tracks on the Tacoma's bed rails. I'd love to get my hands on a couple before the White Rim but I've just spent the last 90 minutes searching the Net and found absolutely nothing. Does anyone know if there is such a thing and where I can get them?
  2. Sep 10, 2013 at 5:46 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    I made some once and used them last summer a lot for tailgating but I put them up and I can't remember what I did with them lol
  3. Sep 10, 2013 at 6:00 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    QuickFist?
  4. Sep 10, 2013 at 6:01 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Were you drunk in the Taco? :rimshot:
  5. Sep 10, 2013 at 6:06 PM
    FirstTracks
    Marc
    Leer cap, BedRug
    I'm sure that I could Jerry rig something but I'm lazy and not incredibly handy, so I figured that there must be an obvious solution out there somewhere.
  6. Sep 10, 2013 at 6:12 PM
    KenLyns
    Belly of the Beast
  7. Sep 10, 2013 at 6:16 PM
    drunktaco
    Sage
    Southwest Va
    On occasions I have been :anonymous: and those with a lawn chair and cooler in the bed makes for a killer time at a bonfire, baseball game, ect. I wish I knew what I did with them now. I might have to try and make more. I just cut pipe and welded tabs that slid into the rails on one side and offset them so they would stick out a little bit. I made them big enough to stick a koozie inside them to keep beverages cold. Worked great actually. Just a bitch to snag your leg or something on though.
  8. Sep 10, 2013 at 6:31 PM
    FirstTracks
    Marc
    Leer cap, BedRug
  9. Sep 10, 2013 at 6:59 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    You don't have enough cup holders already? :)
  10. Sep 10, 2013 at 7:45 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    I definitely have 13 on my DC... :drunk:
  11. Sep 11, 2013 at 5:18 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
  12. Sep 11, 2013 at 8:18 AM
    jw1983
    Alberta
    Did you know that your hand is a cup holder? :)
  13. Sep 11, 2013 at 8:44 AM
    FirstTracks
    Marc
    Leer cap, BedRug
    Ha! True, but after I rolled over in the middle of the night and in so doing Sent my wife's phone for a swim in a glass of whiskey I've been looking for a better solution. :D
  14. Sep 11, 2013 at 9:08 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I saw some magnetic coosies good for 60mph and it had the Toyota emblem on it so win win.
  15. Sep 11, 2013 at 9:31 AM
    jw1983
    Alberta
    Did you tell her that you were having a dream and it was to see if her phone was water and alcohol resistant?
  16. Sep 11, 2013 at 12:50 PM
    FirstTracks
    Marc
    Leer cap, BedRug
    No water involved. That's just not how I roll (over).
  17. Sep 11, 2013 at 4:08 PM
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    I don't know if you're much of a fabricator, but since I am, here's what comes to the top of my head.
    Run down to your local Homey Despot and pick up a piece of 4" black ABS pipe and a cap to fit. And some ABS cement. Glue the cap to one end. Measure to your liking, cut. Drill a hole for the mounting bolt, and use whatever T-bolt fastener you prefer (you could always use the OE cleats separated from their rail mounts).
    You should have more than enough leftover pipe to make another half dozen cup holders, too!
    Want a little more extension? Stick a section of 1/2" PVC pipe between the mount and the cup holder. Or a piece of heater hose. Or a metal spacer. Or anything hollow and able to be cut to size.
    Want a little wobble to it? Bend a piece of 1/8" thick bar stock into a U that fits around the cup holder, drill a hole on either end (to mount to two opposing sides of the cup holder), and a hole in the middle (to mount to the rail mount).
    Fully customizable, something you can point to and say, "I made that!", and less than $10. And less than a half hour of work.
  18. Sep 11, 2013 at 4:36 PM
    FirstTracks
    Marc
    Leer cap, BedRug
    I'm not much of a fabricator so I'm lost at envisioning this stuff, but once someone makes it that obvious I'm off and running. Thank you! The key for me is that I wasn't aware that those t-bolts or t-nuts were relatively commonplace. Thanks to all for the education!
    I think in the end I'll use t-nuts and regular bolts to attach those fold-up cup holders that I can find cheaply. That way they can be freely positioned wherever desired, yet fold out of the way when not in use. But then again I may change my mind 5 more times.
  19. Sep 11, 2013 at 4:45 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Hey, i just found a use for the cubby holes in the bed. Thanks OP! :)
  20. Sep 11, 2013 at 5:01 PM
    jw1983
    Alberta
    The beer is always cold in the winter time. :)
