Cup holder by center console gets hot
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mexicoma, Oct 14, 2017.
  1. Oct 14, 2017 at 10:27 AM
    Mexicoma
    Mexicoma [OP] New Member
    2017 Toyota Tacoma TRD OFF ROAD Red
    Greetings all! I travel with a Yeti cup full of water. I noticed after 2hours that when I picked up my cup and touched the bottom, it was really warm. I felt around the floor by the shift lever and it was cool. Then I felt between the seat and the console and it was very warm. The top of my Yeti was still very cold. Has anyone else experienced this? And I had my tranny fluid checked and it was 1/4 quart low. Could that have caused it?
  2. Oct 14, 2017 at 10:36 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Welcome to TW.
    How much did that Yeti cup set you back?
    Pella and Hobbs like this.
  3. Oct 14, 2017 at 10:42 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    LMGTFY
    fatfurious2, rtzx9r, nphagert and 2 others like this.
  4. Oct 14, 2017 at 11:04 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
  5. Oct 14, 2017 at 11:06 AM
    Sand Shark
    Sand Shark I dont pub crawl.when I do,I use pub crawl control
    Erich
    Phoenix, AZ
    2017 Blazing Blue DCSB Off-Road (yes I get dirty)
    REI VIP Parking Pass,Pavement Avoidance System
    The power inverter for the bed outlet is there. The vent is at the back of the center console. Check if it is blocked.
    tcjacado likes this.
  6. Oct 14, 2017 at 11:09 AM
    tcjacado
    tcjacado Well-Known Member
    Do you have the 400 watt power inverter?? Which cup holder there are 3 for AT... two below climate control and one behind the gear shift with the square hole. If it is the one by the square hole. I think the power inverter is under it.
  7. Oct 14, 2017 at 11:19 AM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    The two below the climate control knobs get warm on mine....it's an auto trans.
    Herniator and tcjacado like this.
  8. Oct 14, 2017 at 11:38 AM
    Sand Shark
    Erich
    Phoenix, AZ
    The inverter doubles as a coffee warmer.:thumbsup:
  9. Oct 14, 2017 at 12:31 PM
    Mexicoma
    Lol! $22 on Amazon for my Yeti. Also have a Mallome with a spare lid and straw we got for $20 on Amazon. Back to Taco, mine is an automatic. And it is the cup holder behind shifter. It could have been the inverter vent because we were traveling with the seats folded down. But I thought it was turned off.
    hrivera007 likes this.
  10. Oct 14, 2017 at 2:49 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    hmm rip out power converter(aint worth a crap anyways) install ham radio.....
  11. Oct 14, 2017 at 6:42 PM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    I’ve noticed the same with my truck, manual transmission 2nd gen also with a Yeti. I think the transmission tunnel just gets hot. Someday I’ll probably insulate to backside of the cup holder to help prevent it.
  12. Oct 15, 2017 at 4:31 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    The console is above the transmission tunnel. Transmission gets warm. Might be some other stuff generating heat there too.
    digitaLbraVo likes this.
  13. Oct 15, 2017 at 7:03 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Like what was said above. Center console sits directly above the transmission. All that air space heats up real quick. If you were to take off the center console trim you’d see the difference. I’ve had my interior disassembled and driven after and just putting your hand over the center hump you can feel the heat.
    Just pop everything open and put some thermal barrier around the backside of the cupholder if it’s an issue.
  14. Oct 15, 2017 at 7:06 AM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    I once was fiddling under the radio while sitting at a red light. Bout burned myself on the tranny tunnel under the console. Hot day, hot truck, owfuck
  15. Sep 26, 2022 at 7:10 PM
    Intrepid
    Intrepid Well-Known Member
    Jeff
    Toronto, Ontario CANADA
    2018 Tacoma TRD Sport double cab short box manual transmission cement grey
    ARE canopy with sliding screened windoors and rhino roof track, Warn semi-hidden winch mount with VR 10 winch, nightrider 28" single row LED lightbar, Hood scoop light bar, Anytime front and rear cameras. anytime Navigation switch, plug-in oil pan heater, plug-in block heater, plug-in battery blanket. WINTER: Snow Sport plow with back-drag modification, Bridgestone Blizzak DM V2 on steelies 265-70-17.
    Just experienced this in my truck with a new Yeti... What a relief to come to Tacoworld and be reassured it wasn't a huge issue!!!!
    Kalebscott and AmateurTaco1313 like this.
  16. Sep 26, 2022 at 7:32 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    You could heat up a can of beeny weenies in the cup holders in my C6 Corvette.
    AmateurTaco1313 likes this.
  17. Sep 26, 2022 at 7:38 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Felt it on my right lower leg driving with the cruise control on the other day. Also yeti is worth the coin, laughable all the people who say “buy once cry once” with truck parts then won’t invest in coffee or booze vessels
