Cub Cadet not turning
Discussion in 'Garage / Workshop' started by JRFugitt, Mar 10, 2014.
  1. Mar 10, 2014 at 6:12 PM
    JRFugitt
    JRFugitt [OP] Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    Any lawnmower mechanics out there? My Cub Cadet i1042 Zero turn tractor isn't working right. When I turn right far enough to activate the zero turn feature, it limps around the corner but when I turn left it works fine. Every now and the after a right turn the forward speed is reduced so I will hit reverse and then the forward speed is fine. Sometimes coming out of a right turn I can feel the steering bind. All the belts have been checked and the front steering linkage is greased and not the binding issue. I have checked both rear brakes and they seem to be working fine and not frozen. I think it is in the drive linkage to each rear hydraulic motor. This linkage is triggered after a certain amount of input from the steering. Such a great mower hate to loose it and no reputable shops around here that want to sell me a rear hydraulic motor that it doesn't need. Any help would be appreciated. Thanks!:confused:
  2. Mar 10, 2014 at 7:30 PM
    JRFugitt
    Justin
    Texas
    '13 PreRunner V6
  3. Mar 15, 2014 at 7:30 PM
    JRFugitt
    Justin
    Texas
    '13 PreRunner V6
    Buuuuummmmp
    This may be the first time Tacoma World can't answer my question!
  4. Mar 15, 2014 at 7:58 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
  5. Mar 28, 2014 at 6:40 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Is there any fluid loss from the hydro units? I'm not familiar with cub cadet rider-zero turns, but am a certified tech for exmark and Dixon ZTR and most familiar with their hydro systems. Exmark mowers (typically) have a pump and drive motor, are these just a single unit? If it is, which is probably a hydro gear brand unit, they are typically throw away hydros because the labor for teardown is too much.
  6. Mar 29, 2014 at 4:57 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    The reason that no one answered or replied to you may be that you made it very clear that you didn't want to hear that it had a bad hydro... Everything you describe....to me...points to a bad hydro.
  7. Apr 5, 2014 at 1:44 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Is there an adjustment to each steering valve on the pump? Typically there is to keep it trimmed going straight.
    Did you mess with these adjustments at all... even before things got bad?
