Crush washer part # for hydraulic brake lines
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jolly Onion, May 5, 2017.
  1. May 5, 2017 at 11:17 AM
    Jolly Onion
    Jolly Onion [OP] Cheap is not Good & Good is not Cheap
    Alex
    Forest Hills, N.Y
    2004 Tacoma 6cyl crewcab
    Hello Gents
    I have purchased 3 hydraulic lines for my 2004 Tacoma, wil be replacing them soon and change the brake fluid to DOT 3/4.
    The new lines did not come with crush washers, and I prefer to change them (might as well). I think I need 6 in total correct? (2 for each line X 3 lines).
    I do need the part number for them please.
    Thanks
    Alex
  2. May 5, 2017 at 2:39 PM
    Glamisman
    Glamisman Well-Known Member
    or... if you have a Harbor Freight close by they sell a multi pack of copper washers. My local dealers, 3 of them, did not have the crush washers in stock.
  3. May 5, 2017 at 4:42 PM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    I appreciate that info as a backup.
    But for an inexpensive item like this, I rather use Toyota ones. Last thing I need is a leak because of a $3 part.
    if you have a part #, I will find it on the web and buy it. Can't find the part #
    Thanks
    Alex
  4. May 6, 2017 at 7:09 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Just email your question at a good oem parts dealer like Camelback Toyota (or pm @gunny1005 whose a rep for them) or partznet.com.
  5. May 6, 2017 at 7:42 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Copper washer/gasket are pretty much all the same. Any Ace Hardware will have a bulk assortment you can pick from. Dealer wont be as cheap as you think. I'd bet at least $5 for each one.
    Dalandser likes this.
  6. May 6, 2017 at 8:19 AM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Thanks gents
    Will look at alternative if I do not find a part #. I will also check Amazon.
    The hardware store copper washers may be thicker/thinner have a different diameter , etc. And they may look like copper bit be inferior material from overseas. I have seen this with several items (non Toyota).
    But I appreciate all the replies. I wil find the part # and buy OEM.
    Alex
  7. May 6, 2017 at 8:25 AM
    v5ensx
    v5ensx CARB legal is not CALI legal
    Please tell us you at least purchase oe toyota brake line since you're looking for oe crush washer.
  8. May 6, 2017 at 8:26 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I buy mine from McMaster -Carr with my fumble fingers I go through quite a lot to just replace one line
    I did buy 10 from the dealer but it has been years
  9. May 6, 2017 at 8:34 AM
    mechanicjon
    Jon
    Scottsdale Arizona
  10. May 6, 2017 at 8:35 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    You will only need 4
  11. May 6, 2017 at 2:24 PM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Yes I did
    But they did not come with the crush washers
  12. May 6, 2017 at 2:25 PM
    Jolly Onion
    Alex
    Forest Hills, N.Y
  13. May 6, 2017 at 3:28 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I like that you are trying to do the right thing and replace them, but you don't need to replace them when you replace the lines, as long as the washers and both surfaces are clean these washers reseal many times over so its not something you need to replace unless you lose one.
  14. May 7, 2017 at 2:14 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I am lucky if I only lose just one
  15. May 7, 2017 at 7:14 AM
    Jolly Onion
    Alex
    Forest Hills, N.Y
    Ok thanks. I will keep that in mind.
    Just very finicky here, I torque everything to spec too, have seen many examples of "it is good enough" not being good enough.
    keakar[QUOTED] and Dalandser like this.
  16. May 7, 2017 at 7:18 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'm the same way. These guys know what they're talking about though - not lazy guys like I've seen on youtube sometimes :)
  17. May 7, 2017 at 11:09 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Thank you.
