cruise control not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lancewood, Oct 25, 2015.
  1. Oct 25, 2015 at 9:24 AM
    lancewood
    lancewood [OP] Active Member
    lance
    British Columbia Canada
    09 tocoma 2.7L access cab 4×4
    Hello, the cruise control on my 09 Tacoma suddenly stop working. There's no light coming on and I have checked all fuses. I know that it is rare for the switch on toyata to default. Does anybody have any suggestions to what it could be.
  2. Oct 25, 2015 at 9:51 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Spiral cable.
    wilcam47 likes this.
  3. Oct 25, 2015 at 10:53 AM
    lancewood
    lance
    Thanks for the reply. I'm not sure what a spiral cable is..
  4. Oct 25, 2015 at 11:00 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    There's a recall or TSB on the spiral cable. Its in th steering colum area. Something along the lines of electrical wires getting cut.
  5. Oct 25, 2015 at 11:01 AM
    moondeath
    Pa, Gardners
  6. Oct 26, 2015 at 1:17 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    The spiral cable is a loaded coil of wires that allow the steering wheel to go around and still maintain electrical contact between the steering wheel controls and the devices they are connected to such as the horn, cruise control, stereo controls and air bag ... The systems that are effected depends on which wires are broken, in your case it seems to be the cruise control.
    When the spiral cable is replaced all the wires are replaced, not just the one for the effected system.
  7. Oct 31, 2015 at 7:50 AM
    lancewood
    lance
    Thanks, I'll look In to it.
  8. Dec 16, 2015 at 7:02 AM
    Jonas111
    Jonas111 Well-Known Member
    Kelowna, BC, Canada
    Is your truck Manual or auto?
    Have you fixed your issue? I have the same issue and mine is manual. I will be doing some tests to trouble shoot it soon.
    Heard the clutch pedal doesn't return to the top position all the time.
  9. Dec 16, 2015 at 7:04 AM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Told $600 to fix mine .. Oh well .. on we go.
  10. Dec 16, 2015 at 7:04 AM
    Jonas111
    Kelowna, BC, Canada
    What's wrong with it?
  11. Dec 16, 2015 at 7:08 AM
    smcgill
    Sean
    spiral cable
    It's behind the airbags .. a lot of man work to replace ...
  12. Dec 16, 2015 at 5:26 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No, it is not a lot of work to replace...
  13. Dec 17, 2015 at 5:24 AM
    smcgill
    Sean
    Dealer side airbag had to be discharged etc. ... I know dealer...:help:
  14. Dec 17, 2015 at 5:29 AM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    I changed my spiral cable (AKA clock spring) myself. Just took a few minutes. There are good instructions you can find on this site with a search.
    I found one on eBay for $60. It was identical to the one that I removed. That was 3 years ago. No issues since.
  15. Dec 17, 2015 at 9:24 AM
    lancewood
    lance
    My truck is a manual. I took it to toyota, They told Me it is the cc swich itself and wanted to charge me $240 for a new one. When I got it home I took the one screw out of the back of the switch messed around a bit and found it was just the momentary switch that turns the cc on and off . So now I just have the two wires hanging out the back off the switch. It works now, just touch the two wires together for a second it comes on. Good enuff for me for now
    wilcam47 and Ginger-Vitis like this.
  16. Dec 17, 2015 at 1:01 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  17. Dec 17, 2015 at 1:41 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    All you have to do is disconnect the battery and wait a half hour to discharge the air bag circuit. Then replace the spiral cable in the steering wheel.
    TRD_turd likes this.
  18. Dec 17, 2015 at 1:45 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Reminds me of the 1957 Chevy I had as a kid (16). It had two toggle switches for the ignition / starter. Turn 1 on then use 2 for the starter, when it cranks turn off the starter switch.
  19. Apr 6, 2016 at 3:08 AM
    Bullzi511Tacoma06
    Bullzi511Tacoma06 KCCO
    Southeast Louisiana
    2016 MGM Doublecab SR5
    Did anyone have luck getting Toyota to honor the TSB on this issue?
  20. Dec 18, 2017 at 10:02 AM
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    about 8 years ago I got an airbag code for the spiral switch. I bought 1 from the dealer & replaced it my self in less then a half hour. a couple of years later they came out with the recall & mailed in my receipt & a few weeks later I got a reimbursement check.
