Crossed battery... Fried something?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JJDub, Aug 15, 2016.
  1. Aug 15, 2016 at 5:48 AM
    JJDub
    JJDub [OP] New Member
    1997 Tacoma 4x4 - 2.7L 4cyl
    Yesterday I went to check my oil and found my battery bracket had fallen off and the battery slid out of place. As I was moving it back in place the metal bar that covers the battery made contact with the positive battery terminal and gave a good spark. It stayed touching it for 3 or 4 seconds while I reached for a stick to push it off.
    The truck did not start after that. It did start with a jump though. The next time it turned off, I had to jump it again and hopefully I can do the same to get myself to work this morning. Everything appears to be working just fine, it just won't start on its own.
    It's a 97 Tacoma, 2.7 liter, 5 speed, 4X4.
    Any thoughts on what to look for first?
  2. Aug 15, 2016 at 5:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    Have you checked any fuses? That's the first place to look, specifically the IGN or STA fuse.
  3. Aug 15, 2016 at 5:50 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    I'd say drive it around a bit and see if it can charge it self back, worse case the battery is toast, you could swing by a auto store and they'll usually check
    It pretty quick at no cost.
    wilcam47 likes this.
  4. Aug 15, 2016 at 6:09 AM
    JJDub
    I did check a bunch of fuses but was uncertain how to check the bigger ones in the box under the hood.
    I drove 120 miles or so home last night and it did not start after that.
    I had not realized a battery could get ruined so easily, I will stop in an auto store have have it tested.
    Thanks for the quick responses!
  5. Aug 15, 2016 at 6:13 AM
    98tacoma27
    Ben
    Not Beech Creek
    Have them check those fuses too.
  6. Aug 15, 2016 at 6:15 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    IDK if I would let an AutoParts store check fuses. :scared: what they would Fuk UP.
  7. Aug 15, 2016 at 6:17 AM
    98tacoma27
    Ben
    Not Beech Creek
    I'd be impressed if they could screw something up by checking a fuse
  8. Aug 15, 2016 at 6:24 AM
    bohpoli
    bohpoli Well-Known Member
    Doug
    Biloxi, MS
    16 Black TRD OR 4x4
    I bought a new battery for a civic a while back. Turns out, the salesperson gave me the wrong battery and I didn't pay attention. The positive and negative cables would only reach so far and it was obvious which terminal they went yo some hooked it up backward. It made a loud clicking noise that damn near made me mess my pants and I just knew I had fried the CPU. Turns out there is a dummy proof fuse that blew before the cross-wired electricity could reach the computer. $10 fuse and I got a new battery. Everything ran fine for years afterward.
    I know, not much help as my only experience is with a different manufacturer's car, but short story is I don't think you did any permanent damage. Fuse, maybe new battery. If it charges and runs, you're probably safe.
  9. Aug 15, 2016 at 7:17 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    If it runs after a jump, fuses prolly are fine. If battery doesn't hold a charge, battery prolly toast
  10. Aug 15, 2016 at 7:19 AM
    cruiserguy
    Elijah
    SEKS
    I would think a fuse blows before it toasts the battery. But I remember now you said battery wasn't hooked up to you harness, so fuse couldn't blow. I bet battery is a goner.
  11. Aug 15, 2016 at 8:58 AM
    Indy
    Indy Master of all I survey.
    A car battery is capable of supplying hundreds of amps of power, it will blow holes in metal. Shorting it will create an electrical arc a few thousand degrees in heat. Something has to give.
    A $2 multimeter can check voltage pretty easily, or for free at any parts store. The fact that it starts and remains running points to the issue being the battery. Any fuses etc that would result in power not getting where it needs to go would prevent the vehicle from starting/running regardless of it being jumped.
    That it remains running says your alt is working fine. Once a vehicle is running the alt should be providing all electrical power + recharging the battery, which only should supply power to start the engine. After that it does nothing.
    So battery.
  12. Aug 15, 2016 at 8:59 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    a short directly from the battery isnt really gona hurt the trucks electrical. it would have to after the fuse for it to even blow one.
  13. Aug 15, 2016 at 9:07 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    if it starts with a jump then I wouldnt suspect any fuses like others said. Another vote for battery being toast.
  14. Aug 15, 2016 at 8:31 PM
    JJDub
    Got it checked out today and as suspected by many, it was the battery. I was surprised myself that a battery could fry so easily... But I learned a lesson... Be more careful.
    Thanks for the help!
    TACO TX and 98tacoma27 like this.
  15. Aug 15, 2016 at 8:57 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Good to hear!
  16. Aug 16, 2016 at 12:36 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I would bet the time was longer then what you were thinking as well.
    What brand battery ??
  17. Aug 16, 2016 at 4:31 AM
    devinzz1
    devin
    2023 aclb trd or mt
    Oh an next time dont bother with the stick. You wont get shocked to death by 12 volts.
  18. Aug 16, 2016 at 4:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    You might by the +600 amps it holds though.
    Voltage doesn't kill, amperage does
  19. Aug 16, 2016 at 4:57 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I did this in my wife's old Saturn Vue and it blew a fusible link at the alternator. It's a small fragile section of wire that will burn in half to protect alternator. I had to splice in a new one and all good.
  20. Aug 16, 2016 at 10:55 AM
    devinzz1
    devin
    2023 aclb trd or mt
    resistance of our bodies is to high.
