Cross Threaded Spark Plug Repair?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ProForce, Aug 8, 2018.
  1. Aug 8, 2018 at 11:30 AM
    ProForce
    ProForce [OP] IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Have a 2009 4.0 with 130k on the clock. This last weekend I went to replace my spark plugs and one of them unscrewed about 2 turns and then locked up and wouldn't budge. I was able to thread it back in tight and leave that 1 plug alone for now, but this will need to be addressed eventually.
    I have always done my own plugs and am very careful not to crossthread them. I dont believe there is any way i messed this plug up on the last change, but anything is possible. Im not even sure its in fact cross threaded but it sure feels like if i continue to unscrew it that its gonna snap or strip.
    I obviously want to be either at a shop or prepared for the repair before attempting to pull the plug, that way i can avoid a tow just incase.
    My question, has anyone done a helicoil repair before and if so, anything about this motor that can help me out? Should i find a shop to do the work or try myself? Ive repaired threads before, but never used an insert or helicoil type repair and never done spark plug repair. Any tips or suggestions?
    Thanks
  2. Aug 8, 2018 at 1:12 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    is it throwing a code or you are just doing pm?
    if it's still performing fine I'd leave it be
  3. Aug 8, 2018 at 1:23 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Maybe it’s just the plug threads. Try a different plug to rule that out.
  4. Aug 8, 2018 at 1:41 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    You may not be dead-in-the water yet. Back the plug out a little bit...maybe half way before it binds and hit it with penetrating oil and let it sit. Wait for a half hour, screw it back in lightly, then back it out to where it starts binding...screw it back in a little and hit it with another short of oil...repeat as necessary. This has worked for me in the past. If the plug eventually comes out, look at threads...if there is a whack of aluminum in them...yup its heli-coil time.
    NOTE: Do this on a COLD engine only...in fact you should never-ever take a plug out of an ALUMINUM head while HOT.
    If it in fact strips...a decent mechanic can install a heli-coil without pulling the head (had it done years ago on an old Corona I had).
    Hope it goes fine for ya.
    Cheers, Jeff
  5. Aug 8, 2018 at 1:47 PM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    You could try this;
    1. Warm up the engine, the shut it down.
    2. Pull the coil out, and shoot some Seafoam deep creep into the plug hole.
    3. Then work the plug back and forth (as far out as you can get it until you feel resistance).
    4. Next shoot some more deep creep down the hole, close the hood and let it sit over night.
    5. Next morning, install the coil, fire the engine and warm it up, shut if OFF and try to remove the plug.
    6. If it comes out, your Dun, if not you may have to end up using one of these, a shouldered threaded insert, I would not trust a helicoil for a long term fix.
    Armed in Utah and ProForce[OP] like this.
  6. Aug 8, 2018 at 1:49 PM
    ProForce
    Anthony
    Alaska
    Preventative. No codes
    5 plugs i replaced. The one thats stuck is the old plug that wont come out. So thats where im stuck
    I tried penetrating oil but only once and gave up quickly. Ill do this on a day i have time to take it slow. I was just terrified of it breaking inside the head and having no vehicle. So i want to do this when im in a safe place the vehicle can stay in case something goes wrong
    Biscuits likes this.
  7. Aug 8, 2018 at 2:03 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    I understand your concern for sure, but I would doubt you'd break the plug...the threads in the head will let go first. Just take your time with it...could take all afternoon. Remember...COLD motor.
    Good luck and report back.
    Cheers, Jeff
  8. Aug 8, 2018 at 2:07 PM
    Muddinfun
    Muddinfun Well-Known Member
    Smart choice. It is possible to break the plug off. I've never done it myself, but I've seen it done. Then you have a huge problem. The metal between the shoulder and the threads is not very thick.
    ProForce[QUOTED][OP] likes this.
  9. Aug 8, 2018 at 4:05 PM
    ProForce
    Anthony
    Alaska
    Ill update this once i give it a try. Probably give it a little while since i have a week long trip planned in 2 weeks so i definitely dont wanna be SOL before that
  10. Aug 8, 2018 at 4:24 PM
    j8food
    j8food Well-Known Member
    Jay
    2009 Tacoma TRD Off Road
    I've used one of the shouldered threaded inserts (Timesert) as mentioned above in a Yamaha R1 aluminum head with great success and that is a 12:1 compression motor that revs to 10k. Just try to get as much of the metal shavings as possible out of the cylinder before firing it up as they can damage your valve seats.
    Biscuits and ProForce[OP] like this.
  11. Aug 8, 2018 at 7:47 PM
    22argh
    22argh Well-Known Member
    soak it in penetrating oil let it sit overnight, try again
  12. Aug 8, 2018 at 7:53 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    ^^^^^^^THIS ^^^^^^^^ and move the plug back and forth to help the oil get down where it needs to go. You may just have a lot of carbon built up on that plug. Do this with the engine cold and take your time.
    Biscuits and Murphinator like this.
  13. Aug 8, 2018 at 7:58 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Man...... mangled frame now stuck plug. Good luck!
  14. Aug 8, 2018 at 9:00 PM
    ProForce
    Anthony
    Alaska
    Man its its been an adventure with this thing but im finally back to normal when this happened. Frame is straight, rear axle has been replaced, third regeared and added a locker. So some good has come of the repairs. and a ton of other replacement parts too but its been driving like a dream lately. Just this one plug which really isnt the end of the world. I figure worst case if penetrating oil and patience doesnt work, i go to a shop and have them rip it out and rethread it. No big deal. Just a bummer
    Biscuits and TommyG[QUOTED] like this.
  15. Aug 8, 2018 at 9:09 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Hopefully it will free itself, but a machine shop should definitely get it done. Enjoy that locker and have a safe trip! Deal with that bitch when you get back.
  16. Oct 13, 2018 at 10:26 PM
    bhotrod
    bhotrod Member
    b
    UTAH
    05 4x4 SPORT TRD
    I have the same issue. # 5 plug is stuck because the spark plug tube is blocking the socket from going all the way down. I attached a picture, but I will try to take a better one soon. I have changed my plugs a few times and haven't had an issue. Any ideas?
  17. Oct 14, 2018 at 6:34 AM
    badger
    badger Well-Known Member
    07 SR5
    How is the spark plug tube blocking it?? Are you using an impact socket? Did you use anti-seize on the threads when you installed them last?
  18. Oct 14, 2018 at 8:17 AM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Another reason that I hate aluminum... Strips way too easy. I wish you luck!!!
  19. Oct 14, 2018 at 8:30 AM
    bhotrod
    bhotrod Member
    b
    UTAH
    05 4x4 SPORT TRD
    If you look down the tube you can see it is uneven. I have used every type of socket that you can find. It will not go past the second half of the tube. I can't get the socket all the way down to the plug. I hope this makes sense
  20. Oct 14, 2018 at 9:51 AM
    Muddinfun
    I'm looking at it on my phone, but it looks to me like there's a rubber O ring jammed down in there.
    Alexely999 likes this.
