Crooked steering wheel after replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobcat_mt, Feb 26, 2021.
  1. Feb 26, 2021 at 6:17 PM
    bobcat_mt
    bobcat_mt [OP] Well-Known Member
    Montana
    2016 TRD OR DCSB
    Leer 100XR
    I feel like I already know the answer to this, but just wanting some opinions. Recently I replaced my steering wheel with a new one that was in better shape. After install of the new one, I noticed it was crooked when driving. In my attempt to take it off and try re-installing it straight, I was a bone head and accidentally pulled apart the clock spring and broke it. I managed to get my wheel back on (again crooked) and next move, I took the truck to the dealer to have a new clock spring installed. Driving off the lot, I notice the steering wheel was still crooked, so I went back and asked them if they could straighten it out. They told me they tried several times to get it on straight and to spec and after getting an extra opinion, determined the vehicle needed an alignment to properly straighten out the wheel. My original wheel was perfectly straight. Are they just trying to screw me over? Or did my alignment somehow magically change during this time? For what it’s worth, they acted like they felt bad and offered me a discount on an alignment.
  2. Feb 26, 2021 at 6:22 PM
    TRDCal
    TRDCal Well-Known Member
    Canada
    2018 DCSB Sport MT
    Mark the splines on the steering wheel with a sharpie so you know it's current position, then remove and reinstall in which ever direction will make it straight. If you do that and it's still not perfectly straight, then you'll need an alignment.
    bulalo, brandon78lusch and hiPSI like this.
  3. Feb 26, 2021 at 6:41 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Exactly.
    brandon78lusch likes this.
  4. Feb 26, 2021 at 7:24 PM
    bobcat_mt
    Montana
    2016 TRD OR DCSB
    Leer 100XR
    Thanks, that’s what I thought. The dealer claims they tried that and it was still crooked so maybe it is just an alignment issue. I’m inclined to try it again myself. But after breaking the clock spring last time and paying hundreds of dollars for a new one, I don’t know if I can bring myself to take the wheel off again:(
  5. Feb 26, 2021 at 7:32 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Was your replacement steering wheel an OEM takeoff from another 3rd gen Tacoma? In my experience, not all the steering wheels have the splines broached the same way, so the new one could be off by half a tooth. The only way to correct this would be an alignment. You could DIY it if you want, just lengthen/shorten the two tie rods in, say, 1/4-turn increments. Shouldn't be difficult if you're mechanically inclined enough to replace your steering wheel.
  6. Feb 26, 2021 at 7:34 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Ive never swapped my steering wheel for a different one without it being a bit crooked after. That splined piece has to be pressed into the wheel in the exact same position as the old wheel for it to be a perfect match. Due to errors and tolerances in manufacturing, it aint gonna be perfect between different steering wheels.
    Talking about the little splined bushing that connects the wheel to the steering shaft.
    Go get an alignment, problem solved.
    bobcat_mt[OP] likes this.
  7. Feb 26, 2021 at 7:37 PM
    bobcat_mt
    Montana
    2016 TRD OR DCSB
    Leer 100XR
    It’s an OEM wheel I got off of eBay, out of a 2018 Tacoma from a junkyard. I was wondering if that could be an issue as well. I’ll call the dealer Monday and see what kind of discount they’d give me on alignment. I’m one of those guys that tries to fix something and breaks something else, as you can tell
  8. Feb 26, 2021 at 7:41 PM
    bobcat_mt
    Montana
    2016 TRD OR DCSB
    Leer 100XR
    Thanks for the advice. Wish I’d have known this before I attempted to re align it. I’ll get an alignment and report back
