Crazy Dash Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cricket-0, Jan 24, 2021.
  1. Jan 24, 2021 at 9:11 PM
    Cricket-0
    Cricket-0 [OP] Well-Known Member
    I have a 2015 Tacoma DCLB with 30,000 miles. Out of the blue, my key fob stopped working(both sets), my dash lights have the SRS warning light and the slip indicator warning light constantly on. What in the world could that be? No google search is leading me in the right direction. I've checked multiple fuses, took the negative off my battery for an hour and still no luck. No recent 4x4, no new modifications.
    Thanks so much in advance.
  2. Jan 24, 2021 at 9:20 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Any codes?
    Skydvrr likes this.
  3. Jan 24, 2021 at 9:22 PM
    Cricket-0
    The check engine light is not on, Im finishing my 48 hour shift then i'll go to a parts store and see if there are codes. I didn't think there would be any without a CEL.
  4. Jan 24, 2021 at 9:28 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Just spitballing at this point. Had it in for any services? Is it new to you? Maybe check the plugs to the ecu at the in cab fuse panel.
  5. Jan 24, 2021 at 9:28 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    There could be codes in other modules but you need a scanner capable of reading codes in modules other than the PCM, since this all happened at the same time I would kinda suspect a communication issue on the CAN bus. Any aftermarket alarm systems or something possibly plugged into the DLC (you need to look under the dash and make sure there's nothing piggybacked off the factory DLC)?
    6 gearT444E likes this.
  6. Jan 24, 2021 at 9:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There will be a code for the SRS ( Supplemental Restraint System ). Make sure the OBD2 reader you use has the capability to read the SRS Codes.
  7. Jan 24, 2021 at 9:46 PM
    Cricket-0
    Nothing has been done to the truck for over a month, maintenance wise, just kinda hunkering down for the winter. I've owned the truck since mile #5. I'll see if I can pull any codes
    I'll also triple check the fuses.
    Thanks again for the input, I appreciate it.
  8. Aug 5, 2021 at 8:45 PM
    Cricket-0
    Sorry I never updated this, I hate when people get help on threads and don't post what the fix was! (guilty!)
    The solution was a fuse. in the main fuse box, there is a 7.5 amp fuse labeled ECU-B.
    What caused it to blow? I have no idea, hasn't had a problem since.
    Lesson learned? Don't trust your eyes when checking fuses, use a meter.
    Thanks for all the help fellas.
