Crankshaft position sensor relearn?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 691tacoman, Nov 22, 2021.
  1. Nov 22, 2021 at 7:08 PM
    691tacoman
    691tacoman [OP] New Member
    4.0 v6 08 tacoma
    Hi guys, new to the forum. I have a 08 4.0 v6, 1gr-fe engine. It was giving me a p0335 code for the crankshaft position sensor. I changed it out but it still gives me the code. Does anyone know if the 2nd gens have to relearn after changing out the sensor?
  2. Nov 22, 2021 at 7:09 PM
    Bishop84
    Bishop84 Well-Known Member
    Nope, not with Toyota.
    You may have a wiring issue.
    TnShooter and Dm93 like this.
  3. Nov 22, 2021 at 8:02 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You can verify the wiring somewhat with a multimeter but you need an oscilloscope to properly diagnose a cam or crank sensor problem.
    TnShooter likes this.
  4. Nov 23, 2021 at 5:07 AM
    691tacoman
    4.0 v6 08 tacoma
    Thats unfortunate, I don't know the first thing about wiring.
  5. Nov 23, 2021 at 5:08 AM
    691tacoman
    4.0 v6 08 tacoma
    What is an oscilloscope and where can I get one?
  6. Nov 23, 2021 at 5:08 AM
    691tacoman
    4.0 v6 08 tacoma
    All feedback is greatly appreciated, thanks guys.
  7. Nov 23, 2021 at 6:58 AM
    Waasheem
    Waasheem
    2007 xrunner
    Not sure about the taco, at work when I get the code for crank or cam sensor, I replace both and that engine has a short harness I also replace. Never fails, replace one sensor, the other one fails, or the harness is bad.
  8. Nov 23, 2021 at 7:16 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Not sure about Toyota, but on some cars a crank/cam sensor error can be caused by bad timing such as bad/broken/stretched timing chain/belt or poorly operating vvt (bad enough to throw the timing off but not bad enough to throw a code itself), but if it's that it usually runs really bad or not start at all.
  9. Nov 23, 2021 at 8:29 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you are asking this question, you probably need to take it to a shop that has the ability to troubleshoot this issue.
    https://www.tek.com/blog/what-is-an-oscilloscope
    TnShooter, CurtB, b_r_o and 1 other person like this.
  10. Nov 23, 2021 at 4:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The first time I ever seen a scope was in this video.
    When it was all said and done, I found it very interesting.
    And at the same time, gained a lot of respect for todays Technicians.
    It take a small fortune just to start working on vehicles now days.
    BTW, I watched the wholes series, not just this one video.
    https://youtu.be/75ptVbCpkjk
    Jimmyh likes this.
  11. Nov 23, 2021 at 6:32 PM
    Waasheem
    Waasheem
    2007 xrunner
    It’s been years since I even heard oscilloscope mention. I think it was used for fine tuning back when you loosen and twist the distributor to set timing, gap the points and such.
  12. Nov 23, 2021 at 7:02 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It's a very common tool these days for intermediate to advanced technicians to use although it's more commonly referred to as a lab scope or automotive scope and you need a multi-channel one to do many tests.
    It's pretty much a required tool to diagnose many issues on modern vehicles unfortunately many shops, dealerships, and individuals still use the old "read a code, change a part" approach which while it works sometimes it can get quite expensive when it doesn't.
    The hard part is finding a shop that has the proper test equipment and techs with the knowledge to use it.
    https://www.youtube.com/watch?v=qSr6k3htjKY
  13. Nov 24, 2021 at 6:44 AM
    tak1313
    2013 Base 2WD
    ScannerDanner has used cheap, handheld scopes in some of his videos. A Sainsmart handheld can be had for as little as $99 to about $150 for a 2 or 4 channel. No, it's not the greatest scope, has a somewhat limited bandwidth (but by and large enough for automotive use), and being handheld doesn't have much resolution, but it CAN do quite a bit when it comes to auto diagnostics since a scope is just a graph of voltage versus time. For example, it easily has enough power/resolution to see if an injector is operating correctly (I believe that's one of the things SD used it for).
    It's a cheap way of performing at least some testing and to wet one's feet on the use of a scope for automotive use. One disadvantage is being just a general pocket scope, it doesn't have any preset tests the way a dedicated automotive scopes (read much more expensive) have.
    Dm93 likes this.
  14. Nov 24, 2021 at 8:51 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Neither has anyone else...
  15. Nov 24, 2021 at 8:59 AM
    tak1313
    2013 Base 2WD
    I have an old 2007 Buick Rainier (the Buick version of the Trailblazer). When the crankshaft sensor is replaced (on the 4.2L at least), a relearn procedure has to be performed. For GM it's called a C.A.S.E. relearn (for Cranshaft Angle SEnsor). I hate GM. At the time we just got it 4 snow days. Right now it's in the far end of the driveway because I have to replace the PS pressure hose (for the second time) - if you google it, it's a REAL PIA process.
  16. Nov 24, 2021 at 4:30 PM
    TnShooter
    Deogee
    STOCK
    I believe Jimmyh was referring to hearing about a sensor relearn on a second Gen.
    Never heard of it, because you can’t and don’t need to.
    And yeah, I’ve heard of the CASE. There’s no need in all this fancy relearn junk IMO.
    I believe you have to register the battery in some BWM cars now? WTF….really?
    Jimmyh likes this.
  17. Feb 10, 2022 at 10:49 AM
    cacocker
    cacocker Occasional Smartass
    Corey
    Seattle
    2017 TRD OR DCLB MGM
    Mods: https://bit.ly/34WhzsW
    My two cents.
    Just took my truck in with this CEL/code. Nothing wrong with the sensor. Turns out a rat had chewed the wiring.
    So check the wiring harnesses for damage.
