Crankshaft Position Sensor Location
Discussion in '2nd Gen. Tacomas (2005-2015)' started by verdugo173, Sep 24, 2019.
  1. Sep 24, 2019 at 8:27 PM
    verdugo173
    verdugo173 [OP] Member
    Armando
    2007 Tan Toyota Tacoma Pre Runner 4.0
    Hey Guys,
    This one has been killing me for a while. Check Engine light came up. Code is P-0016 "Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A". I have changed the camshafts (both), hardcore clean of the engine. My only other option is changing the Crankshaft Position Sensor. Some suggested that it might be the timing chain, but the engine is not dying or acting different. So please! Do you guys know where the Crankshaft Position Sensor is located in a Toyota Tacoma 2007 4.0. Thank you
  2. Sep 24, 2019 at 8:27 PM
    Bishop84
    Bishop84 Well-Known Member
    That code usually pertains to a stretched timing chain. P0016 and P0012 I quote chains, guides and tensioners.
    b_r_o and Speedytech7 like this.
  3. Sep 24, 2019 at 8:29 PM
    verdugo173
    Armando
    Even if the engine is not stalling or dying?
  4. Sep 24, 2019 at 8:35 PM
    Gerard6778
    Gerard6778 Well-Known Member
    Gerard
    2015 TRD Sport
    Welcome to TW!
    How many miles are on your truck?
  5. Sep 24, 2019 at 8:36 PM
    verdugo173
    Armando
    200k + ... Thank you. Happy to be here and on the road to getting back on my truck.
  6. Sep 24, 2019 at 8:39 PM
    Bishop84
    Yes, the codes are simply stating the cam and crank are out of correlation. The true way to tell is with an oscilloscope and graph them, but with 4.0 tacomas we dont even check. Once its over 150k and p0012/16 we just call a tear down.
  7. Sep 24, 2019 at 8:40 PM
    Gerard6778
    Gerard
    2015 TRD Sport
    I agree with BISHOP84, it could be the timing chain. I think it would need to be really bad for the engine to stall.
    Katdaddy likes this.
  8. Sep 24, 2019 at 8:41 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Yeah because it's a correlation issue not a sensor failure issue. They aren't in the exact right spots in relation to eachother (cam vs crank signal) the computer can make it run like that but less optimally.
  9. Sep 24, 2019 at 8:50 PM
    verdugo173
    Armando
    Alright, well you guys helped me figure this out instead of spending unnecessary money. Thank you guys. Timing chain is out of my scope of practice so I will have a professional look at it, this is no backyard project for me. Thank you guys again!
    b_r_o and Gerard6778 like this.
  10. Sep 24, 2019 at 8:59 PM
    Bishop84
    In your original post it says you've changed camshafts. You mean sensors? Because the shafts are harder than the chains to replace!
    Lester Lugnut likes this.
  11. Sep 24, 2019 at 9:23 PM
    verdugo173
    Armando
    Yes, I meant the camshaft sensors, not the camshafts. Small difference haha.
  12. Sep 25, 2019 at 12:32 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    But just for information:
    Johnbodor likes this.
  13. Aug 30, 2021 at 7:41 AM
    Johnbodor
    Johnbodor Member
    Toyota Tacoma Baja series
    Where is the camshaft position sensor located at
  14. Jul 31, 2022 at 1:47 PM
    spots n specks
    spots n specks New Member
    Mcallen Texas
    3" suspension lift. Leer shell with Yakima rack. 17" XD series rims. Procomp A/T tires
    Having the same code. Installed the two camshaft position sensors. Engine light still goes off and engine still spudders. Code also says it could be the crankshaft position sensor. Will try that as well. What are the chances this will fix it. Or is it the timing chain. I only have 140k on this engine I expected more time until the chain changing
  15. Jul 31, 2022 at 1:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I am not a mechanic so take my advice for what it is worth (nothing)
    While it is possible it fixes it, I would doubt it will.
    Mostly because I’d suspect there would be an additional code for the other cam if it were the crank sensor.
    The key word here is “Correlation”. Which means, things are not in sync when they should be.
    You could use a scope and look at the data, or do a visual timing check to know. A scope would be fast, but they are expensive.
    Jimmyh likes this.
  16. Jul 31, 2022 at 1:54 PM
    Speedytech7
    If you got a cam correlation issue you've either got bad VVT actuators or solenoids, or a very stretched chain. I've heard of low oil pressure causing the same issue but it has to be dramatically low
