Crankcase Breather Hose
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ironmanw, Mar 7, 2016.
  1. Mar 7, 2016 at 6:43 AM
    Ironmanw
    Ironmanw [OP] Member
    Will
    Ormond Beach, FL
    2015, Dual Cab, 4×4, Red
    None... Yet...
    2015 / V6
    Does anyone know whether the Crankcase Breather Hose (not the PCV valve/hose) vents air into the intake (out), or does it pull filtered air into the crankcase (in), or both in and out?
    Thanks for any the help anyone can provide, I've read conflicting data...
  2. Mar 7, 2016 at 6:54 AM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    It allows pressurized gases to exit the engine so oil doesn't puke out your seals.and makes it so shit doesn't explode/cracked cases(oil pan)
    billybob50 likes this.
  3. Mar 7, 2016 at 7:32 AM
    Ironmanw
    Will
    Ormond Beach, FL
    None... Yet...
    Ok, so your stating that the breather hose vents "out" into the intake system prior to the throttle body?...
    Isn't the purpose of the PCV valve to vent the Positive Crankcase Pressure (out) and the breather to take the air in? The reason why I'm asking this is that most people run oil separators (catch-cans) connected to the PCV valve then back into the intake manifold.
    If the breather hose vents into the intake system prior to the throttle body wouldn't there potentially be a need (or benefit) for an oil separators for this side of the "V" as well? The breather hose would spewing oil mist and moisture into the intake manifold which could effect A/F ratio and just generally griming up the throttle body?
  4. Mar 7, 2016 at 8:06 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    the path of the PCV is this, it pulls air from the intake before the throttle body, through the motor than out on the after throttle body side.
    Think high and low pressures here. Before the TB is relative high pressure, after the TB is relative low pressure. Air moves from high to low pressure.
  5. Mar 7, 2016 at 8:42 AM
    Ironmanw
    Will
    Ormond Beach, FL
    None... Yet...
    nd4,
    Thank you...
    So the breather hose draws filtered air into the engine, it does not push air from the crankcase out to the TB. So there is no need or advantage to running an oil separator on the breather hose as it only pulls air into the engine, PCV releases it...
    Sorry for my ignorance here, I've just seen a lot of contradictory information concerning this...
    Respectfully...
  6. Mar 7, 2016 at 9:05 AM
    nd4spdbh
    SoCal
    people say there are advantages to an oil air separator on the line that comes from the engine to the low (vacuum) side of the throttle body. Realistically its the ones who are supercharged and have more blow by that will see any benefit.
    The little bit of oil mist actually helps to lube intake valve stems as well as the upper cylinder, and in a stock non boosted application you are doing nothing more than wasting your money on a catch can.
    Billy182 likes this.
  7. Mar 7, 2016 at 11:32 AM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    The crap I catch in my can on a non boosted application makes me sleep better at night.
    Edit, and I can only hope enough passes my can to lubricate valve stems.
  8. Mar 7, 2016 at 1:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The hose that you are concerned about is the # 2 Ventilation Hose Air Inlet Into the crankcase and its sole purpose is to supply fresh filtered air into the crankcase. The purpose of this air is to displace the gases getting sucked out of the # 1 Ventilation hose via the PCV system.
    No need for a catch can on the # 2 Ventilation hose.
  9. Mar 8, 2016 at 5:04 AM
    Ironmanw
    Will
    Ormond Beach, FL
    None... Yet...
    Thanks Jimmy...
  10. Mar 9, 2016 at 12:13 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Not a problem.
