crankcase breather hose
Discussion in '2nd Gen. Tacomas (2005-2015)' started by esse10, Apr 10, 2013.
  1. Apr 10, 2013 at 7:09 AM
    esse10
    esse10 [OP] Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    Hello fellow tacoma folks, Does anybody know whey the Tacoma 2nd gen. engine has two breather vent hoses coming from the crankcase back to the throttle intake? One small hose attaches to the PCV valve and the other longer on the passanger side seems to be a strait hose. WHAT GIVES??? :confused: In this picture 12261 has the pcv valve and 12262 is the regular hose.
  2. Apr 14, 2013 at 7:46 AM
    esse10
    Texas
    Question #2 Is an oil catch can really helpful or just a waste of time and money????
  3. Jan 28, 2014 at 9:35 PM
    RELLIM
    RELLIM Well-Known Member
    IOWA CITY IA
    2010 ACC CAB 4X4 V6 SR5 TRD
    Scan Gauge II, AFE air filter, charcoal intake filter delete Fitch Fuel Catalyst, Alpine iDA-X303, AMS OIL (ENGINE) Bilstein 5100 RHA series
    The large hose is a crankcase vent not to be confused with the pcv valve which is on the other valve cover.
    The other smaller tube is the atmospheric pressure regulated fuel pressure regulator. Yes I know a mouth full, it don't vent anything it controls a valve by atmospheric pressure.
  4. Mar 17, 2014 at 9:59 AM
    esse10
    Texas
    thanks for the reply,
    I know this is an old posting but I never saw this reply until now. So the longer hose which is 12262 in the picture does not vent anything and it's an
    atmospheric pressure regulated fuel pressure regulator?
  5. Mar 17, 2014 at 8:40 PM
    RELLIM
    IOWA CITY IA
    hold on a second, 12262 is the crank case breather hose which is connected to the intake right before the throttle body. its metered air meaning it goes through the Mass air flow meter.
    12261 is the hose connected to the pcv valve 12204 the other end connects to the intake manifold which is after the throttle body.
    the intake manifold creates vacuum and pulls through the pcv valve it pulls air through the engine by getting air from the crank case
    breather 12262. this just simply explanation for the pcv system.
    about the FPR hose its not pictured on that diagram. its hooked to the FPR and to the air filter box near the fire wall its a hose that's only like an 1/8 size.
  6. May 21, 2017 at 4:28 PM
    CalebCole
    CalebCole New Member
    Caleb
    06 x runner
    Will it hurt any thing if you put a lil filter on the hose?
  7. May 22, 2017 at 5:14 AM
    esse10
    Texas
    what hose are you talking about? I never did get an answer about an oil catch can being useful or not. The catch can will go between the pcv valve and the return hose back to the intake.
  8. May 22, 2017 at 6:46 AM
    Stemmy
    Stemmy Certified Wombat Rancher
    Rob
    Pennsylvania
    2013 Pyrite Mica DCLB
    yes they are very useful, I'll post a pic of mine. I have about 1500 miles since install and its caught about 1/4" worth of oil vapor
  9. May 22, 2017 at 6:47 AM
    Stemmy
    Rob
    Pennsylvania
