Crank Pulley Bolt Removal - Easy Way!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SManZ, Jun 12, 2010.
  1. Jun 12, 2010 at 12:32 PM
    SManZ
    SManZ [OP] Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I just removed the crank pulley bolt on my truck for the S/C install. This guide will grow a bit since some of the photos are on my camera at work.
    You will need;
    -22mm 1/2" drive socket.
    -Breaker bar, 18-24" long, 1/2" drive
    -10mm socket
    -Crank pulley holder tool (see link below)
    -Two M8 x 1.25 x 60mm bolts. Bolts must be all-thread.
    -Six M8 x 1.25 nuts
    -Flathead screwdriver
    -Torque wrench, 1/2" drive
    -Trolley jack with a cupped lift point and casters
    This is the pulley holder tool I used.
    http://www.amazon.com/OTC-UNIVERSAL...0?ie=UTF8&s=automotive&qid=1276369547&sr=8-10
    First, use the flat blade screwdriver to remove 4 of the 5 plastic plugs that hold the rubber flap onto the frame on the inside of the passenger side fender well.
    Remove your skidplate if you have one. My truck is lifted 3". You may need to get your truck off the ground a little if you're at stock height.
    Then, use a 10mm socket to remove the one bolt for the bracket that holds the fluid line that is closest to the crank pulley. Its in front of my lower finger in this photo.
    Set up your pulley holder tool like this before you start;
    From left to right,
    After the bolts are screwed into the pulley,
    -The first nut is screwed against the pulley face to spread out any twisting forces. I bent my first set of bolts because I didn't do this.
    -The second and third nuts are used to hold the tool perfectly perpendicular to the pulley bolt, and to keep the tool from shifting when the pulley bolt is torqued.
    Put the truck in neutral. Put the 22mm socket on your breaker bar. Use the 22mm socket to turn the crank pulley so that the 2 holes are lined up vertically.
    With your pulley holder tool set up, get under the truck and pass the handle end towards the opening on the passenger fenderwell. Lay the handle on top of the frame. Place the tool behind all the fluid lines except the one you removed the 10mm bolt to. The tool goes in front of this line. You can move the larger fluid line closest to the pulley out of the way since you removed the bolt.
    Screw the M8 bolts in by hand until you feel them touch the engine case on the back of the pulley, then back them out a full turn. I did it this way because I didn't want to risk damaging the crank seal.
    Screw the innermost 8mm nuts down against the pulley face. Then, use the 2 remaining 8mm nuts to hold the tool flush with the outer face of the pulley. Tighten these two nuts together so there is no room for the tool to slop around.
    Use the 22mm socket to turn the crank to the left and set the M8 bolts against the holes in the tool. Then get out, put the truck in 6th gear, parking brake on.
    Get back under the truck and set up your trolley jack and breaker bar like this. The breaker bar must be as close to perpendicular with the bolt as possible.
    The jack must be set up this way so that it can roll across the ground as the handle moves up. The cup will keep the end of the handle in place. Keep your body parts on the forward side of the sway bar while the breaker bar is under tension so that you don't get whacked if the bar slips out of the cup.
    If the angle head on your breaker bar has a lot of slop in it (like mine did) you'll need to add one step. After you get everything set up, put the socket on the bolt so that the handle of the breaker bar is pointed straight down. Muscle the bar to the frame tab on the center crossmember. In the pic above, the frame tab is just to the left of my breaker bar on the center crossmember.
    Get the end of the bar up and over the frame tab then run a screwdriver through one of the holes in the tab to hold the bar in place. Now, set up your jack and get the bolt off.
    There was no crack to let me know that the bolt had come loose. The jack just got easy to lift and it was turning the bolt. After that you can remove the bolt with a ratchet driver. Make sure you use the torque wrench to tighten the bolt back up when you're done. The TRD S/C calls for 204ft.lbs.
  2. Jun 12, 2010 at 1:53 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Nice man. I wish I got that pulley holder tool when I swapped out my crank pulley it would have made my life a whole lot easier
  3. Jun 17, 2010 at 6:56 PM
    SManZ
    Fauquier County, VA
    Added more pics, made some corrections, added details.
  4. Jun 17, 2010 at 7:25 PM
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    Are you kidding me?? LOL!! This is the hack-job way to do it.
    Use a chainwrench, which is the proper tool for the job, and the tool all the dealer guys use.
    http://www.sjdiscounttools.com/otc7401.html
    If it's too tight (which somtimes they are) simply wedge the breaker bar against the frame, disable the ignition, and bump the starter. Works every time, and that way, you don't even need the chain wrench :)
    Da Boogie Man likes this.
  5. Jun 17, 2010 at 7:37 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    If it's too tight (which somtimes they are) simply wedge the breaker bar against the frame, disable the ignition, and bump the starter. Works every time, and that way, you don't even need the chain wrench :)[/quote]
    x2:D
  6. Jun 17, 2010 at 7:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    x2:D[/QUOTE]
    this.
    this is the way i do it when it needs done.....easiest and fastest that i have found. a cahin wrench can fubar the pulley if you aint careful.
  7. Jul 9, 2010 at 7:05 PM
    Silver DC
    Silver DC Well-Known Member
    Mark
    Nashville
    07 TRD Prerunner SuperCharged
    Supercharged,TRD CAI, TRD exhaust, DTLT Headers, L.E.D. Taillights, Factory BHLM,Wet Okole Seat Covers,Weather Tech Digi-cut Floorliners
    You cant get a chain wrench around it anyways because of the timing marks indicator on the front cover.
  8. Sep 12, 2010 at 9:04 AM
    SManZ
    Fauquier County, VA
    Not enough room for mine. Its a cordless electric so a bit bulkier than most air tools. I think with the fan shroud and fan removed, you could probably fit an air impact between the crank pulley and radiator.
  9. Sep 12, 2010 at 9:07 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    This is a better idea, my harbor freight couldnt pull it off though
  10. Sep 12, 2010 at 3:42 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I have to remove the crank pulley to replace the engine oil seal behind it that started leaking this week!:mad:
    The FSM instructs to remove the fan shroud, but it appears you guys didn't have to?
    Once the pulley and belt is off you pop out the seal with a screwdriver, put the new seal in place and tap it in until its flush with the block. Don't really see the need to remove the shroud?
    What fuse did you guys pull to disable the ignition?
  11. Sep 12, 2010 at 5:44 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Invest in an air compressor. 90 psi or better.
    I was having a random thought after watching a Tundra commercial today. Commerical was talking about the forged steel crankshaft in the Tundra vs cast iron crankshaft....
    Whats used on the 2nd Gen 2.7 Tacomas? Is it a forged crank as well or is it cast? Been trying to look around and haven't been to lucky.
  12. Sep 12, 2010 at 10:37 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    x2:D[/QUOTE]
    That's what I did with my 3000GT VR-4. Though I didn't bother disabling ignition lol.... it's only for accessories anyway, and I'm rather quick with the key.
  13. Feb 18, 2012 at 11:04 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    Sorry to res an old thread but I figure this is better than starting a new one. I notice that the pulley holder you used has pins that are included in the box and in one picture, you have them holding the pulley. Why did you choose the bolt/nut method instead?
    Just curious as I am getting ready to do this myself and I ordered the same tool but I have had a really hard time finding the bolts you used without spending 20 bucks online to find them.
  14. Feb 18, 2012 at 11:56 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    They'll be threaded in and a lot more secure, when you're working with this much torque it's wayyy better than waiting for that to slip out and damage something or yourself.
    You should be able to find those or very similar length bolts at your local Ace Hardware... they're the best place to usually find metrics.
  15. Feb 18, 2012 at 12:21 PM
    spithead051
    Patrick
    Fairfax, VA
    I've checked Lowe's, Home Depot, and Advance Auto so far. Didn't think Ace Hardware would have that big of selection but I'll have to go take a look.
  16. Feb 18, 2012 at 12:23 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    I almost never find bolts I'm looking for at lowes or home depot, I think I've had maybe once out of 100 times I failed to find it at Ace
  17. Feb 18, 2012 at 12:57 PM
    spithead051
    Patrick
    Fairfax, VA
    Any other advice for doing this? I have an automatic so there's no way to put it into gear like you can with a stick because the torque converter won't engage when the truck is off.
    This method seems to be the smartest and easiest way to remove this bolt without access to air/specialty tools. Bumping the starter just seems like a bad idea to me.
  18. Feb 18, 2012 at 1:45 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Make sure you have a lot of quarters for the swear jar? :shrug:
  19. Feb 18, 2012 at 1:55 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Lost count 30 years ago of how many times I removed the bolt that way.
  20. Feb 18, 2012 at 8:34 PM
    SManZ
    Fauquier County, VA
    Kyouto42 is correct - threading the bolts into the pulley and using the nuts to secure the tool is important. I didn't use the pins that were included with the tool because the largest one that would fit was too small. It would keep popping out of the pulley when any torque was applied.
    You should be able to get the bolts you need at Home Depot, Lowes, or Ace Hardware. Its a M8 but I don't remember the thread pitch. You should be able to get all the hardware for well under $10.
    Edit...read my own post. Thread pitch is 1.25 :p Ace Hardware stores in my area have the absolute best selection of random nuts and bolts, especially metric.
