Crank and Cam Sensor Electrical Issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by jeng4x4, Apr 10, 2020.
  1. Apr 10, 2020 at 10:15 PM
    jeng4x4
    jeng4x4 [OP] Member
    Jimmy
    2000 Green Regular Cab 2.7l 4x4 5-Speed
    Pulled my 2.7 out to replace engine mounts and when I put it back in I am not getting any voltage to or from the crank and cam sensors. Engines cranks but will not start. 99.9% sure all wires are connected and in their rights spots. Got ECM and everything came back fine, now I am stuck. Anyone else have this issue and if so how did you fix it?
  2. Apr 10, 2020 at 11:39 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Check all the fuses. Check engine light come on with key on engine off? Do you have a scanner? What are you using to check voltage to sensors?
    Wyoming09 likes this.
  3. Apr 11, 2020 at 5:27 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
  4. Apr 11, 2020 at 8:54 AM
    rockies
    rockies Well-Known Member
    RockieMountains
    Tacoma
    Also, Check your ground wires to engine.
    JJ04TACO likes this.
  5. Apr 11, 2020 at 12:03 PM
    jeng4x4
    jeng4x4 [OP] Member
    Jimmy
    Pretty sure check engine light does come on. Checked all fuses and ground and everything is good. Using just a regular volt-ohm meter. Having a buddy scan it today.
  6. Apr 11, 2020 at 1:58 PM
    Scesare1
    Scesare1 Well-Known Member
    Shawn
    97 2.7 3rz 4x4 MT
    I’m fighting this same problem right now. Got a new ecm today thinking my was toast and turns out that did not fix my problem. Got no shorts. Continuity is good from plug to computer. Efi and open circuit relay both good. Getting no spark. Also is your fuel pump coming on?
  7. Apr 11, 2020 at 2:20 PM
    Scesare1
    Shawn
    97 2.7 3rz 4x4 MT
    Let me know if you figure anything out. As we are fighting the same battle
  8. Apr 11, 2020 at 3:35 PM
    jeng4x4
    jeng4x4 [OP] Member
    Jimmy
    Ran a scan on it today. Codes for misfire in all 4 cylinders, which I already knew because I was getting no spark. Found I am getting RPM signals, so that rules out the crankshaft sensor having issues, so it brings me down to cam sensor not sending signal to fire. I will check voltage and ohms for cam sensors wires again. Unsure if I should try changing out cam sensor.
  9. Apr 11, 2020 at 3:37 PM
    Scesare1
    Shawn
    97 2.7 3rz 4x4 MT
    I have all new sensors and still nothing
  10. Apr 11, 2020 at 6:18 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Boom! This.
    I read somewhere someone had an issue that ended up being caused by a missed ground somewhere in the engine bay. A small one toward the back perhaps. Don't know if it was a 4 or 6 though. Good luck...that sucks.
    Scesare1 likes this.
  11. Apr 11, 2020 at 6:22 PM
    Scesare1
    Shawn
    97 2.7 3rz 4x4 MT
    I have the ground at the firewall to corner/back of the head. Ground going to the coil packs. Ground at the front of the intake manifold. And the ground right beside the battery going to the battery. Am I missing any?
  12. Apr 11, 2020 at 6:31 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Honestly that sounds pretty comprehensive. But I don't know. Keep combing through there. It has to be something loose or missed. Sorry I can't be of more help w/o actually looking in there myself. Maybe a second set of eyes? That always helps me.
  13. Apr 11, 2020 at 6:44 PM
    Scesare1
    Shawn
    97 2.7 3rz 4x4 MT
    Thanks man. Me and my buddy have been fighting it for a couple weeks now.
  14. Apr 12, 2020 at 3:32 PM
    rockies
    RockieMountains
    Tacoma
    Check the engine coolant sensor and wiring as well.
  15. Apr 12, 2020 at 6:54 PM
    jeng4x4
    jeng4x4 [OP] Member
    Jimmy
    Grounds were not clean enough. Cleaned them all up and she kicked right over. Idles great and no check engine lights.
    mechanicjon, JJ04TACO and cruiserguy like this.
  16. Apr 12, 2020 at 7:14 PM
    rockies
    RockieMountains
    Tacoma
    Good work, glad to hear your Tacoma is running well.
  17. Apr 13, 2020 at 7:47 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Awesome news! :thumbsup:
