Crack in plastic part of spark plug wires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 11B4X4, Jul 29, 2011.
  1. Jul 29, 2011 at 3:42 PM
    11B4X4
    11B4X4 [OP] Well-Known Member
    Northern VA
    2006 tacoma 4x4, Black
    Trd intake, Doug Thorley offroad headers, magnaflow exhaust, RBP running boards, 2.5In spacer, URC O2 simulator, 5100's all around
    Not sure what it is called, But i found a crack in the plastic head part above the spark plug. I've change spark plug wires in other cars. It doesnt look the same in a tacoma. I have an extended warranyt plan. I have to bring it in to see if it is covered. If not is this something i can fix my self?
  2. Jul 29, 2011 at 3:56 PM
    11B4X4
    Northern VA
    Wow...i feel like an idiot
    I completely forgot, that it snaps right of the wires coming off of the coil pack.
    Jeez, well atleast i know the name of the cracked part now.
    Thanks
  3. Jul 29, 2011 at 4:38 PM
    JKD
    JKD Well-Known Member
    Are you experiencing a misfire on that cylinder?
    If not, I'd epoxy the crack and forget about it.
  4. Jul 29, 2011 at 5:10 PM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    +1 if you couldn't get the part for free with the warranty........then epoxy it if it's not misfiring.
  5. Jul 29, 2011 at 7:48 PM
    11B4X4
    Northern VA
    no misfire...just noticed it under pre-roadtrip inspection.
    Epoxy huh...could work
    If i did decide to replace it would i have to replace all of them?
  6. Jul 29, 2011 at 7:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can replace that one only, but it doesnt look that bad. Thats just a plastic housing over the actual coil.
  7. Jul 29, 2011 at 9:48 PM
    JKD
    I hate to think what a full coil pack replacement would cost.
  8. Jul 29, 2011 at 10:13 PM
    11B4X4
    Northern VA
