Covering my air intake with mesh?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Resterik007, May 9, 2017.
  1. May 9, 2017 at 1:52 PM
    Resterik007
    Resterik007 [OP] New Member
    Zach
    2015 Metallic Grey Tacoma TSS
    i took off my wheel well liners in the front of my truck when I installed my aftermarket front bumper. This kind of leaves my air intake open for large debris to get into. I am considering putting mesh over the the intake to stop this. Has anyone done this? Also if you did what did you use to keep the mesh in place?
  2. May 9, 2017 at 1:57 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Or mice and other miniature fauna... I covered mine with 1/2" square wire mesh after finding acorns in the air filter housing. I had to do the same with the cabin air intake after a red squirrel made a nest and had babies on top of my cabin air filter.
  3. May 9, 2017 at 2:01 PM
    Resterik007
    Zach
    Exactly, So what did you use to keep the mesh in place?
  4. May 9, 2017 at 2:02 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I have done it...
  5. May 9, 2017 at 2:09 PM
    Large
    Large Red
    Remove intake tube that ties in to the intake manifold, put a sock over it. I ran mine like this for 2 years, I just changed my air filter every 10k miles or so but it was always dry as a bone.
  6. May 9, 2017 at 2:41 PM
    Larzzzz
    Larry
    MA
    I used tyraps
  7. May 9, 2017 at 2:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    For the cowl intake to the cab............
    Use fiberglass screen on the backside of the cowl trim, hot glue it in place as you keep it taught and well fitted. Trim excess with a razor when all done.
    It will stop the sticks/leaves/nuts from entering the AC intake.
    Larzzzz likes this.
  8. May 31, 2017 at 1:15 PM
    jonnycar1
    jonnycar1 New Member
    NY
    None at the moment
    None
    A sock??? Not the most hi-tech solution - but if it works - why the hell not!
    I believe the problem Larzzz is having is due to the mesh size he is using - as you can see here - www.bwire.com - when it comes to woven wire mesh, 1/2" opening is quite large on the grand scale of things. Perhaps a tighter mesh - perhaps a 10x10 or 20x20 would make for a better choice.
    Is the fear there that this would restrict air flow?
  9. Jun 1, 2017 at 11:19 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
  10. Jun 1, 2017 at 11:36 AM
    Pigpen
    Northwest Montana
    How about water? Your tires will throw a fair bit of water straight into the intake on a rainy day - and if you wheel in the mud...
  11. Jun 1, 2017 at 11:37 AM
    Pigpen
    Northwest Montana
    Sounds like it's snorkel time. Do it right. Buy once cry once.
