Could someone explain dynamic and static load?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wolftaco0503, Jul 17, 2017.
  1. Jul 17, 2017 at 6:27 PM
    Wolftaco0503
    Wolftaco0503 [OP] Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    In non technical terms please
  2. Jul 17, 2017 at 6:48 PM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    Static loads are loads that exert a constant amount of force, while dynamic loads exert varying amounts of force upon the structure that is upholding them. A simple example of a static load is the weight of a bridge span upon the bridge pilings holding it aloft. A truck moving across that same bridge span would be exerting a dynamic load on the pilings.
    Standing stationary in one place on the floor would be a static load, jumping up and down would create a dynamic load. :taco:
    PinnaclePete and KB Voodoo like this.
  3. Jul 17, 2017 at 6:50 PM
    Wolftaco0503
    Adam
    Chicago
    So the Weight load on a Cap on a Taco would Static, Correct. And the load the manufacture place on Caps would be ?
  4. Jul 17, 2017 at 6:53 PM
    JoefromPTC
    Joe
    Yes, because it doesn't change... Just adds weight to the total static weight.
  5. Jul 17, 2017 at 7:01 PM
    JoefromPTC
    Joe
    The variations of dynamic loads can be due to changes in mass, direction of movement, pressure or speed of movement. Like something in the bed of your truck not secured - as it shifts around when you brake, turn or accelerate, the dynamic load on your suspension and tires would vary depending on those types of variables...
  6. Jul 17, 2017 at 7:14 PM
    Taco Caliente
    Taco Caliente WTF?
    San Antonio, TX
    2019 TRD OR DCSB
    Simply put, a 100 lb RTT on your parked bed rack would be 100 lbs STATIC. That same RTT will impart more DYNAMIC load when you drive off a tall curb. Same as if someone tossed you that same RTT from the 2nd story window...it will weigh more, or put more load on what it's sitting on.
    JoefromPTC likes this.
