Cost to wrap a Tacoma?
Discussion in 'Detailing' started by NoMoreMrRiceGuy, Mar 29, 2015.
  1. Mar 29, 2015 at 7:28 PM
    NoMoreMrRiceGuy
    NoMoreMrRiceGuy [OP] Well-Known Member
    jonathan
    San Anlsemo, CA
    2011 DCLB 4x4, 1997 240sx w/1JZ swap
    i have some ugly rattle can paint on my taco from the previous owner, i wanna consider doing a wrap since it will be much cheaper then paint, how much material does one normally need to cover the whole truck? I've seen people do it with all the materials for under $600 thanks
    Alexely999 likes this.
  2. Mar 29, 2015 at 8:19 PM
    ATdivide
    ATdivide Well-Known Member
    Aaron
    RVA
    '17 DCSB TRD-OR '12 DCSB TRD 4x4 '05 Gen4 Runner
    Blank Slate
  3. Mar 29, 2015 at 8:22 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    good one will probably run you just over 3 grand, depending on material. Chrome will cost way, way more due to material cost and technique
    Key-Rei likes this.
  4. Aug 27, 2020 at 8:56 AM
    Lemmehearyeryee
    Lemmehearyeryee Well-Known Member
    Luna
    Pensacola
    2008 Tacoma TRD Sport
    Beginner setup. Bilstein 5100s, black rhino wheels
    A single stage paint job is going to be the cheapest, a good wrap costs a good chunk of money.
    Key-Rei likes this.
  5. Aug 27, 2020 at 9:01 AM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I wrapped my car before and it was a hell of a learning experience. Even if you get high quality vinyl it isn't too expensive. But you really need another person for many parts and expect to redo sections several times until you get the hang of it. It is not an easy experience and requires patience. I really do advocate people to look into plasti dipping as an alternative, as a decent sprayer setup with proper application does a good job of changing up your vehicle and is pretty easy to remove if applied properly. Obviously a proper paint job would be the be all end all solution but the cost is much much higher than any other solution.
  6. Aug 27, 2020 at 9:18 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    It costs as much as a good paint job. They aren't cheap and aren't as resistant to environmental variables.
    Key-Rei likes this.
  7. Aug 27, 2020 at 9:51 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    5 yr. Old thread.
  8. Aug 27, 2020 at 2:24 PM
    Juisebocks
    Juisebocks Commander of the Inglorious Badger
    Drew
    2015 SR5 2.7L AT OPAF,DTF&PITA
    "Stock+"
    Just consider it a long overdue update:thumbsup:. The costs, materials, and methods associated with wrapping have changed a bit in 5 years.
    You and I have very similar trucks lol
    Brice and spitdog[QUOTED] like this.
  9. Jan 19, 2022 at 5:02 PM
    greenteeth
    greenteeth New Member
    Yet, here I am in 2022:D
    wldct69 likes this.
  10. Jan 31, 2022 at 12:12 PM
    Crow41
    Crow41 Well-Known Member
    Lehigh Valley PA
    if you are going for a wrap make certain your installer has plenty of experience
