Cost for Differential Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Minimag95, Mar 7, 2019.
  1. Mar 7, 2019 at 8:14 AM
    Minimag95
    Minimag95 [OP] Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME's w/ 887 Coils, SPC UCA's, 285 ST Maxx. Mobtown sliders & skid
    Whats up guys,
    I'm considering swapping a Truetrac into the rear of my 2009. From what I understand my truck has 3.73 gear ratio, currently the plan is to keep stock gear ratio and just do the rear but i'll be going up to 285/75/16's soon enough so I might also consider regearing to 4.10.
    Anyway, I called two shops for an estimate for just the rear Truetrac, and the first quoted me $1800 for everything (Truetrac carrier, labor, and other parts/ shims and things). The second quoted me $1600-1700, rough estimate. Does this sound about right? Sounds high to me...
  2. Mar 7, 2019 at 8:34 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Could always do it yourself. Shops markup the cost of parts to cover their overhead. Just a fact. Shops charge labor. Mechanics have to feed their families.
    Shop cost initially- 100k to god only knows what
    Lift- 25k+
    Tools-500 dollar impact to take wheels off
    Socket to take wheels off- 50 bucks
    Other tools- probably over a few thousand.
    If you don’t have any of the things to do it yourself, sounds like a bargain to me. Make sure to get your speedometer recalibrated for the bigger tires.
  3. Mar 7, 2019 at 8:38 AM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    Thats wayyyyyyy to much. look into other shops. shit the dealer did mine at $1400.00 to the whole truck with my yukon gears of choice!
    For that kind of money you can get a diamond axle housing and build your own much much nicer axle. but if you cant build it then you screwed and it's gonna cost a lot
    Get all your parts list and price list 1st. and then find out who can install at the best price.
  4. Mar 7, 2019 at 8:43 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    The Truetrac with free shipping from Summit in Ohio is about $500 bucks....... Installer needs to be Toyota savvy - and you need to have new, quality bearings installed.
    Price sounds high to me.... they aren't building a shop for your job alone....
    FFBlack likes this.
  5. Mar 7, 2019 at 8:51 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    That's way high just for a carrier swap. If you get new carrier bearings only, all they really need to do is transfer the ring gear over and put the OE shims back in the same spot. Pinion depth will be unchanged. Check the pinion baring preload and make sure they get it to 6inch#'s. Then check back lash, get it to about 6-9 thousandths, then carrier bearing preload n done. Ship me your diff n I'll do it for much cheaper.
  6. Mar 7, 2019 at 8:58 AM
    Minimag95
    Niles
    Annapolis, MD
    If I had the knowledge and experience I would definitely just do it myself. If that were the case, I wouldn't have posted in the first place. I much prefer to do my own work, but frankly I don't trust myself to do this job without screwing it up.
  7. Mar 7, 2019 at 8:59 AM
    Bebop
    Nick
    Are you regearing both diffs? It says you are 4x4
  8. Mar 7, 2019 at 9:02 AM
    Minimag95
    Niles
    Annapolis, MD
    The breakdown for the $1800 dollar estimate was something like this:
    $550ish for carrier
    $600 for labor
    $200 sumthing for gears (from what i understand, I dont need new gears if i'm keeping stock ratio?)
    remainder for bearings/ shims/ fluid/ etc.
    Never would think that I could SAVE money going to the dealer, but at this point, sounds like that's a decent option lol
  9. Mar 7, 2019 at 9:08 AM
    Minimag95
    Niles
    Annapolis, MD
    The estimates that I got are for just the rear swap, stock gearing. But i do plan to go up to 285's, not sure if it's recommended to regear or not for that tire size. I do understand that i'd need to do both front and rear if I did that and it would cost around double for labor.
