Corroded transmission cooler line
Discussion in '3rd Gen. Tacomas (2016-2023)' started by schruder, Oct 29, 2021.
  1. Oct 29, 2021 at 5:54 AM
    schruder
    schruder [OP] New Member
    Barry
    2016 grey limited
    While out of town recently, the transmission in my 2016 Tacoma slipped a gear and shortly thereafter the check engine light came on. Another 10 or so klicks to my destination, and the truck was parked and the cause of the light investigated. After removing the skid plate, and topping up transmission fluid, it was determined that one of the above mentioned lines , picture attached , had corroded considerably leading to lower fluid levels and transmission failure. This did not happen overnight and would have been almost impossible to detect, but could have been prevented, in my opinion
    My truck is serviced regularly, undercoated every 18 months and babied .
    Purchased in October 2015 and with 77000k, Toyota s response was "past warranty." ! Too bad, so sad !!
    I have owned 4 Runners, and Tacomas since early 2000, and have put over 200000k on each of them with never an issue. I think , Toyota cheaped out by installing these lines and now I am out of pocket by approx 4500$ , and that was the lower end of the scale !
    This post is to advise other Toyota owners with a trailering package to have those lines checked by your favourite mechanic to ensure you don't experience the same aggravation and frustration I have, and if you find the same failures, make Toyota Canada aware of the short comings.
    I am also curious if any one else has experienced this same situation, since I have been advised by Toyota Canada, that this was the first they had heard of this particular problem.
    Thanks for taking the time to read, and possibly reply
    Claudiomartinof likes this.
  2. Oct 29, 2021 at 5:58 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  3. Oct 29, 2021 at 6:17 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    You're saying the trans is toast? I had the same thing happen to my 00 Explorer. I was six hours from home when it happened too. I just topped it off every hour or so and drove it home. Changed the line at home and drove it another 50k miles without issue. Trans had 200k miles on it when I got rid of it.
  4. Oct 29, 2021 at 6:23 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Sorry to hear about your situation. Pretty costly fix. How much fluid was lost? Were there any symptoms prior to the slip and failure or did the line fail all at once?
    I’m not surprised at Toyota Canada's response given their non interest in the 3rd brake light leak issue.
    Bleep100 likes this.
  5. Oct 29, 2021 at 6:35 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Welcome to Tacoma World. :hattip:
    Now this is something that was going on for a while by your own admission. You never noticed the fluid on the ground where you park regularly? The smell while you drove down the road? The oily film on the back bumper and tailgate? This is quite common on all vehicles with transmission coolers across every brand in the rust belt of North America. Sorry to hear you have to purchase a transmission but this was preventable as you say.
    If you live in the Lower Mainland, there is one on Craigslist for much cheaper...Screenshot_20211029-063405_craigslist.jpg
    CrufflerJJ, hiPSI, RustyGreen and 2 others like this.
  6. Oct 29, 2021 at 6:54 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    how much transmission fluid did you add? if it didn't happen over night the only way for the transmission to be that low to affect shifting would be if it puked all 11 qts very quickly? did you patch that section with a piece of hose ?
  7. Oct 29, 2021 at 6:57 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    ^^This^^
    Speedfreak[QUOTED] likes this.
  8. Oct 29, 2021 at 7:03 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Have you had this verified by a reputable independent transmission shop? Assuming that the trans is shot, then go for the used option; this is a very-doable driveway job if you have a buddy with a bit of know how and access to basic tools.
  9. Oct 29, 2021 at 7:11 AM
    wiljayhi
    Jim
    3G, Tuned
    @schruder , do you live in an area with higher than needed use of road salt or corrosive road spray? I thought that the Ottawa area used way too much and way too frequently when I lived there.
  10. Oct 29, 2021 at 12:03 PM
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    cant corrode a transmission cooler line if you dont have a transmission cooler #2020-21 :cool:
    CrufflerJJ and joeyv141 like this.
  11. Oct 29, 2021 at 12:19 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Most places neglect to coat plenty of the little out of the way parts that are prone to corrosion. Power steering and trans cooler lines are high on that list.
    FRE1809 likes this.
  12. Oct 29, 2021 at 2:06 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    These lines are certainly something to keep an eye on. This was the first thing to start corroding on my fathers 2012 Tacoma. Krown never really sprays behind the skid plates….. Good luck with your fix :(
  13. Oct 29, 2021 at 2:44 PM
    RX1cobra
    19 OR
    Except you do have metal cooler lines too...
  14. Oct 29, 2021 at 2:57 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Welcome to TW. You joined just to say that?
  15. Oct 29, 2021 at 5:36 PM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Gotta start somewhere, and it was a decent post instead of the "what's the biggest tire can I fit stock?
    hiPSI[QUOTED] likes this.
  16. Oct 30, 2021 at 4:12 AM
    gearcruncher
    Canadain bumper technician
    Living in the salt belt myself , Thats about the worst cooling line I have seen coming from a 3rd gen 2016 Tacoma with 77K
    Who diagnosed the transmission as being faulty ?
    Was there an attempt to fill the transmission back up and test drive ?
    Big tall dave and hiPSI like this.
  17. Oct 30, 2021 at 4:15 AM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Wow, cooler lines/pipes are always made out of shit steel. You can run a soft hose in stead of the hard pipes.
  18. Oct 30, 2021 at 8:08 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I believe you’ve been another victim of undercoating. In all honesty, it looks like that cooler line has rubberized undercoating on it, which is 100% guaranteed to rot it out. Anytime you spray Ziebart or any other asphalt or rubberized undercoating on anything under the truck, you are sentencing that surface to a quick death by corrosion. The more often you spray it, the worse it will be. Looks like that line ended up with water under the coating (which it will) and then rotted away. The heating and cooling of the line would have compromised the coating in the first day or two, and the rest is history. This is the reason why Toyota doesn’t put that stuff on at the factory.
    Anyways…….on you next truck……don’t use that stuff.
  19. Oct 30, 2021 at 8:32 AM
    The hammer
    I don't live in the rust belt anymore, but when I did, it was an issue. I tried coating all the metal parts with white (lithium) brake grease being careful not to get on the rubber. Messy!
    Replacing metal with all rubber may not be not a good idea imo, but I think I would try heavy automotive paste wax on all the metal. Easy to putt on and shouldn't damage rubber if any gets on.
