Cooper Discoverer AT/3 265/70R17 Tire Pressure??
Discussion in 'Wheels & Tires' started by Southwest4x4, Jan 4, 2018.
  1. Jan 4, 2018 at 1:44 AM
    Southwest4x4
    Southwest4x4 [OP] New Member
    2012 Tacoma TRD Sport
    I have a 12’ TRD Sport that came with the stock Dunlop 265/65R17s
    Just upgraded and changed size slightly to the Discoverer AT/3 LT265/70R17s — Load Range C, 6-Ply (*Not the 10Ply E Load)
    Tire shop inflated these to 39psi.
    Cooper Specs show Max PSI = 50.
    Since I’m running a slightly different sized tire now, I’m not sure what PSI is recommended for these on my Tacoma. I just have a camper shell; won’t be hauling anything.
    Question: What PSI should I run these for everyday use??
    What PSI should I be running *and/or can I safely go down to when I’m off-roading in Utah on both slickrock and sand environments without getting a pinch flat?
  2. Jan 4, 2018 at 5:56 PM
    lyodbraun
    lyodbraun Well-Known Member
    NW Ohio
    2006 SR5 TRD Sport
    Nothing yet
    Start with what they have now and do a chalk test then either Inflate or deflate depending on the results of your test results, I have STMaxx and run them at 35psi and it's perfect... good luck
